Question about Samsung CXD2512 25 in. Combo
Can't get the tv off of Line in
When I turn the TV on it is automatically set to Line in. I lost the remote control and I cannot set another remote control because I can't get the Line in off. Is there a way using the buttons on the front to get to the channel instead of the Line in?
5 Suggested Answers
  • 81 Answers
SOURCE: 18 Mo old Samsung CXM2785TP made high pitched noise and lost power
The high pitch sound could have been the flyback transformer. check the horzontal output transsitor if is gone the tranfomer is sure to be gone . Tranformers are varying in price are the transistors can also vary you could be looking at around 150.00 plus labour.
Posted on Apr 19, 2007
SOURCE: How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
I had this problem with my TV/VCR combo unit (Samsung CXC1972) after losing the remote while in the dorms. I tried a few different universal remotes and dozens of codes before I tried the Philips 3 device universal remote as pictured below with code 037 programmed into the VCR/DVD button. I can't change the volume with this code but the input key switches between line in and tv. You can also change the channel, access the menu and operate the VCR functions with the code. I bought the remote for less than $10 at Walmart so it might be worth a try, and if it doesn't work you can always bring it back. Hope this helps.98fe8a9.jpg
Posted on Jan 19, 2008
SOURCE: Using a universal remote control on a Samsung TV
i found this somewhere here, don't know if it works. I have yet to try it on my own.. 0358
Posted on Mar 31, 2009
SOURCE: I have no remote to
Try holding buttons down in different sequence. Go get universal remote if that don't work. Good luck!
Posted on Mar 01, 2011
Trying to find out how tostart automatic code seach for tv so I can set the code and use the remote for my old daewoo tv
Try Aim tOn the remote control, press TV once. Press and hold SET until the LED (red light) blinks twice, then release SET. Enter 9 - 9 - 1.
Aim the remote control at the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off (after pressing POWER).
Feb 19, 2011 | One For All URC4220 Remote Control
How do i search for codes on urc20-d1f
URC20 D1F
Set up by Automatic Search
1. Turn TV on
2. Point the remote at tv and Hold SET and TV buttons at the same time and keep pressed for 3 seconds.
3. The LED flashes and the remote control starts the automatic search.
4.The OFF signal is automatically sent to the tv from the remote control.
5. Once the TV switches off press any button except SET to stop auto search.
6. Switch your tv on using the POWER button.
Jan 02, 2011 | Televison & Video
Hello i need codes for asda's universal remote model URC20-D1F so i can sync it with my BEKO tv please can you help?
URC20 D1F
1. Turn TV on
Dec 27, 2010 | Beko 142746 TV
Can you help i have the asda rch7h10 smart price remote controls and have lost the insrutions i changed the battries and now they need re programing
Switch the TV on.
Press the Set and TV buttons together and the red LED should light continuously. Then press the power button and then press it every time the LED flashes (about once a second).
When the TV switches off, press the TV button on the remote. Switch the TV on with the remote and check that the other buttons work as expected. If not, repeat the process...
I had the same problem: worked it out by trial and error ;-) Hope it helps...
Oct 28, 2010 | Televison & Video
I need the codes for an ASDA remote control, model no: URC20-D1F
URC20 D1F
1. Turn TV on
May 09, 2010 | Universal Remote Control Remote Control
Need code for asda remote model#URC20-D1F for use with my sony tv
URC20 D1F
1. Turn TV on
Sony TV codes
010,011,028,030,031,077,107,128,131,166,203,237,302,309,367,444,445,446,449,160
To enter. Just hold SET and TV at the Same time.
The red led light stays on you are in set up mode.
Enter the first code on the list and try power button.
Keep following the steps untill you can turn the tv off.
Then its set.
Feb 08, 2010 | Televison & Video
Lost manuel need codes to set up tv
To program your URC-3021 remote control to operate your TV, the remote has a code search function.
To search for a code for your TV:
  1. On the remote control, press TV once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Oct 24, 2009 | One For All URC-3021 Remote Control
I need instructions for a jumbo universal remote
im going to tell you automatic searching to operate your tv.... turn the tv on..
push the tv button and the on off switch at same time and watch if the led is steady ,leave the buttons., push play button and wait 5 seconds til the led finishes flashing you have to do this about 20 times to be complete secure your remote control doesnt control your tv....but if the control found the code the tv turn it off push reverse button and leave it and wait two seconds to turn the tv on and that set push stop. ........test all functions on your remote control to the tv.....saludos.
Nov 15, 2008 | Universal Remote Control Remote Control
Universalremotecodes
turn on tv set.... press the button set in remote control until light lit on then press power button again and again untill ur tv set off then press set..
Feb 06, 2008 | Big Button TV Universal Remote
Can't change Proline TV / Video combo to scart
visit www.partstore.com to purchase a originald remote for your set if they do not have it they can get it for you.good luck
Apr 07, 2007 | Pro Line 2089VYD TV
Samsung CXD2512 25 in. Combo Logo
23 people viewed this question
Henry  Thomas
Henry Thomas
