Question about Toshiba Satellite A135-S4527 Notebook
Toshiba a135 no life
My kid was using the laptop and in the morning there was no light on except the ac power when connected. i tried the power but still now response. i also tried powering it on without the battery but that did not work. im ready to do some surgery on it any suggestions?
thank you
  • cuk13 Feb 25, 2009
    I have the same problem. I charged the battery one night and the next day the computer will not power on. Only the blue light indicating ac power iluminates. I purchased my computer in May 2007. What does "reseating" the memory cards mean? Thanks.
  • 2,653 Answers
You can start with reseating the memory cards, if that doesn't do anything, which it probably won't, then it's more than likely a motherboard issue. You can poke around but unless you know what you're doing it can be a bit difficult. If you do decide to open it definitely pull the bios battery out for a few minutes and pop it back in. I've saved a few laptops like this before.
Posted on Feb 20, 2009
I have a Toshiba Satellite A135-S4527 and it will not turn on. I checked the AC adapter and I am getting 19 Volts and my laptop shows that i have power going to the laptop but yet it will not turn on.
Welcome to Fixya.
It seems like you are experiencing a "No power/no post" issue on your laptop, here are my recommendations :
  • Disconnect everything attached to your laptop (USB cables, etc)
  • Disconnect the ac adapter
  • Carefully remove the laptop's battery
  • Press and hold down on the power button for at least 10 seconds
  • Connect the ac adapter to laptop without the battery and turn it on
  • If this works, return the battery to the laptop and try it again with the ac adapter
If none of the above procedure works, then the laptop needs to be serviced. I've included Toshiba's support contacts below for your further reference :
Toshiba Support
Hope this helps and Thanks for using Fixya.
Jan 22, 2011 | Toshiba Satellite A135-S4527 Notebook
I am trying to figure out what the buttons on the underneath of my laptop are for, they show a battery sign and mine only stays charged for an hour?
That battery LED shows up when you are connected to AC power. When the battery is charging, the light is up. However, when it is fully charged, it will change color or disappear or does not light. But I am begging you to not use your laptop always with the AC power so as not to destroy your battery. When you are at home, plug your laptop to charge but dont open it. When it is fully charged, remove the battery and turn it on while the battery is out. It is the safest way to conserve and lengthen the life of your battery. Use only your battery when you are in places where there is no power outlet or when you are on the go.
Sep 25, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite a130/a135 series. I connect to
check the power cord to the laptop in the back wiggle it. check the lights. if they come on and go off with you giggling the power cord. the ac input socket may be broken. you may have to wedge it in one spot to get the two lights to come on let it sit there a while 20 min to charge battery some then turn on laptop.
Jun 23, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba A135-S4527 laptop ** Battery not charging!
Check the power input jack soldered connections for cracks, resolder them as necessary.
May 15, 2009 | Toshiba Satellite 1135-S125 Notebook
Toshiba's A135-S4527 Battery isn't working anymore
Have the battery checked or better yet, replaced. Prolonged use might damage the charging circuitry of your machine.
Jan 11, 2009 | Toshiba Satellite A135-S4527 Notebook
Satellite A135-S4427 won't start
when you connect the AC charger with the battery , your laptop power on ?
and try to directly connect the ac charger with laptop without the battery, if it is on, that means the battery go bad, you need replace
Dec 27, 2008 | Toshiba Satellite A135-S4427 Notebook
Not charging . . . And probably the power pin ... where the AC cord connects to thecomputer. That particular component is very fragile. The part torepair it runs between $ 5-$15 but the labor to repair it will costanywhere from $ 100-$250. It can be repaired by you if you are verycareful taking the system apart. Just pay attention to every detail ofyour dis-assembly. I also recommend you get one of these to stop the problem from happening a 2nd time.
Dec 14, 2008 | Toshiba Satellite A135-S4527 Notebook
PC won't go on.
Motherboard Replacement needed most Likely..
Toshibas are known to run very hot...
and over time it might have caused a Short in your Motherboard..
Try connecting laptop to an external video source to see if it is a bad video card.... but I am leaning towards motherboard.... The DC Jack is probably not your problem being that when plugged into AC Power source.. It Lights up a Power Light On the Laptop... which indicates, power supply "good"
Jun 08, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A135-S2276... went in sleep mode.
Try pressing power button once. Does Windows logon screen come up?
Jan 13, 2008 | Toshiba Satellite A135-S2276 Notebook
A135-S2276 does not turn on
Try removing the memory and hard drive. Replace just one memory module and see if it comes up. If it does, replace the hard drive and bring it up. If that works, try replacing the other memory module.
If it doesn't, get back to me for more ideas.
Nov 25, 2007 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
27 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
