Question about JVC AV-27530 27" TV
Number won't erase
Is there a way to erase the number 3 which is visable on the top left hand corner of my JVC televison model #AV-27530 which stays on constantly even when changing channels.
    President:
  • 2,992 Answers
Press the "DISPLAY" button. This may cycle through a couple of other displays but will finally clear the channel number. (That's how it gets turned on, too, by pressing that button.)
If this solution is what you needed, please take a moment to rate it. Thanks for asking here!
Posted on Feb 20, 2009
My tv jvc av 27530 has ablue screen and un able to operate by remote or manually so could you help me please?
many of the late model tvs with a crt (picture tube) would go to a blue screen when there is not signal from the cable or antenna so you don't get the irritating white noise and black and white dots running all over the screen, (called the raster), so probably you aren't getting a signal to the tuner. check your connection from the cable/antenna.
Sep 25, 2014 | JVC AV-27530 27" TV
What is the eprom for JVC model # AV-27530
It is the main system control memory IC. EPROM [Electrically Erasable Read-only Memory]
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 08, 2014 | JVC Televison & Video
Video chroma section ic
If you wish to get more details, check the site linked here. http://electronicshelponline.blogspot.com/
Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 10, 2013 | JVC AV-27530 27" TV
Picture on tv JVC 27" AV-27530 is getting to dark to enjoy. During dark scenes you can't see much. Have tried adjusting controls and settings to no avail. Any solution greatly appreciated.
I have the AV-27S33 model and in the rear to the right of the inputs are two slits and inside these slits are two screws. The top screw is the focus,the bottom the brightness.Your tv is a different model but it may have this same adjustment,if it does try turning the bottom screw to the right to increase the brightness.
Jun 11, 2010 | JVC AV-27530 27" TV
I have a jvc av-28wft1eks i can see the picture
well take the back off on the transformer should be two adj. pot screen control on top focus on bottom normally try to turn up screen control good luck
Apr 02, 2009 | JVC AV-27530 27" TV
The tv turns on, i can see picture but its too dark.
Try adjusting the screen control on the flyback transformer. It may be accessible without removing the cover . The access hole is usually on the back of the set and wil be marked "screens" Failing that please post the model number
Mar 12, 2009 | JVC AV-27530 27" TV
Channel number on screen
Just press the Display button on the remote.
Feb 15, 2009 | JVC AV-27530 27" TV
TV Value
under $100.00
Aug 04, 2008 | JVC AV-27530 27" TV
JVC AV-27530 27"
WHEN YOU TURN THE SET OFF,SOUND LEAVES BUT PICTURE STAYS ON--SOUNDS LIKE THE MAIN POWER RELAY IS STUCK-NEEDS TECH TO REPLACE BUT SHOULD BE A CHEAP JOB!!
Dec 03, 2007 | JVC AV-27530 27" TV
JVC AV-27530 27" TV Logo
123 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
