Question about Acer Aspire 5500 5570-2609 Laptop
OK The only thing I can access is on the screen that first comes up and that's the acer screen. At the bottom left has press F2 enter setup. I press F2. Information, Main, Security, Boot, and Exit appear. I can look through them. When I press F5 at the acer startup screen, it gives me an option to choose my OS or do a memory check. I can do a memory check. When I click on OS it does not enter safe mode. It shuts off and on over and over. I Can't use the dvd drive either. I was told my hard drive may be corrupt or failed. I don't understand how. It was working fine yesterday and a blue window popped up saying windows has shut down to prevent system damage. Also, a computer check revealed my OS is not found. Anymore advice as what is going on and how to fix it. I can fix a desktop inside out, but not a laptop. Thanks.
  • Millie Corkerin Miller Feb 21, 2009
    I have windows vista. I can put a cd in the drive, it just want pull up or start up and I have no way to command it to start.
    I fooled around in setup and was able to do as you said and I'm having sucess. I hope it works. Thanks very much.
    President:
  • 2,653 Answers
Yep, sounds like a crashed / crashing hard drive. Why can't you use the cd / dvd drive? Does it not work? You're gonna need some kind of boot up cd to start troubleshooting that laptop. XP is usually my choice.
Posted on Feb 20, 2009
  • RescueTechLA
    RescueTechLA Feb 21, 2009
    Great! Let me know if you need any more help.
HOW to tget to bios acer aspire AST180-ED400A
Immediately after pressing the power up button, start repeatedly pressing F2 while the Acer logo is displaying. The Bios setup screen should appear. If you press F2 too soon, the keyboard may not have initialized yet. If you press it too late, Windows will proceed to launch. Press it once, wait a second, press, it again, wait another second, and repeat this while the Acer logo is displaying until you see the bios setup screen.
This is standard approach with most Acers. That said, some laptops may defer to either Ff being the key to press or CTRL+ALT+EXC. Such would be entered as the above mentioned F2. Your Aspire appears to be a desktop and I suspect F2 will suffice.
Feb 19, 2015 | Acer Computers & Internet
How to set my acer laptop to factory settings
Reinstall Windows is the only way to take it back to previous state.
Feb 28, 2011 | Acer (ACERMOTHERBOARD)
Hi How do I clear BIOS password set by misstake on Acer Travelmate 2413 LCI? I can not get in to BIOS setup
When you turn on computer look for Acer logo on boot up. Press F8 or F10 or F2 while the logo comes up several times (if you miss turn it off and try again)and then you can access your bios. Use arrow keys and enter to clear the password. Follow the bottom of the screen for directions and if you need more help let me know and thanks for using FixYa.
Feb 01, 2011 | Acer TravelMate 2413LCi Notebook
What is the boot up sequence please
You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
Hope this helps!
Aug 22, 2010 | Acer Aspire 5535-5050 Notebook
Acer notebook doesn't go past the Acer screen
If its the hard drive problem, it will not *shut down* automatically!
You should get your CMOS battery checked/replaced, i guess your's laptop is bit old.
Hope it helps.
Thanks.
May 01, 2009 | Computers & Internet
Won't go past opening screen with "acer" in the middle
If you have Vista, you can press F11 and go into the recovery mode, and it will prompt you to restore your computer to an earlier date.
Mar 22, 2009 | Acer TravelMate 290 Notebook
WHEN LAPTOP IS SWITC\HED ON..IT STAYS ON THE TRAVELMAYE LOGO WITH A THIN RED LINE TO THE RIGHT AND A THIN WHITE LINE TO THE LEFT OF SC\REEN.////////IF LAPTOP IS POWERD UP WHILST HOLDING DOWN F2 BUTTON..A...
ok..enter to the bios setup and then find "load bios setup default" and then save and restart the system.
If won't help then, verify if the hard drive is detected..if don't know how to detect hard drive, go to bios set up and find hard disk if detected. if not hard disk found then ..consult your vendor for immediate support.
melnavz
Oct 22, 2008 | Acer Computers & Internet
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
Acer 3003lci will not boot up.
sounds like locking up on boot, hence why nothing happens when you hit F2, try tapping F2 as soon as you push power button, if still hanging, you may need to take it to get looked at, could be a number of things causing it to lock up
Dec 11, 2007 | Acer Aspire 3003LCi Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
