Starbucks Barista Burr Grinder
Problem for Starbucks Barista Burr Grinder
Help cleaning Barista burr grinder
By Powe33 - usenet poster
I'd like to remove the burr from my grinder and wipe it off. The
instructions say to remove the top hopper and then pull out the top burr
grinder. I did, it doesn't pull out. Any suggestions?
Starbucks Baristra Burr Grinder ($125)
Thanks,
brettr
Best Solution
posted on Aug 01, 2007
Very Helpful)
pawa
Rank: Apprentice
Rating: 0%, 0 votes
Ya, you have to turn the hopper all the way to the front before the
burr assembly will pull out. A few other tips:
I clean my (Solis 166, same design as Barista except for grind
setting) thoroughly, a LOT. I have a good coffee brush (I get them at
Linens N Things), and I turn upside down over the sink and brush brush
brush down inside the burrs. Then turn right side up and push brush
up into plastic part where the grounds come out and brush up in there.
Then, I bang it with my hands on the sides and on the chute to loosen
more coffee (Kyle the Solis guy said it's tough and this won't hurt
anything - he's right).
Then especially if you have been grinding oily beans, oily crud will
appear inside on the white plastic areas and burrs - I use a Q-tip
with some of the cotton removed to make it thinner using alcohol to
scrape this residue off. For the burrs that are down in there (not
removeable) I use a Q-tip with alcohol and wipe over them to remove
any oily stuff. Then lastly, I get some really lighly roasted beans
and run a large amount through the hopper on the coarsest setting
which removes all the rest of the oily residue. I have heard of
people using dry instant rice and unflavored bread crumbs, but some
have had trouble with this. The light beans do wonders for the
inside, only leaves a bit of the usual dust behind which can just be
brushed away.
If you need to clean the removeable part of the burr, it is VERY
IMPORTANT that it be dried immediately, and very well. Finishing it
off with a hairdryer is important as any moisture could cause rusting
(Kyle the Solis guy said this).
Wendy
The Teeniest Silex Site On The Net
*$'s Barista Espresso Machine
*$'s Solis 166 Grinder
HWP Roaster
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Very Helpful)
Chandler
Rank: Apprentice
Rating: 0%, 0 votes
Thanks. I got it. The problem was the white ring under the top burr wasn't
turned far enough. When I took off the top hopper, it didn't turn that ring
enough was locking the top burr.
brettr
Was this helpful?
Yes
No
Solution #3
Very Helpful)
LiZzIe
Rank: Apprentice
Rating: 0%, 0 votes
If you have modified the grinder range you will find that the top burr
remains locked in place after the hopper has been removed. This is because
the position of the adjustment ring has been skewed. I found that this
occurred for me after I had moved the ring more than 6 holes from the
original setup.
Once the hopper is removed you have to reach under the "collar" and change
the position of the white plastic adjustment ring using your fingers and the
two "rabbit ear" tabs. Moving the ring a few clicks (I believe
counter-clockwise in my case) should free the top burr.
Dan
Was this helpful?
Yes
No
Solution #4
Very Helpful)
Lizzy
Rank: Apprentice
Rating: 0%, 0 votes
Don't pull directly on the top burr itself - pull up on the white plastic
frame that holds the burr. It should pull out *easily* - if not, you're
doing something wrong.
HTH,
Seth Goodman
Was this helpful?
Yes
No
Solution #5
posted on Jul 20, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
You can try using one of the little air blaster cans commonly used to clean computer key boards.
Solution #6
Not Rated)
Charlie
Rank: Apprentice
Rating: 0%, 0 votes
Don't have one around here. Where else could I get such a brush, preferably
online?
You mean the brown beans?
Is there a way to tell if my whole beans are oily?
Was this helpful?
Yes
No
Solution #7
Not Rated)
Odud
Rank: Apprentice
Rating: 0%, 0 votes
What espresso machine do you use this with, Dan?
Sent via Deja.com
Was this helpful?
Yes
No
Popular Solutions for Starbucks Barista Burr Grinder
Questions and Unsolved Problems for Starbucks Barista Burr Grinder
Do you recommend Starbucks Barista Burr Grinder?
Answer
Answer
You can actually just turn it full circle it's very lose and will not set to a specfic number so... (More)
Answer
the barrista portafilter spring is broken. where can i buy a new one? dan
Answer
"There is a thermal fuse on the side of the motor to prevent the motor from burning up. You... (More)
Answer
lid latch is broken so for the last six months iv'e held it down with a rubber band and it has... (More)
Answer
store does't have them, site doesn't list them.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee Grinders Experts
Top Small Appliance Repairmen
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
