Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Red ,Blue and Yellow lines off,curving inword from top and bottom
How do i replace IC chips in a Panasonic PT-53TW53 projection tv
  • elvispre318 May 11, 2010
    Need procedure for removing the board where the ICs and resistors are mounted. Not having luck with some of the cables or wires from disconnecting especially the one with the boot that looks like the spark plug of a car.
  • 10,594 Answers
Its failure of 2 convergence out ICs and requires replacement.
You can replace these ICs if you have basic electronics knowledge and good soldering experience. let me know to provide you more info about parts.
Posted on Feb 20, 2009
Panasonic pt-53tw53 location of my stk chip
my tv panasonic PT-53TW53G turn on red light on tv no pictur on sound
Jan 06, 2012 | Panasonic PT-53TW53 53" Rear Projection...
Red, Green, Blue curve upwards and cast shadows
that sounds like a typical Convergence IC problem..
http://i.ehow.com/images/GlobalPhoto/Articles/4575598/ConvergenceICs_Full.jpg
this is a picture of what typical convergence ics look like
Mar 12, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Seeing triple red,blue,green
you have proble with the convergences ICs if the tree colors are at fault then also check your power supply voltages the polarization resistors
Feb 08, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53TW53 53 in with bad picture
Sounds like you need new convergences ICs. There are two of them in your set sometimes you can get away with just replaceing one of them but I wouldn't recommend it. They are not too expensive are 15.00 each once you replace them you have to get into the service mode and adjust the convergence.
Sep 19, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Grennish/yellow spots pt-50lc14
I received a new blue polarizer unit from Panasonic. I installed it and it fixed my problem!!!
Duane
Apr 09, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Problems with Panasonic PT-53TW53 53 in. Rear Projection HDTV-Ready Television
sounds like the blue convergence IC is bad.This is quite common in all Projections units about 3 to 4 years old.
Jan 31, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Uh oh... the colors are curved and wacky
replace the amplifier IC chips for the convergence.  part # stk392-???  could be from 040 to 120..  90% chance that'll fix it.
Oct 08, 2007 | Panasonic PT-47WX49 47" Rear Projection...
PT-47WX53 blue convergence
you will need to change or have the convergence IC's replaced I'm afraid. Good Luck
Aug 15, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
128 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
