Question about Olympus Cameras
Our olympus stylus verve dropped and the lens won't retract.
The camera was dropped and the lens gears now just grind but do not retract the lens or autofocus.
    President:
  • 919 Answers
The problem you are describing is a problem with the lens assembly in the camera. It seems to have failed and needs to be replaced.
Olympus will charge a flat rate repair fee for this product. The cost is $93 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price. The telephone number to Customer Service is 800-622-6372 option 2 and then option 3.
Posted on Mar 16, 2009
Olympus all weather 760 errors 5f08 5f0a 5e02 Blue error message lens will not retract makes burring sound help please
The sound your camera is making, is probably the slipping from the gears, grinding them down, because something is blocked. Even when you can't see any blockage. Please don't leave the battery in, to avoid more damage. Contact a certified Olympus repair centre, or visit your dealer with the camera.
Sep 17, 2014 | Olympus Stylus Stylus 760 µ Digital 760...
I have an Olympus stylus 720 SW, when I turn it on the lens cover either won't open or opens only partly.
1. Sand or foreign object in the lens cover.2. bad motor or gears.
Try cleaning with canned air while powering the camera up/down...
Mar 18, 2012 | Olympus Stylus 720 SW Digital Camera
LENS OPENING BUT NOT SHUTTING
Its seems lens got stuck in the barrel due to external shock caused, Try out following steps-
  • If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once's or twice then it will stuck again.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Else contact Olympus, your camera need to be disassembled to get at the focusing ring at Service Center .
I hope this will solve your problem
Thanks..!!
Jul 04, 2011 | Olympus Mju 725 SW Digital Camera
Camera does not start up until after several
If you are sure that your battery if fully charged but still does not do any good, then do this little trick:
1. Hold the camera on your right hand with the lens facing the ground.
2. As you press the power on button, tap or hit the camera's base to your left palm. Do this several times.
Chances are, there could be a sand or granule of dust that got stuck on the sides of the lens, preventing it to retract properly.
Hope this helps.
Nov 11, 2009 | Olympus Stylus Verve / ?-mini Digital...
Statup problem
Hi there and welcome to FixYa.
Sorry no one has gotten to your problem sooner.
There is a problem with the lens mechanism. Here is what you can do, either:
A) Whack the camera on the palm of your hand as the lens is extending. OR:
B) As the lens is extending, pull it out and twist it. Don't be afraid of it, but...don't rip it out of it's socket either...LOL. Just give it a pretty good tug/twist.
It may take a couple tries, but that is what will help you. You just have to align the pins right with the track that they ride in. Let me know if you have any questions.
Rob
Feb 08, 2009 | Olympus Stylus Verve / ?-mini Digital...
Olympus Stylus Powers itself off
the power on button is located under de lens slyding thing, therefore probably is broken or just need to be glued to do that u will need to open the camera. the other u will need to replace a small battery on the mainboard. good luck
Dec 04, 2006 | Olympus Stylus 410 / ? 410 Digital Camera
Battery
The expected battery life of the Stylus Verve is about 300 frames.
Sep 01, 2005 | Olympus Stylus Verve S / ?-181 mini S...
Weatherproof
The Stylus Verve weatherproofing protection is equivalent to IEC Standard publication 529 IPX4. The camera will not be damaged by water splashed from any direction. The camera can be used outside in adverse weather conditions. If you are taking pictures when the camera is exposed to rain or snow, make sure that the optical components (lens, flash) are not covered with water. Water droplets on the lens may affect image quality. The Stylus Verve is designed to operate at ambient temperatures of 32?-104?F and relative humidity 30-90%. Please note that the camera is weatherproof, not waterproof, and cannot be immersed in water. Olympus will not assume any responsibility for any camera damage caused by water getting inside as a result of misuse by the user.
Battery
Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
Weatherproof
Cameras Logo
102 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
