Question about Panasonic KX-TG5673B Phone
Base is not receiving any signal.
The phone was working this morning and now I can not call out it keeps telling me "No link to the base" and I have tried everything and I can not call anyone. Is there something I am doing wrong?Need help!!!Thank you.Sincerely,Bridget
SOURCE: Link to Base
unplug both wires at back of base and replug after about 5 minutes - it should work now
Posted on Jan 02, 2008
SOURCE: its saying no link to
I also have no link to base message but only on one of my two handsets. One works the other doesn't.
Any suggestions?
Posted on Apr 30, 2008
SOURCE: GE 900mhz model 26936GE2-C
HI NEED HELP MY PHONE IS SAY NO LINK TO BASE
Posted on Jul 03, 2008
ynotphone
  • 192 Answers
SOURCE: "no link to base" error message
Sounds like the antenna is not working, and signal is not getting to the cordless sets.
Try unplugging your base station (unplug everything; power and phone cable - the basestation were all the cords are plugged into) and leave it unplugged, pull out all the batteries in the phones, and then start by putting all the batteries back into the phones.
Once the phones are back and powered up, plug in the base station again, and see if that helps.
All this is doing is re-setting the phones and base station and forcing them to re-link to each other.
I hope this helps.
Posted on May 01, 2009
ynotphone
  • 192 Answers
SOURCE: My phone says no link to base but I am right beside it.
Sounds like the antenna on the base station is not receiving, or the cordless handset is not transmitting -OR- the sets have never been registered to the base station (please look up registering to base station, if the set has never been registered)
Did the cordless set work before?
The base station or the handset may just have a hick up, I would un-plug the base station and leave it un-plugged... now get all the cordless set(s), and take out the batteries from the cordless set(s). Wait for about 15 seconds for all the power to drain out of the sets, then re-install the batteries.
Once all the cordless sets are back up and working, plug in the base station and wait for about 1 minute.
This forces the base station to re-establish and link between the base station and the cordless sets.
Good luck
Posted on May 11, 2009
No reception
Sounds like the radio in your base phone has quit working. Yes, you can buy another base but it has to be the same model s your existing one. After you get the new base follow the instruction in your users manual to unregister the old handset and then reregister them to the new base. Link to users manual
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1760om.pdf
Jan 29, 2014 | Uniden Cordless Phone
Panasonic KX - TG5664
may be the problem is with the speakers check that first
Jun 02, 2008 | Lands Phones
No Link to Base - - Walk closer to base and try again --
You should try resetting both the base and handset but removing their power supply/batteries and then reconnecting their power supply/batteries. You can also check and see if there is a registration option on the handset that will re-link it with the base. Could just be broken though!
Jan 08, 2014 | Panasonic KX-TG2740 Cordless Phone
A key symbol on the left hand side of the phone is blinking. I'm unble to make a call,its telling me that no link to base. move closer to base, Try again. All the phone cords are in the socks and...
The key symbol is supposed to be an antenna.
It can't receive a signal.
There are a few possibilities:
- Too far from base. Move closer.
- Base is unplugged (no power at base station)
- Phone has become unregistered (unlikely).
If you need to re-register the phone, the process will vary depending in the model of the base station and will be covered in the manual.
Apr 05, 2011 | Panasonic KX-TGA101S Cordless Handset
My cordless phone is not functioning properly.I get consistent disturbance in the background while talking on cordless.Please help me remove this noise.
This can be due to poor meshing of the base and handset , a poor signal strength that tends to pick up stray EMI signals. Make sure that the antennae of the Base phone is tight and up . Check the voltage to the base phone - if adapter is faulty.
Also check the handset for any loose fittings on the antennae.
If the problem does not resolve then you need technical help to check if the operating frequency or the signal processing is weak and faulty on the base unit. Best you can remove base unit and look for any loose links in RF section or shielding faults in this section that picks up stray signals.
Jan 22, 2011 | Audio Players & Recorders
I hope this helps.
May 01, 2009 | Lands Phones
Phone line gets glitched and phone gives one very short ring with error message on readout.
phones not working people are trying to call they tell me there getting a busy signal and cant get through me. I have three motorola E51 cordless phones and they are showing parallel set on the lcd screen how can i get my phones back working
Nov 18, 2008 | Motorola Mobility E51 MD7151-3 Trio...
PANASONIC KX-TG2431 CORDLESS PHONE
The handset is away from the range of the base. Keep the handset on the base for some time and then try again.
Aug 25, 2008 | Panasonic Hybrid IP 12 Key Add-in Mod use...
Link to Base
Dec 30, 2007 | Panasonic KX-TG2357 Cordless Phone
Panasonic phone
1st) you must identify the ranking order of your handset. Put all your handsets in the main base cradle and it will tell you which phone is your handset ie: (1) (2) (3) (4). (if you are reseting a handset, chose a number that is missing to reset your phone to) Now, with NO handsets in the main base cradle. Hold your phone and press "menu", then key in the numbers 00. Now, don't do anything with your handset just now. Go to the main base cradle. On the bottom, where it says"locator" press the select button until you get the desired phone rank needed. H1,H2,H3 etc... Now, press and hold "call". (The charging light should start flashing) Now, on your handset press the "OK" button on the top upper right corner. Your phone should now be working! If you are still having problems, call Panasonic Customer Service at 1-800-211-7262 for tech support.
Dec 23, 2007 | Panasonic KX-TG5633B Phone
Lands Phones Logo
20 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
