Question about Husqvarna Designer I
Husqvarna Designer 1 won't sew...feed dog won't come up
I just bought this machine, and went to use it for the first time, and the feeddogs won't come up enough to feed the fabric through. I used to sell these machines about 5 years ago, and own a different model as well, but for some reason, I can't get it to go! Boo-Hoo!!! Please help!
    Problem Solver:
  • 9 Answers
Either the feed drop is engaged or it may not be releasing due to being stuck because of an oiling issue. Let me know if you've checked this as I have one around to reference as well.
Posted on Feb 21, 2009
Can the feed dogs be lowered on a Designer 1
read your manual I could not find that info .
Feb 19, 2015 | Husqvarna Designer I
Why do the feed dogs reset while free motion quilting?
Your machine's feeddog drop control may loose or worn. Your authorized Viking repair dealer can fix the problem .
Jun 20, 2014 | Husqvarna Viking 1
Feed dogs do not return to up position
manually rotate the handwheel a few times after deselecting the feeddog drop. if this doesn't work, take the machine to an authorized Viking for evaluation.
Apr 16, 2014 | Husqvarna Sewing Machines
For some odd reason, even though it is snapped into place, the metal cover on my designer 1, (near the feed dog) slowly moves and next thing i know, i have a broken needle!!! what is making this happen? ...
Take the needle out and moved the hand wheel, watch carefully where the feed dogs meet the plate. Is the dog hitting or nudging the plate? Is there gunk or packed fuzz?
Sep 12, 2012 | Husqvarna Designer I
Feed dog not pushing fabric
then the feeddogs need to be checked at a sewing machine shop to see
what wrong with the feeddogs
Apr 27, 2012 | Bernina Bernette 75
I can not remember how to lower the feed dogs on my Husqvarna quilt designer and I can not find my manual
I think the Quilt Des. is the same as the Designer 1 (which is what I have) and the lower feed dogs is a serrated dial (looks like part of a circle sticking out of the machine) located on the lower front of the free arm about 2 inches to the right of in line with the needle. You turn the dial towards the left to lower the feed dogs and to the right to raise them.
Oct 09, 2010 | Husqvarna Designer I
Fabric stuck when sewing
Several things could be happening. It may be the hook/needle timing. Or it could be the feeddogs are not moving (that's the toothy looking part under the presser foot that moves the fabric). Recommend removing thread and bobbin (needle and presser foot). Slowly move the handwheel and put your finger on top of the feeddogs to determine if they are moving back and forth and are high enough to move the fabric. Check to make sure you had not manually lowered the feed dogs. You may need to take it to an authorized Husqvarna Viking dealer for their assistance. You can find the closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Nov 21, 2008 | Husqvarna Viking 1
Husqvarna Viking Designer I (feed dogs will not lower)
Its likely this machines feedogs have either never been lowered or not lowered for a long time. Thus the old oil has hardend and is causing the mechanism to freeze up. A tech would take the bottom cover off, follow the connections from the lowering knob, button or switch to the feeddogs and putting a bit of oil or penetrant on each moving connection. Don't force anything, gently tap where you beleive its sticking and turn, push or flip the switch, knob or button slowly bit by bit, back and forth until they drop. They will work loose then make sure they get a bit of oil again. Hope this helps. Good luck.
Jul 13, 2008 | Husqvarna Designer I
Feed dogs
What machine do you have? Have you tried manually raising the feed dogs with the switch? (Need to know which machine you have to help you find the switch.)
Dec 16, 2007 | Husqvarna Viking 1
Sewing Machines Logo
180 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
