Question about Philips Magnavox MWR10D6 DVD Recorder
  • Mexjewel May 11, 2010
    What manual? Mine didn't come with one and it won't program. After searching for active chanels, it tells me "no signal". That's the end of the programming. Sure could use a manual.
3 Suggested Answers
SOURCE: Magnavox DVD.VCR player.
The remote code for magnavox dvd/vcr dual player is, 21593. It work for me..
Posted on Feb 04, 2008
  • 258 Answers
SOURCE: Won't dub
It could be that the tape is copy protected. in that case, you're out of luck.
Posted on Aug 14, 2008
How can I hook up a Magnavox dv220mw9a DVD/CD player to my Orion 1934 19" TV?
One possible solution would be to use an RF Modulator. This will convert the composite (red white and yellow jacks) output from your player to channel 3 or 4 on your tv. Try radio shack or any store that sells electronics to find one. Follow the instructions that come with the RF Modulator.
I hope this is helpful.
Jan 05, 2011 | Orion1934 19" TV
I have a Magnavox DTV Digital to Analog Converter Model TB 110MW9 and lost remote control. Can I purchase another one or can I buy a universal remote. If a universal will work what one should I buy?
Go to Wally world and they have two universal remotes I just purchased a RCA RCRN04GR for about $11 that is with included..... works just fine!!
Hope this helps.
Oct 02, 2010 | Philips Magnavox Learning Universal Remote
How to set the clock on vcr/dvd.
Make sure the antenna//cable TV connections are correct. Channels are set. If this unit is connected to a cable/satellite box, select the local PBS station on them to set the clock automatically.
There's an Auto Clock Setting. "This Unit can set the time and date automatically by reffering to a PBS station.". But I never had to do that, I just went to Setup and it already knew what the date and time was.
"Note: The clock may set itself automatically after you connect the antenna/cable signal and plug in the power cord. Only the analog PBS channel signal is effective for auto clock setting. The unit receives the clock data at 12:00 A.M./P.M. from the PBS channel when the power is off.
1 Press [SETUP] and use the up and down arrows to select "General Setting", then press OK.
"General Setting" menu will appear.
2. Use up and down arrows to select "Clock" then press OK.
"Clock" menu will appear.
3. Use up and down arrows to select "Auto Clock Setting", then press OK.
4. Use up and down arrows to select "Auto" then press OK.
5 Press SETUP to exit.
6. Press STANDBY-ON to turn off the unit.
This unit will search for the time only when the power is off. Leave it off for several minutes to give this unit time to set the clock.
If the unit chooses an incorrect PBS channel, set the PBS channel manually by following the steps below:
1. Select "Manual" at step 4, then press OK.
2. Use [the number buttons] or up and down arrows to enter your PBS channel number, then press OK.
3. Press SETUP and turn off the unit.
If this doesn't work, let me know and I'll type up the instructions for what to do if you need to actually set the clock manually.
Feb 17, 2009 | Philips Magnavox DVD/VCR Dual Player
No signal after autoscan for channels
Tv stations main channel is an addition of 1 (04-1) but can have up to 5 stations (4-1, 4-2,4-3,4-4,4-5). They may not have anymore then one, it is their choice. PBS usually has 2 or 3 channels
Jul 01, 2008 | Insignia Digital-to-Analog Converter for...
VHS to DVD Dubbing Problem
I have the same problem. I saw a solution that said I needed to set my cable to a non-premium channel like NBC, ABC, PBS, CSPAN in order to allow the dubbing to occur without the +VR problem. At first, I thought it was a stupid solution; but guess what, It worked. I just set my cable box to from HBO to CSPAN,restarted the dubbing from VCR to DVD and it worked. Now the question is: Why do I have to change the channel when I'm dubbing from VCR to DVD?
This worked for me..still trying to figure out why it worked???
May 25, 2008 | Philips Magnavox DVD/VCR Dual Player
How to play video on Philips Magnavox PR1906C 19
You can get a device that is an A/V to RF converter. They an cost about $25 and up to a lot of money depending on the quality you want. Many of the audio video stores sell these converters.
With the converter, you connect the A/V from your source in to it, and then connect the converter to the antenna connection of the set. Put the TV on to the channel that the converter instructions ask.
Jerry G.
May 25, 2008 | Philips Magnavox PR1906C 19" TV
Jan 21, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips Magnavox MWR10D6 DVD Recorder Logo
195 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
