Question about Food Processors
How do i seperate the housing on a robot coupe processor
I am trying to replace the switch on a robot coupe r2 unit but I can't see how to access the inside. How do I seperate the maroon top from the white bottom?
  • Anonymous Mar 20, 2009
    the red cover broke when the processor fell. trying to fix it myself, since labor is so expensive!!
    Scholar:
  • 81 Answers
There are 4 rubber shoes on the bottom of the white or gray base. Twist & pull these out. With a TORX long shank screwdriver (nothing else works, trust me) there is a screw way down in each hole. After removing the screws a gentle but firm bump should loosen the base. If you ever need to replace the motor, on the top around the drive shaft you will see three round plugs/disks, remove them by prying up with a pocket knife (works best) this will give you access to the three motor bolts.
Posted on Jul 25, 2009
  • Capt Rick Jul 25, 2009
How to remove and install on/off pin for robot coupe r2
Thanks so much for the advice. Any idea what size TORX is required?
Jan 08, 2012 | Robot Coupe R2Dice Ultra Food Processor
Robot chef RC3 lid the little bit on the lid that switches it on is broken.
To valewis46 - is the lid still available as mine has been stick together that many times that it has now bitten the dust. I realise that your offer was made over a year ago but I thought I would ask - just in case. Thanks.
Sep 24, 2011 | Robot Coupe CL50 Food Processor
I have a robot chef food processor it says type RC3 on the bottom the clear plastic top about 20cm dia with the funnel has broken where can I get a replacement part please?
To the person wanting a funnel for her robot chef just bought an old processor on eBay to replace the bowl I've got the lid if you still need it
Jun 26, 2010 | Robot Coupe CL50 Food Processor
I have a Robot Coupe R2 food processor that quite
It just a long shaft phillips screwdriver. The screws are located under the foot pads. They just pull out and then there are the four screws.
Dec 29, 2009 | Robot Coupe R2U Ultra Food Processor
How do I replace the spring on a robo coupe?
Are you referring to the spring in the cutter bowl? You will need to remove the retaining nut. The spring will then come out. the part number for the spring is R1776. Whole assembly part # R242.
Are you referring to the spring in the on and off switch? You will have to replace the switch. If you call Heritage Food Service Equipment, they will be able to fax you a parts break down so that you will know what part is needed. They can most of the time tell you how to replace the parts also. You can contact them at 1-800-253-0200.
Oct 13, 2009 | Robot Coupe R2U Ultra Food Processor
Looking for spare parts for a Robot Coupe R301 Ultra Food Process
Robot-Coupe USA.com should be able to sell you anything needed
Jul 09, 2009 | Robot Coupe Food Processors
Robo coupe CL52D would not turn on
There is a reed swich (safety switch) located on the top where the lid comes down. A reed switch works with a magnet. If the magnet is missing or the reed swictch is bad, no power will be allowed to the motor. Send me your e-mail & I will look up the part # in my Robot-Coupe manual. capt_rick1912@yahoo.com
Dec 16, 2008 | Robot Coupe CL52D Food Processor
Robot coupe maintanance
That plastic piece is a sling disk or sling blade and made to sling product to the discharge chute. Believe it or not, the motor shafts wear out and could be the cause of premature failure. When you install the new sling blade, check to see how much slop/ play there is by moving this back and forth on the shaft, a small amount is ok (1/16th to 3/32nds). The other thing to look at is forcing or overfeeding the unit. You can contact them at Robot-coupeusa.com
Nov 15, 2007 | Robot Coupe CL50 Food Processor
How do I assemble the Robot Coupe R 2 Ultra
Cindy,
Send me your e-mail & I will send you back an exploded view of your Robot-Coupe. It will give all the info needed. capt_rick1912@yahoo.com
Nov 02, 2007 | Robot Coupe R2U Ultra Food Processor
Food Processors Logo
385 people viewed this question
Top Food Processors Experts
Are you a Food Processor Expert? Answer questions, earn points and help others
