Question about Philips 42PF7320A 42 in. Plasma HDTV
NO picture Red led flashes 7 times
  • 335 Answers
TV has an internal problem and needs to be serviced, see if its still under warranty....
If not I can repair it at my shop....
Posted on Feb 20, 2009
  • Circuit World
    Circuit World Feb 21, 2009
    When the led flashes a certain number of times it tells the technician what circuit is at fault causing a problem resulting in total shutdown. There are no secret codes or methods to get your tv back up and running without having it repaired "SORRY". On Philips models a 7 flash window indicates an under voltage within your power supply circuit. This means there's a Op-Amplifier, high wattage resister, Power-IC, Diode, or NPN-PNP transistor that has developed an internal defect and needs to be replaced. Keep in mind that these TV's produce alot of heat and so the components on the circuit board are prone to thermal breakdown over time. I can show how to fix this problem if your willing to cooperate with me and follow some steps.
    My answer is not inappropriate, your tv needs to be serviced. Period!
    GOOD LUCK!
PT54DL50
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic faults
These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Dec 09, 2013 | Televison & Video
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
I get a red screen and then it goes black no picture i get sound just no pic the red led light blinks 7 times
In most cases on these models the red crt is shorted and causes the set to go into a shutdown mode and flash the timer light 7 times. The part number for the red crt is 8-733-664-25 but is no longer available.
Nov 11, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
No picture/sound
I saw this thread on fixya which might help:
http://www.fixya.com/support/t576215-philips_42pf7320a_37_dead
Feb 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF7220A/37 42'' TV (LED flashes red 7 times)
Five buck solution; If you have any tek skills at all and are feeling adventurous; UNPLUG THE POWER, remove the back panel; You will be faced with the mainboard. In the lower right quadrant you will see two small capacitors, like tiny yellowish coke cans. If these are bulging, there lies your problem. These must be replaced. If you have no soldering skills, take only the mainboard to a fixit shop and have them solder in the two capacitors easily found on line. No guarantee's but worth a try
Dec 06, 2008 | Televison & Video
TV does not turn on/red led flashes 7 times in front
this is common issue with this model and through your troubleshooting is tied to y main board. blinking led on logic main in normal operation. when replacing y main always good idea to replace y upper and lowe buffer boards as they complete a circuit and sometimes replacing one without other could cause additional failure on remaining boards
Aug 10, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Philips 42PF7320A 42 in. Plasma HDTV Logo
107 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
