Question about Dell Inspiron 1000 Notebook
I have a inspiron 1000 pc notebook and it has a wifi but it says that it is not switched on. how do i swich it on, so i can use the net.???? help any one
  • Anonymous Feb 21, 2009
    we have entered Bios and can not find the wifi connection where is it located in the Bios
    we have entered the Bios but cnanot find the wifi can u help us locate it????
    Sergeant:
    Champion:
  • 275 Answers
Go in to the BIOS and u will find an option there to on the wifi
to go in to bios first shut the system down completely and when you start again the moment u hit the power button start tapping the f2 key and u will land up in bios
Posted on Feb 20, 2009
    President:
  • 2,653 Answers
Check around the sides of the laptop. There is usually a switch. It's not always easy to find so look carefully. If that doesn't work report back and I'll give you another tip.
How do I add wifi to my dell inspiron 1000 laptop using a hotspot?
  • same way you connect to any wifi. switch on the hot spot option in the device u r using as a hot spot then go to your laptop and turn on the wifi.....if u r lucky the laptop will automatically search and give you an option to connect to the wifi hotspot....otherwise u will have to go to wifi settings of your laptop and manually search for the same....visit dell.com for further help.
May 28, 2014 | Dell Inspiron 1525 Notebook
Wheer is the wirless switch on a inspiron 1545 laptpo
It is not a switch
look on the keyboard and look at 'F2' button and press it
this is the button which turns on the wifi
note the f2 key says f2 in blue and then shows a wifi signal icon in white also note a blue square box appears as you switch on and off your wifi connection in the bottom right hand corner...
Jun 01, 2011 | Dell Inspiron 1545 Notebook
I am not getting internet connection. It keeps saying that there is no ethernet adapter connected but I have the ethernet cord plugged in. When I turn the switch on the right of the computer for the WiFi,...
The Ethernet is still can't use for WiFi so far,but it isn't not a problem for the WiFi connect matter because there is a Net Work card itself for most Laptop today including Dell Inspiron 1525 PC Notebook, it may be the Drive matter for the Net work system,you can update it ,or there is no WiFi Net work in your place obsolutely.
Dec 16, 2010 | Dell Inspiron 1525 Notebook
My wifi light is red and it won't change
in thwhen u see sometin like this try and check the wifi botton the botton is always at the fron side of your computer check the swich maybe it is switch off then turn to the other side to put in on thnks
Dec 10, 2010 | HP Pavilion dv7-1132nr Notebook PC
I coudn't found my wirless swich of my ibm thinkpad t42 laptop
There is no hardware switch wireless. Just hold Fn and press F5. It would brings up a menu that allows you to turn Bluetooth on/off, WiFi on/off or both.
Hope this helps
Nov 04, 2010 | IBM ThinkPad T42 Notebook
How can i get wireless on mi dell inspiron 1000
hold fn+f2 on in your notebook thats it wifi will get on :)
Jul 23, 2010 | Dell Inspiron 1000 Notebook
I swiched off my laptop inspiron 1000 at the off switch. when I put it back on the back light did not work
how do you know it is the backlight? Usually people think that's it but it is the inverter.
f the backlight of your laptop stopped working and the image on the screen is so dim that you can barely see it under bright light, most likely you have a failed inverter board. There is a good chance to fix the problem if you replace the inverter board. If you replace the inverter board but the image is still dim, most likely there is a problem with the backlight lamp inside the LCD screen. If that's the case, try to replace the LCD screen. Note: it's much easier to disassemble the laptop display panel when the display panel is separated from the laptop.
I can definitely fix either way if you are out of warranty from dell.
Good luck! EJ Kudelka ej@outlet3g.com 516-860-2969
Feb 06, 2010 | Dell Inspiron 1000 Notebook
Which adapter do I need to visit 'hotspots' w/my Inspiron 1000 ?
you can use this one $59 but will have to install it (not to hard), to make sure you don't already have one when booting up hit the F2 key enter the setup/bios menu and see if one is listed under wireless, if it shows one enabled.
if it is you can connect with it, there is no switch on these dells just a software switch.
this one slides in the side and sticks out link$31 as a cheaper option,
hope this helps
for more help try a premium chat
thanks
Eric
Aug 25, 2009 | Dell Inspiron 1000 Notebook
Dell Inspiron 6000 PC Notebook, No Wifi Radio Signal
Open Intel Proset Wireless or Dell wireless utility from start>all programs. Make sure the the checkbox for 'enable radio' is checked.
Jan 01, 2009 | Dell Inspiron 6000 Notebook
Connecting using wifi
If you go into the device manager and click on Network adapters, is there a wireless adapter listed there? Are there any items that have an exclamation mark next to them? If you answered no to both of the above questions, then there is no wireless adapter installed. You can purchase a PCMCIA wireless adapter rather inexpensively online. ($25) It will just pop right into the PC slot on the side of the laptop.
Dec 04, 2008 | Dell Inspiron 1000 Notebook
Dell Inspiron 1000 Notebook Logo
63 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
