Question about Cakewalk SONAR 4 Producer Edition for PC
Cant hear USB Keyboard through sonar
I have a small Korg K25 Midi studio controller. When it is plugged into my computer I am Able to hear it. When I open Sonar and set it to a channel I can see the levels moving up and down from me hitting the keys, but there is no sound when the program is open. when I record with the keyboard Lines or notes show up where it is to be recorded but when i playback, no sound occurs. (all volumes are up) I have also inserted many soft-sythns and set the channel i'm usings input to USB sudio Device OMNI and the output to the Synth that I had Imported. I've also tried using other outputs and inputs and that does seem to make a difference. I also use a USB M-Audio device where I plug guitars and microphones etc. into and I have no problem using that. If you could share any advice with me, it would be greatly appreciated.
Thanks you, JV
  • iceumup Mar 24, 2009
    cant hear no music nothing on my sonar studio i'm confuse it ant easy what people claim it will be
SOURCE: Sonar Producer 6 - Audio/midi devices/controller-surfaces..Which settings??
o always run at 0 on play back recording -3 with drums use anlog cables then select anlog 48000 24 bit if u can if its digital cable might use 96000 bit rate ok spdif watch it close on digital for digital clips never go in red keep steady balence cheak your sorse tape how loud is that adjust your stuff to sound good at peaks never hit red in digital mode does this help sum
Posted on Mar 13, 2008
SOURCE: Sonar 6 Producer - palyback quality issue
I had this problem today whilst installing Sonar on my new laptop. It wasn't the click track. It was the playback glitching, clicking and rattling. I put the buffer size to maximium but it was still happening.
I got round it by downloading the latest version of ASIO4all (2.9 beta4) and installing it. I then opened Sonar 6, options, audio, advanced, then selecting ASIO in the driver mode drop down box. Then I closed Sonar and reopened it.
If you use one device for recording and playback it should work now but if like me you use seperate devices or if it doesn't work click, options, audio, general, ASIO panel, advanced options. Here you can select your inputs and outputs. Play around a bit here. Mine worked when the output of the playback device was selected and both the input and output of the recording device was selected.
ASIO4all sorted out my latency issues as well.
Hope it helped.
Posted on Oct 05, 2008
  • 17 Answers
SOURCE: me and some buddies record
Sounds like what is called a latency problem. You need to go into the settings in Sonar and under audio, adjust the Latency to a higher number...I don't know sonar home studio, or I would tell you the exact area to go in the menu's to adjust latency..Hope this helps!
Posted on Mar 06, 2009
  • 39 Answers
SOURCE: sonar 4 and midi sound cuts offat start of playback
If you are recording from bar 1 at time 1.00 you might want to start recording one or two bars later. So try starting your song on bar three istead of bar 1
Posted on May 19, 2009
  • 110 Answers
SOURCE: I need a manual for cakerwalk sonar 4
Download Manual From Here!
Posted on Feb 05, 2010
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
Now frustration has set in as i am trying to get my Yamaha MU5 tone generator and Korg keyboard (Both midi) to link with my new Acer Aspire One D255 N550 netbook which i have loaded with an old version of...
I need to know how it's all hooked up first (IE Korg midi out to Yamaha in, Yamaha thru or out to Chord, USB from chord to Acer.....etc etc. etc.)
Also, see if the instruments can at least talk to each other.
Post a reply here.
Mar 14, 2011 | Acer (54.AA806.001) Sound Card
Cant hook up my casio 2000ctk 2 computer
if its a midi keyboard, it should be in your audio settings in control panel under the midi device, ive used fl studio with these before, or reason. hope this helps in some way.
Nov 30, 2009 | Casio CTK810 61 Key Keyboard
Stuttering during audio playback in Sonar
The stuttering is caused by excessive CPU usage, in other words: you have too little CPU power to play the file with the inserted synth smoothly. You could try inserting a different synth or play with the rendering-options of the synth (like disabling aliasing, etc.) or increase the audio buffer size (under audio options ?), but the only longterm solution is upgrading to a much faster computer.
Even when you find some tweak which lets you play the file (just) smoothly, adding another effect or synth is likely to cause it to stutter again, since your computer doesn't meet the official (!) minimal requirements for running Cakewalk Sonar 6, which is at least a Pentium 4 1.3GHz computer (and you have a 1.0GHz computer).
I would recommend upgrading your computer to something which at least meets the "recommend requirements" of Cakewalk Sonar 6, which is a Pentium 4 2.8GHz or newer (like any Intel Core 2 system), when you're serious about composing music.
Aug 12, 2009 | Cakewalk SONAR Power Studio 660 Full...
My MIDI won't play back even when I play the file, no matter which program I use to play it. The computer I use is a Compaq Presario, I have Cakewalk Home Studio 2002 on it, and my sound card is SB X-FI...
The default MIDI setting of your PC may have been set for another MIDI device (for example, if Cakewalk Home Studio has been used with a MIDI compatible keyboard). Go to... Control Panel / Sounds and Audio Devices / Audio / MIDI music playback and change the setting back to your soundcard (and set as default if you prefer).
May 03, 2009 | Computers & Internet
Sonar LE: no playback b/c "NO MIDI OUTPUT" selected
You have to go in to the Sonar configuration and select what the default MIDI and WAV input and output devices are. That is usually handled by the ASIO driver. In your case you would select the USB mic for input, and for output you need to select your sound card. For midi you need to configure the midi controllers and the software synth or soft instrument you are using.
If you need any more detailed help I need to know what version of Sonar LE it is and what sound card. I am guessing it detected the mic and just needs the output device configured as I mentioned.
Dec 31, 2008 | Edirol UA-4FX External Sound System
Recording on my Yamaha CP33 keyboard using USB
We're talking about audio recording. If so you must conntect your piano by using the L + R outputs with your sound card or mixer line inputs (that's how I do this). USB is ok if you want to use your piano as a master keyboard (MIDI). Another important thing is that you must have an additional application installed called sequencer ( for example Cubase Sx, Sonar...) which will let you store your digital music. I'm not talking about the proper settings of them because it could take a day or so...:)
Overall, you will have to learn a bit about the home studio, home recording techniques. There are tons of informations on web. A great thing is that you can use your CP33 as a master keyboard to control additional virtual instruments (VST) or for example play different piano samples (check Synthogy Ivory). Possibilites are endless!
May 24, 2008 | Yamaha Full-Size Keyboard
Midi sound prob
ok..try this open control panel->click on sounds and audio on advanced button->If your midi volume control is shown..make sure it is not muted and the midi volume is high..If it is not shown..then click on options->properties ->tick the midi box and close the window..then adjust the MIDI volume..I hope this helps
Dec 01, 2007 | Edirol UA20 USB Audio/MIDI Interface...
Cakewalk SONAR 4 Producer Edition for PC Logo
338 people viewed this question
Top Cakewalk Computers & Internet Experts
Parshiv Luthra
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
