Question about Ultra 1 Bay USB 2.0 External Drive Case
Rock external hard drive can not be accessed by the computer
Hi, I have a Rock external hard drive and have not used much. One day, I attached the external hard drive on a computer and turned the power on. I heard sound of computer found the new device however, it can not show the icon of this removable drive on my computer. I changed to another USB slot and got a warning signal saying 'USB power exceeded' and asking to use another USB slot, but the same thing occur. Anyone can help me how to fix it.
  • The Sot Feb 28, 2009
    Red light on, the drive doesn't show up. Does anyone know who makes this as I would like to see if the manufacturer has a fix or suggestions as to a fix?
  • Christoloco Mar 13, 2009
    Recently bought the Rock 500g external drive. It worked alright while I stored all my files in it. Then one day it simply ceased to work. It just makes a slight clicking noise, the computer does not recognise it, or even realise there's something connected to it. I read somewhere that this external drive might work with a pc but not as well with a laptop but I only have a laptop so cannot confirm. No real information or support on the web. Any suggestions anyone?
    Thank you
2 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: Rock Mobile external hard drive was accidentaly dropped
Well it has been cause a mischief that's for sure. Try dismantling the case to check the connectors but that is about all you can do - if the drive is done then it stays done there is no repair option
Posted on Jun 02, 2007
Files from a back up
You should be able to plug the external hard drive into the new computer and restore. Generally the drivers needed to access the external driver are on the external drive itself. The operating system will detect the hard drive (if it has plug-and-play services running). If the new computer fails to see the external drive, check the cable and download the driver manually from the manufacture's website. If the drive is recognized by the operating system, but you do not see a prompt to restore from the backup, you may need to locate a setup program on the external hard drive to start the restore process.
Apr 18, 2014 | Computers & Internet
Question about retreiving data from external hard drive.
There are no problems hooking a external hard drive to any computer. If you mean take the hard drive out of the external case and putting it inside of your computer with a SATA cable, you can do that to. If your worried that they are both Western Digital, there are no conflicts with that either.
Good Luck
Dec 07, 2013 | Western Digital Computers & Internet
Can i attach an external usb hard drive to a toshiba lcd tv
The usb external hard drive was designed to work with windows operational system giving access to all the files, attaching the hardware would give limited use at best and may not respond.
Apr 22, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a 320gb toshiba external hard drive, i've been using it around 3 years without any trouble. A few days ago i lost the cable connecting it to the PC. I bought a few cables but no use. Doesn't...
This is because there is a connection problem between the external drive and the computer. If you have changed cables to no avail, you can open the casing of the external drive where you will find the hard disk inside. Unplug the two cables connected to the harddisk and replug it after a minute. Then try again. If it still does not work, then you need to buy just a usb enclosure and plug the harddisk there to be able to use it again.
Hope this helps. Thank you for using FixYa.
Jan 13, 2011 | Toshiba 120GB USB 2.0 Portable External...
My new computer can not recognize my iogear GHD 335C external drive . I had it for three years, nothing happened to it . I hear a spinning disc noise . The lights on the drive are on and I can't remember...
first check the usb port of your new computer for which you are connecting the drive .The noise comes when the drive is read mby the system .Please try with different usb port and even then if it is not working there is some problem with the drive
Mar 07, 2010 | IOGear ION (GHD335C160) 160 GB Hard Drive
Hi! I have a Rock Mobile External 250gb hard drive that I have reformatted for my MacBook Pro computer. I have used it for about 6 months now. One day I noticed when I turn on the power it took longer and...
Its in your logic board controller issue, usually the problem is like that but to see what is the another problem of your External Drive is to make or use any diagnostic freeware program to identify the device where it really connected in your PC. I have also encountered like your problem but I send my External to Electronic Tech to check the power connection and controller connection going to PC. Because you said that the hard Drive is still have a normal sound then it is working then but cannot see in your Computer. Try to Diagnose first before you bring to a Technician. Good luck!
Jul 29, 2009 | Computers & Internet
My western digital Passport 320Gb usb drive is not detected
hi ,
looks like u primary hard drive is inside the laptop and so should be displayed as c : drive ,
and the reason , the external hard drive is not displayed seperately is csue ., the external HD  may be added as slave to the internal HD .,
can u tell me ,make a right click on c:/ drive and choose properties : and tell the totalsize dispalyed
Jul 23, 2009 | Western Digital Passport WDXML800UE...
My external hdd used to be reconized and accessable by my computer but after several uses all it does is make a buzzing sound. My computer will not reconize its presence until after it is shut down.
Hi
Its not a software issue with your computer or external hard drive but a hardware issue with the external hard drive. You'll need to get your Iomega hardrive checked from Imomega, hope its under warranty. You can reach them at--
External Hard drive iomega support
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 04, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Drivers?
hi Lpw47;
can you please remove you external hard drive and see if you still get the problem?
pls post back, thanks
Jun 03, 2008 | Computers & Internet
Jun 02, 2007 | Ultra 1 Bay USB 2.0 External Drive Case
Ultra 1 Bay USB 2.0 External Drive Case Logo
127 people viewed this question
Top Ultra Computers & Internet Experts
just-ice
Alun Cox
ed_coyle
ed_coyle
Are you an Ultra Computer and Internet Expert? Answer questions, earn points and help others
