Question about BIT Leigh Router Bit Sets for all D Series Dovetail Jigs
Looking for instruction manual for dewalt worktop jig
I can not find my instructions for the Dewalt321 jigsaw so i therefore cannot replace a blade that fell out
Most Dewalt manuals are available here: https://servicenet.dewalt.com/Home . There are 40 Dewalt power tools with 321 in the model number. Several are jigsaws. There are two types for the DW321 (TO3PAK-2LE JIG SAW) jigsaw. Please look at the label on the jigsaw to ensure that you get the correct model and type. The direct link to the manual for the DW321 Type 1 is currently https://servicenet.dewalt.com/Products/GetDocument?docName=402086-01,DW321.pdf&productId=2841&productType=3001&documentId=24909&translatedFileName=http://documents.dewalt.com/documents/English/Instruction%20Manual/402086-01,DW321.pdf .
To change the regular blade on the DW321 type 1, unplug the power tool. To remove the blade, pull the knob on the top of the jigsaw up about 1/4". Rotate the knob counterclockwise until the clamp opens. Do not force the knob after it stops. Insert the blade making sure that the back edge of the blade fits into the support roller. Rotate the knob clockwise until it clicks and then push it down.
I hope this helps.
May 24, 2017 | Blade Saws
Dewalt 331k jig saw blade falls out
Dewalt Jig Saw
DeWalt Jig Saw MANUAL ManualsOnline com
Blade catch wears out too fast
I loved this tool when it was working but after not that much use the teeth that hold the blade under pressure no longer hold hard enough to prevent the blade from coming out. The mechanism that holds the blade has no catch hole, it uses a few serated teeth to pressure hold the blade in place. Unfortunately, once the pressure starts to lessen you can't tighten it down...
Aug 24, 2014 | Dewalt 331K 6.5 Amp Top Handle Jig-Saw
How to use the splintering insert for the de330 jigsaw
The only reference to the insert is in the manual for your jig saw. If you don't have it you can download one from the Dewalt service website at http://servicenet.dewalt.com/. Find your tool by searching for your model number in the Find Parts box. The manual doesn't go into very much detail but there are instructions on when to and when not to use it and a picture of it installed on the saw.
Sep 19, 2012 | Dewalt 18 VOLT CORDLESS JIG SAW MODEL...
Need instruction Manuel for delta tenoning jig
Go to the Dewalt Service website at http://servicenet.dewalt.com/ and put your model number in the Find Parts box. Hit search and you'll be presented with a page where you can view or download the parts breakdown or the instruction manual.
Jul 31, 2012 | Delta 34-184 Universal Tenoning Jig
Instructions for dewalt worktop jig
If you have the model number go to Dewaltservicenet.com and type it in and you can usually download an owners manual, if you want give it to me and I will try and find it for you and let you know.
Nov 16, 2009 | Dewalt Tools & Hardware - Others
Need instructions to use Worktop jig
Screwfix were happy to send me a copy of the instructions for their jig which adapted perfectly.
Sep 29, 2008 | Tools & Hardware - Others
BIT Leigh Router Bit Sets for all D Series Dovetail Jigs Logo
227 people viewed this question
Top BIT Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a BIT Tool and Hardware - Other Expert? Answer questions, earn points and help others
