Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Kenmore Progressive cannister electric motor will not operate. Is there a fuse blown or some other reason? All filters are clean. Power works to wand only.
  • 201 Answers
Apparently there may be a fuse in the canister itself, I have no instructions for getting to it though. There's another post on here you might want to check, perhaps that person can tell you how to get to it
http://www.fixya.com/support/t1581380-kenmore_progressive_canister_vac
Please rate if this helps :)
Posted on Mar 05, 2009
My kenmore progressive canister vacuum turns on only if the hose is attached to the floorwand. It seems that the canister motor is not working because I can't hear anything coming from the caniste
If the floor wand is powered, there may be an electrical connection that is broken when the wand is disconnected. This is part of the design, not necessarily a fault
Jan 05, 2013 | Vacuums
High pitched sound when power on
I had a vacuum cleaner that did the same thing. My vacuum had three suction levels. The noise level would decrease as I lowered the level. I also noticed that when I turned the vacuum off the sound didn't stop instantly, it wound down/faded off as the motor slowed down. I found the problem to be the bearings in the main motor. I've been told that the motor that powers the carpet brushes can also make the sound if the motor bearing fails.
Dec 29, 2012 | Kenmore Progressive Bagless Upright with...
Power Head keeps cutting in and out while vacuuming???Canister motor keeps running but the power head starts and stops like there is a short or some loss of connection somewhere. Any ideas?
The electrical terminal at the top of the extension wand may be loose or corroded. Unplug the vacuum and remove the wand from the hose assembly. Look at the 2 prongs and clean off any corrosion using a a Q-tip or scrape with a screwdiver if it's more persistent. After cleaning reconnect the wand to the hose and try it again. If the prongs are not corroded, they might be loose instead or they might not be aligned properly. If this is the case then bending the prongs very slightly may help realign them. The part that may be giving you the trouble is called the terminal cover (PN 8191782). It costs about $10 but the problem is knowing the procedure to actually replace the part. CAN ANYONE EXPLAIN HOW TO OPEN UP THE EXTENSION WAND TO REPLACE THE TERMINAL COVER ??
Jan 14, 2010 | Kenmore 23913 Progressive PowerMate Bagged...
Need to find specs to test hose and electrical connections
There are no hose specs. You have continuity or you don't. These are very problematic canisters as they age.
Kenmore canisters are very subject to dirt build up on internal contact rings where they swivel at the elbow adjoining the vac.
They are also prone to intermittent connections at the handle/wand junction and at the wand/power head connection.
Due to the weight of the head there is a lot of strain on those connections.
You never fix half the connection, always both, male and female components in pairs for best results.
Oct 04, 2009 | Vacuums
I have a Kenmore progressive cannister vacuum cleaner.
There should be a pile height pedal on rear of the attachment, just behind the where the wand goes into it, near the handle release pedal. Just keep clicking on it to go through the height settings.
Mar 05, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Can you tell me if Powermate Power Brush attachments are all the same for all the Sears Powermate Cannister vacuums.  That is, would one power brush attachment on a Model 116.56512690 fit one that is Model...
i think your confusing model #s ,as the 116. 22512202 is the canister model number and the model number of the powerbrush attch would be 116.52512202,but to answer your ? no it depends on which wand your useing that determans which one you can use
there 3 types of wands 1 telescoping which comes only on progressive models 2 a 2 piece with wire connected and a 2 piece
wire not connected,hope this helps,les
Jan 03, 2009 | Kenmore 22812 Bagged Canister Vacuum
Carpet attachment
Check the plug ends at the top of the wand and the plug going into the hose handle, also at the bottom of the wand. It sounds like they may be burnt, if so they will need to be replaced. One cause of these connections going bad is not turning the power head off when connecting or disconnecting. Therre are other causes, the switch in the handle is going bad, also some of these cannisters have a relay mounted by the vac motor, sometimes they go bad.
Mar 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore Progressive Motor is not working.
Could be a number of things, cord may be bad as well as a problem with the motor. There also is a fuse that could have blown. If you go to sears.com, click on parts, put in your model number, when the page loads, click on the first link and you will have a parts list, and scroll down there will be a parts break-down picture that you can look at. You can also order parts thru the Sears website.
Feb 28, 2008 | Vacuums
Kenmore progressive vaccuum
Did you replace the hepa filter with a new one? Those filters may not look bad, but after a period of time and use, air is restricted thru them. They should be changed at least once per year.
Sep 03, 2007 | Kenmore 31913 Progressive Direct Drive...
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
463 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
