Question about Kenmore 15864/15862 Top Load Washer
I need the manuel for a kenmore 90 series washing machine
  • amartinez164 Mar 02, 2009
    model number is 110.26912691
    it won't spin.
  • steve
    steve May 11, 2010
    Need a model number. 3 digits a period and 8 digits.
  • 15,935 Answers
Head over to the manufacturer's website.
www.SEARSPARTSDIRECT.com
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
  • 1028 Answers
SOURCE: MY 90 SERIES KENMORE WASHING
if agitator mounted pull off ..may be blue ring at base if so pull up and lift dispenser off or newer type twist off..soak in hot water and flush out if front mounted dispenser clean as good as possible
Posted on Apr 27, 2008
mikedurland
  • 481 Answers
SOURCE: my washing machine
  • first thing to check is the lid switch.
  • if the lid switch is bad it will fill up, then agitate then sit there full of water.
Posted on Jul 07, 2008
SearsTechToo
  • 261 Answers
SOURCE: Kenmore washing machine 90 series
If not use pump 3363394 and tilt the machine back to expose the pump. Two clips hold the pump as well two hoses and clamps. From here it pulls off the motor and the new pump is installed. Please note position of clamps and clips to ensure a good repair, observe then repair. PS A&E is a Sears company geared for third party warrantees which makes them useful!
Posted on Sep 07, 2008
  • 262 Answers
SOURCE: Remove agitator on Kenmore 90 series
ok take the top off the agitator there is a cap carefully remove this cap and then some have a inner cap with a handle remove that also in side the agitator it has a 1/2" or 7/16" head bolt remove the bolt and then pull up really ******* the agitator. to replace dogs you have to break the taps holding them in not the agitator be careful
Posted on Jan 11, 2009
TheMobilian
  • 8220 Answers
SOURCE: Water fill valve on Kenmore series 90 top fill washing machine
To get into the machine read THIS first.After you have accessed the innards then you can easily remove and check the water valve. . Hook the water up to the valve. Get a suicide cord and apply 120 vac to each of the coils and see if they open.
Posted on Jan 21, 2009
How do i get the back off my kenmore hd 90 series washing machine
YOU DONT!!! THE 90 SERIES COMES OFF OR OUT DIFFRENTLY. THE WHOLE BODY IS REMOVED BY PULLING IT FORWARD AFTER REMOVING FRONT SIDE PANELS THEN UNSCREWING 2 SCREWS. CAN THEN PULL OUT WHOLE BODY FORWARD
Oct 18, 2014 | Kenmore Washing Machines
My 90 series Kenmore washer spins but doesn't
The most likely problem is the drain pump.
Jun 26, 2011 | Kenmore Washing Machines
We have a Kenmore 90 Series Washing machine. We
You have a leaking dishcharge pump. Not too hard to replace.
Nov 08, 2009 | Washing Machines
Kenmore series 90 washer won't go into Spin
This is probably a bad drive coupler between the motor and the gearcase assembly.
Go here for:
Kenmore Washing Machine Parts
RepairClinic.com
appliance parts, help & more
Sep 20, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Kenmore 90 Series Washer
CHANGE THE LID SWITCH
Apr 18, 2009 | Washing Machines
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
297 people viewed this question
Sal De
fordexpert
Robert Rankin
