Question about Refrigerators
Ice cube dispenser door does not open to allow ice to fill container in the freezer door
    Problem Solver:
  • 19 Answers
Ice is jamming the agitator, or the arm is in the up position.
Posted on Feb 21, 2009
LG Freezer ice maker makes ice but wont dispense
There is a mechanical flap (trap door) that should open to allow ice that is being pushed by the auger in the bottom of the bin to fall out. Possibly the solenoid that opens the door does not work, or you just have an obstruction (piece of ice) preventing the door from opening far enough to allow the ice to pass through. Here is some helpful information and instructions.
Mar 19, 2014 | LG LSC23924ST Refrigeration : Refrigerator...
Ice cube dispenser
make sure the ice maker lever is in the down position, when removing the tray the arm was probably moved to the top(off) position as if the tray was actually full which would shut off the ice making process
Aug 30, 2012 | LG LFX25971ST Bottom Freezer French Door...
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Ice dispensor
Make sure that the "flapper-door" closes about 3 seconds after the ice dispenser button is released. Mine had a habit of catching and staying OPEN. This allows warm air to enter the dispenser / freezer compartment causing your problem.
If it is stuck you have to take the dispenser apart to loosen / lubricate the flapper door cam to allow for free movement.
This is the worst ICE system I've ever seen for a variety of reasons.
Jun 06, 2009 | LG LSC26905TT Side by Side Refrigerator
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
GE Profile side by side refrigerator-freezer PSC23SGNABS
Hi sckk,
ngafm at your service,
Your indoor ice and water keeps getting iced up.
There is an air leak somewhere between the ice and water dispenser on the door and the freezer!
there are many places that this may be. But usually the spring loaded door where the ice drops out to the door ice machine!
It takes a good tech sometimes a couple visits changing a couple of parts till he gets it.
There is no sure fire way to diagnose which part is the culprit thats leaking air.You need an experienced tech that eyeballs it and knows what parts to choose first to be replaced.
The air leak almost microscopic to the eye.
Sometimes you take ice from the door and the crack only closes full some time after wards. Then the tech comes the next day and sees nothing. Or it is intermittent problem!
My advice is only a trained tech can remedy this problem, this time!
If I were there I'm sure I could nail it down!
You need hands on service!
Bless You ,
ngafm,
please give me a goo rating before you sign off.
Thank you.
Sep 09, 2008 | Freezers
GE Freezer Side Ice Dispenser
It isn't supposed to free wheel and the only solution that I know of is tumbler replacement. I have the same issue and am currently hunting replacement parts.
Jun 16, 2008 | Refrigerators
Refrigerators Logo
118 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
