Question about Intuit QuickBooks Pro 2003 Single User Retail - Ships SAME business day. S&H $5.95+ (028287006546)
I accidently pressed the revert button
I am currently using QuickBooks Pro 2003 and I am doing Bill Entry. I accidently pressed the revert button on the lower right corner of the screen just after I finished entering all the expenses and was about to save it. is there any way to reverse this?
Thanks,
Jessica
  • pbutternjam Feb 20, 2009
    The only undo button is for typing
    Brigadier General:
  • 5,158 Answers
Look for a button that says undo changes....
Posted on Feb 20, 2009
  • Roberta Smith
    Roberta Smith Feb 20, 2009
    being volunteers and offering you advice has gained my a horrible rating... thanks for that and good luck with the problem
In quickbooks pro 2007, the date format is mm/dd/yyyy
Hi, i am using windows 7 and clicked on start, control panel, regional and language, and then found my settings (was having same problem with quickbooks premier and the date set to US) and found i had accidently selected in the install of windows 7 [English-USA] instead of [English-Australia]. i altered two settings and now my quickbooks is working fine. whenever i searched for this on quicken help sites it did not indicate clearly how easy it was to fix this.
Oct 01, 2009 | Intuit QuickBooks Premier: Accountant...
I just bought a 1995 Lincoln Continental. How do i reprogram the keyless entry on the driver door
After entering the 5 digit code that is currently installed, press the 1/2 button and enter your new 5 digit code. After entering your new code, press the last 2 buttons (7/8 + 9/0) at the same time. This will confirm your new code has been accepted. Keep in mind, in case of loss of power, the keyless entry will revert back to the original code. Best of luck.
Greg
Jul 26, 2009 | 1995 Lincoln Continental
Date Problem in Quick Books Pro 2006
For Starters Go to control panel and open date and time and make sure it's set to today's date.
Jun 01, 2009 | Intuit QuickBooks Premier: Accountant...
Program factory remote keyless entry for 2003 Hyundai XG350
This bulletin supersedes TSB# 02-90-001.
DESCRIPTION: The security system keyless adapter cable (SPX/Kent-Moore P/N 09900-21300) is a special service tool (SST) that is used for programming new keyless entry remote transmitters to the factory security systems. The keyless adapter is used in conjunction with the Hi-Scan Pro (with Hi-Scan SOL Pro Software Version 09-29-03
or newer) and Data Link Connector (DLC) Cable. SERVICE INFORMATION: The keyless adapter cable can be used on the following vehicles:
  • 2001 - 2004 MY Elantra
  • 2001 - 2004 MY Santa Fe
  • 2002 - 2004 MY Sonata
  • 2001 - 2004 MY XG300/350 0390020a.gif
NOTE
  • The 2003 - 2004 MY Tiburon does not need the Keyless Adapter Cable to add keyless entry remotes to the factory security system. Instead, the Hi-Scan Pro connects to the vehicle using only the DLC cable. See page BE-60 in the 2004 MY Tiburon Shop Manual for the latest instructions.
  • The most current Keyless Adapter Cable Instructions are available in the following shop manuals:
SHOP MANUAL
PAGES
2004 MY Elantra
BE-73 - BE-74
2004 MY Santa Fe
BE-43 - BE-44
2004 MY Sonata
BE-40 - BE-41
2004 MY XG350
BE-46 - BE-47
KEYLESS ADAPTER CABLE INSTRUCTIONS:
  1. Connect the keyless adapter cable to the Hi-Scan Pro DLC cable. 0390020b.gif
  2. Plug the keyless adapter into the vehicle's 10-pin multi-purpose connector located behind the driver's side lower instrument panel (next to the DLC). NOTE Sample vehicle shown is the Santa Fe.
  3. Turn the Hi-Scan Pro ON
    and press ENTER
    . NOTE "Release date 29. Sep. 2003" OR LATER
    must appear on this screen. To update your SOL card with the latest software go to www.hmaservice.com and refer to TSB 00-00-001.
  4. Select option "HYUNDAI VEHICLE DIAGNOSIS"
    and press ENTER
  5. Select vehicle model and press ENTER
  6. Select option "TRANSMITTER CODE SAVING"
    and press ENTER
  7. Ensure that the key has been removed from the ignition cylinder before proceeding. 0390020h.gif
  8. Follow the steps noted on the Hi-Scan Pro screen to program the remote(s). NOTE The factory security system can only be programmed to accept two remote transmitters and MUST be programmed for both remote transmitters at the same time.
  9. Press ESC
    on the Hi-Scan Pro and verify that the remote(s) are functioning properly.
  10. Turn the Hi-Scan Pro OFF
    and disconnect the adapter cable from the multi-purpose connector.
May 22, 2009 | Hyundai Motor 2003 XG350
Unable to retrieve company file after closing it
You probably opened an old file. You will need to find the current file that you were using. Use the search and search for all files ending in .QBW
Check the dates they were last used (you don't want the one with the most current date since that was the old file that was opened.)
Feb 17, 2009 | Intuit QuickBooks: Pro 2005 for PC
Upgrading from Quickbooks Pro 2003 to Quickbooks 2009
I would not open up the company file in 2009. Open your 2003 Quickbooks, make a backup and then restore the back up in 2009. If you do run into problems you might want to upgrade into 2006 and then to 2009. (you will need to find someone who can do this for you if you don't have a 2006 version. I can help you with that if you need it
Jan 21, 2009 | Intuit QuickBooks Premier: Accountant...
Quickbooks error ~~ transfering files from 2003 to 2009
There may be more than one issue going on here. In some cases, going to a version that is several versions later requires a stepped upgrade. 2003 to 2004, 2004 to 2006, then to 2009. There may also be data damage existing in the 2003 file that will prevent an upgrade, until it is resolved in 2003.
Intuit used to have a policy that it would have you send in a copy of the data file and would convert it for free if you were going to the latest version.
If you are still unable to resolve this, let me know.
Nov 12, 2008 | Intuit QuickBooks Pro 2007 Full Version...
Computers & Internet Logo
618 people viewed this question
Top Intuit Computers & Internet Experts
Scott Fair
Scott Fair
Mark Taylor
Mark Taylor
Dan Shibata
Dan Shibata
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
