Question about Kenmore 62802 Electric Dryer
Dryer door won't close - Kenmore 62802 Electric Dryer
  • steve
    steve May 11, 2010
    Won't close or won't stay closed?
  • 547 Answers
Http://www.partstap.com/ please go here for diagram thank you please rate me
Posted on Feb 22, 2009
The Door won,t stay closed on our gas Magic Chef Dryer
Latch is broken and needs replace or may just need reset. Probably been slammed one time too many.
Aug 07, 2014 | Magic Chef CYG4000AWW Gas Dryer
Frigidaire electeic dryer won't turn on.
Have you checked the door switch to make sure it is closed when the door is closed?
Jan 21, 2013 | Frigidaire Dryers
Kitchenaid dryer model kgys750jq0 wont start
The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive. Here is the switch to order if it is bad.
The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset. Here is the fuse to order in case it is bad.
Post back your findings and I will post the repair video for the repair.
Nov 07, 2012 | Dryers
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
DRYER DOOR WON'T STAY CLOSED
the drier door became loose.go to any repair shop to fix it
Apr 07, 2012 | Kenmore Dryers
Why does the inside light stay on and the Kenmore dryer won't start when the door is closed?
There is a switch in the door jamb that turns on the light and also allows the dryer to start. If you close the door and the light does not go off like it did before, then that switch is probably bad.
Aug 29, 2011 | Kenmore Dryers
Replaced igniter and valve assembly still won't fire up?
check the door locking mechanism, if the door isn't giving a signal that the door is closed it won't fire up,
Jul 21, 2011 | LG D2526 Gas Dryer
Fridgidaire dryer aeq6000es. won't start, beeps 3 times with error message dr
Hello
This code means the dryer door is not closed or the door safety switch is not making a good connection at times. The dryer door safety switch is in the opening of the door and when the door is closed the switch button is depressed. If the control circuit board doesn't get a signal that the dryer door switch is closed it will not allow the dryer to start.. Try firmly closing the dryer door a 2nd time when this happens, if that cures the problem you are good to go, if that doesn't cure the issue you must remove the front panel of the dryer and replace the switch. If you need a switch they are available from Sears Direct for about $15.00 Below is a picture of the switch that most likely used in your model and make, the button on top is what the dryer door depresses when closed..
Jul 12, 2011 | Dryers
My whirlpool duet front load dryer will not turn on. the light is on inside the dryer, but the panel won't light up
Sounds like the door is not closing completely. Check the connectors that tell the unit the door is closed.
May 27, 2011 | Dryers
I have a Kenmore 500 series dryer. The dryer just stopped working but the light stays on when the door is closed.
the door switch is broke.when you push on the paddle of the door switch the lite should go out,if you don't see the paddle it most likely broke off,you need to send the full model number next time,it will start with 110.or similar.the door switch is a safety so the machine won't run until the door is closed,if the switch is broke no power will go to start the dryer
May 10, 2011 | Kenmore 500 6953 Dryer
Kenmore 62802 Electric Dryer Logo
47 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
