Question about Neff 18 in. S5943 Slim-Line Built-in Dishwasher
Neff s5946 slimline built in dishwasher. Fills with water, clonking sound in pipe and does not register on programme, although pump working.
    Sergeant:
    Champion:
  • 338 Answers
If you only hear the clunking sound while the dishwasher is filling then the inlet valve is bad.. i would replace it because if it fails completely you could possibly have a flood..
Posted on Feb 20, 2009
When you switch the dishwasher on, where the programme time cones up it says F. we tried to switch it on n restart again but it still says F and makes noise
Says here the overflow pipe night be blocked and needs to be cleared. When it's cleared if you still get a code "F" and it is still trying to pump dispite no water then remove the side panel and you will more than likely see you have water in the base. Remove the water and run the dishwasher with the side panel off and look for a water leak.
Mar 21, 2011 | Neff 24 in. S5453X1 Built-in Dishwasher
Dishwasher not working. Start button works ok as
It sounds as though the Anti-flood device has kicked in,could be due to a leak under the dishwasher,it will need to be pulled out and investigated.
I would also check that there is water at the hose to the machine.
Hope this helps.
May 21, 2010 | Neff 24 in. S4456 Built-in Dishwasher
Spray arms not rotating
Check pump in the dish washer. Clean and check!
Apr 28, 2010 | Neff S5946 Built-In Dishwasher
Neff Integrated slimline - Programme does not complete.
IT SOUNDS AS THOUGH ITS NOT HEATING DETERGENT AND RINSE AID INTRODUCED INTO COLD WATER WILL GENERATE A LOT OF FOAM,IS APPLIANCE WARM INSIDE AT END OF CYCLE?OR IT COULD BE TOO MUCH RINSE AID IF IT IS FILLED WITH RINSE AID AND YOU ARE USING A TABLET WITH RINSE AID COMBINED IT WILL HAVE TOO MUCH TO USE IN ONE WASH.
Aug 03, 2009 | Neff Dishwashers
Pump carries on pumping
Water is in bottom panel behind kick panel. You have a leak.
Mar 08, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Neff dishwasher continually draining
Update to my problems. It is now working. I removed the T20 tork screw housing the pump cover which is situated underneath the filter. I used a sponge and siringe to remove all water. And started the dishwasher a few times to spin the pump and flickout any excess water. I noticed some small bits of food which were removed and I cleaned all filters and put it back together. It didnt work staright away but the pump was not comong on as soon as the door was shut anymore. I did a reset and then selected a rinse programme and voila it worked! Tried a full wash cycle last night and it all seemed to be working fine......
Feb 25, 2009 | Neff 24 in. S5456 Built-in Dishwasher
How do I reset my dishwasher
Sounds to me like you have put the dishwasher into flood mode, this happens when there is water in the base panel, try leaning the dishwasher back and see if any water comes out. :)
Sep 07, 2008 | Neff 24 in. S5409X0 Built-in Dishwasher
Neff slimline dishwasher type S5946
hi there sounds like your wash pump has burnt out
Jan 11, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Neff S5555 - empties water but stuck in draining mode.
if this machine uses an electrical-mechanical timer with cam switches, the try oiling the shaft bushings both for the timer motor and cams-the timer may be getting stuck because of dry or corroded bushings
May 26, 2007 | Neff 24 in. S5555X0GB Built-in Dishwasher
Dishwasher stuck on "drain"
not easy to fix - it has a leak. the tray at the base is full of water which ooperates a float which switches drain pump on. remove front panel at bottom front and mop out water or tilt backwards 45deg and water will run out. leak is usually main pump
Mar 18, 2007 | Neff 24 in. S5543X2 Built-in Dishwasher
Neff 18 in. S5943 Slim-Line Built-in Dishwasher Logo
398 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
