Question about Compaq iPAQ H3765 Pocket PC
Compaq Ipac pocket PC 3765
I need to install the battery and I can not get the unit open to install it!!
HELP
  • Anonymous Mar 27, 2014
    How can u or can u hook up your smart phone to the compac pocket pc 3765 to download songs or whatever from phone to pc
    Problem Solver:
  • 8 Answers
Nivensm, I don’t think you need two exclamation marks and an all-caps ‘help’. ;o)
I’m not quite sure what cparr meant by ease the case from the back center to the corners. ?
But, anyway, I’ll give my story: After years of retirement, I went to turn on my iPAQ and no luck. Charged it over night (orange charge light blinked) but no luck. It would turn on in the cradle though. So I assumed it was the battery. I bought one on ebay for a little more than $9 shipped. I think Amazon might have been better because they include a little screwdriver and installation instructions for around $9 (not sure if shipping is included for that price though). Even though the four visible screws are hex, I used a very small flathead, no problem. Where I did have a problem is, what do I do from there? The four screws were out but the back cover wasn’t easily coming off. I didn’t want to force anything. Were there more screws I was missing? Maybe one under the sticker? Maybe the case had to be taken off a certain way. Etc., etc. I spent 1.5 hours looking on the web for a how-to on taking the 3765 apart! At best, I found a few dead links and a few scattered barely helpful threads. Nothing on youtube either, like I had hoped. :o( Anyway, I hope this helps anyone in my shoes:
Undue all four screws (no more). Like I mentioned, a very small flathead will work if you don’t have the correct star/hex tool. Make sure the stylus is ejected. Turn the little hidden button from ‘battery on’ to ‘battery off’. Then, just pick a spot along the edge and start carefully prying. No one spot is easier than another, they are all sealed pretty tightly. But once you do get a bit of separation in one spot, it gets easier. Move your way around the unit. There are quite a bit of snaps. Once the two halves are free, open the two halves carefully/slowly because the two halves will be connected via the battery ribbon. The battery is double taped to the back case and the ribbon connection goes across to the main internals located in the front half of the case. Unplug the battery ribbon connection and then separate the two halves. The battery unplugs easily and the battery comes off the back half case but not without using a butter knife or something similar to get down in there between the battery and case to push through the double sticky tape. Install is reverse, obviously, but you need to decide how to attach your battery to the back wall. I used a few drops of silicone glue.
Just barely helpful: http://www.pocketpcpower.net/PGF.htm
This has a link to take apart directions but the link appears to be broken. Bummer. http://www.directfix.com/mm5/merchant.mvc?Screen=PROD&Product_Code=HP1024&Category _Code=BATT
Good luck.
Posted on May 22, 2010
  • ptatohed May 25, 2010
    Update. As of today (05-24-10), the link I provided at directfix.com to take apart the iPAQ has been restored. I didn't think my e-mail to them would work but it did! :o)
    Link to take apart instructions.
You'll need a very small flat screwdriver and ease the case open from the back center to the corners. Then the sides should pop loose.
Posted on Sep 18, 2009
I have the IPAQ pocket pc 3765 and I was replacing battery but when I opened I saw the battery door out of its place but I do not know where is located then I can not to finish my work. Can you describe...
Welcome to Fixya
As far as i can remember, there are no battery door for ipaq. Once the device opens, gently pry out the original battery. This one should come right off (it is only stuck using some double sided tape). All you need to do is to replace the double adhesive tape if you are going to replace the battery then close the unit. Tip: Use an old credit card or something that won't damage the case to gently lift the battery out.
Thank you for using Fixya!
Jul 04, 2011 | Computers & Internet
Align screen on IPAQ
Tap the target firmly and accurately at each location on the screen.The target will continue to move until the screen is aligned,
pls help.what can i do.
Jul 23, 2009 | Compaq iPAQ H3955 Pocket PC
I don't remember the password I set up.
how about reset password for compaq ipaq 3900... thanks
Mar 12, 2009 | HP Compaq 256MB SD Rom Memory Card IPAQ...
Compaq ipaq
hi i am wolson so i have a problem with my pocket pc so i need connect it to the internet but i can't can you explain what i suppose to do please
Apr 03, 2008 | Compaq iPAQ H3765 Pocket PC
IPAQ 3765 Won't Turn On
you may have to buy a new battery for the unit. Simple as that
Jan 05, 2008 | Compaq iPAQ H3850 Pocket PC
Hp IPAQ H4150
thanks for the post. the first thing is to install the ipac software and try see if the syetm can sysnc. when properly configured there should be an ipac icon in my computer, open this folderand other sub folders will be visible,if you have an SD card media in this device it will be visibleas well. try copy the music of your choice from the system into the music folder or your sd card depending on your pref.
Aug 10, 2007 | HP iPAQ H4150 Pocket PC
IPAQ 3700 series
Most iPaqs use a small AC Adapter This model will still need an AC Adapter, because it does not draw any current from USB to charge.
Oct 11, 2006 | Compaq iPAQ H3630 Pocket PC
Compaq iPAQ H3765 Pocket PC Logo
356 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
