Whirlpool AWZ410 Front Load Washer/Dryer Logo
Posted on Feb 20, 2009
Need a manual for whirlpool washer/dryer awz410 1000
I just need the manual because it does not dry, it leaves it all wet all the time!1
Anonymous
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Mar 10, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
0
Helped
8580
Points
48
Make sure the half load / drying button is pushed in also and the drying time set.
Do you know whether the temperature dial controls the washing or drying cycle. Have shrunk too many jumpers. Thanx
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 31, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5493
Points
If you go on to whirlpool site and look at instructions and manuals you can prit off a basic using guide there.
3answers
Whirlpool duet fw95hedco washer won't spin at max speed & leaves all clothes wet. No error codes during tech diagnostic visit. Washer only 18 months old.
Possible Defective washer transmission. Do you overload the washer with heavy items like towels or blue jeans very often? That can cause early failure.
3helpful
I have a whirlpool duet dryer.. I need to know how to put in the rack for the tennis shoes.. HELP
Hi dear.Here is some help from the user manual.I hope that helps.Thanks. DryingRack
To use the drying rack
Do not remove the lint screen.
1. Open dryer door.
2.
Place drying rack inside dryer drum, positioning the back wire
on the ledge of the inner dryer back panel. Push down on
front edge of drying rack to secure over the lint screen.
3.
Put the wet items on top of the rack. Leave space between
the items so air can reach all the surfaces.
NOTE: Do not allow items to hang over the edge of the rack.
4.
Close the door.
5. Select a timed drying cycle and temperature, or an air cycle
(see following chart). Items containing foam, rubber, or plastic
must be dried on a clothesline or by using the Air Only
temperature setting.
6. You must select a time by pressing MORE TIME or LESS
TIME. Reset time as needed to complete drying. Refer to the
following table.
7. Press (and hold) HOLD TO START button (about 1 second).
NOTE: You must remove rack for normal tumbling. Do not use
automatic cycles with the drying rack.
This chart shows examples of items that can be rack dried and
the suggested cycle, temperature setting and drying time. Actual
Rack Dry Setting Temp. Time*
Wool Sweaters
Block to shape and lay flat onthe rack.TimedDryLow 60
Stuffed toys or pillows
Cotton or polyester fiber filledTimedDryLow 60
Foam rubber filled
N/A Air Only(noheat)90
Sneakers or canvas shoes N/A Air Only(noheat)90
drying time will depend on the amount of moisture items hold.
2helpful
2answers
My whirlpool AWZ510E washer dryer - the dryer doesn't seem to be working - it goes through the cycle but the clothes are still as wet as before. I am using the same cycle as I always have which used to...
there are 3 reasons for a dryer not doing the job yet running through the motions. 1st, the heat is not being produced and only cool room temp air is circulating. this can be a burned-out electric element or an over-heat sensor, or in0line safety fuse. ( if gas, can be ignitor or gas valve coils).. It could be that the washer is not ringing (spinning) dry the clothes verywell and there is too much moisture stiil in clothes which would double the dry time from 50-60 minutes to 2 hours. 3rd, could be clogged vent line and the hot moist air cannot leave the dryer so the clothes get hot by the moisture stays.
1helpful
Whirlpool AWZ410 Washer/Dryer Washes But Will Not Dry!
I have the same problem. The half load / drying button is pushed in; the drying time set; I've reduced the load to almost nothing, but it won't dry. I've tried numerous cycles. The clothes spin, but are still damp at the end.
How would I go about checking my lid switch or fixing my clutch, if that's the problem?
1helpful
2answers
Thin twin stacked washer/dryer...dryer won't stay on
My twin stacking whirlpool washer/dry. The timer switch kicks on but does not dry clothes kicks off after 5 mins but, clothes still wet.
1helpful
3answers
Twin thin dryer
I believe that it is the thermostat that is bad if it will not heat. It is the piece that supplys electrical heat to the heat coils. 696818 is the whirlpool part number for the thermostat on my stackable unit and it can be purchased online for 10-15 bucks.
Washer won't spin dry clothes
What model is in reference here? Please post back with model number.
1helpful
4answers
Why wont my machine start drying?
I called Whirlpool on 08706008989. The machine can only dry half a load of washing at a time. At the end of the washing cycle, the Programme dial should be at either the sun or half sun symbol. Remove half the washing, set the drying time via the drying time dial and press the 1/2 Load Dryer button - Voila dry clothes!
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
