Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
My printer is all of a sudden saying it is not online.
I have gone into the control panel and it is checked off as default printer. My USB cable is plugged in and the printer is turned on. It will copy just won't print anything.
Printer is ESP7 All-In-One Printer
  • Kodak Master
  • 13,433 Answers
Hey,
the printer doesn't seem to be installed properly.
Would you like me to solve this over remote support?
open the link to start a remote support session
http://www.fastsupport.com/441884749
Posted on Feb 20, 2009
  • Ekse Feb 20, 2009
    Hello? The above link will function for around 1-2 hours. I feel this is the easiest way to fix your problem.
    let me know if you have any questions or if you would prefer to go text only? Please use the ADD a Comment button at the bottom todo so.
  • Ekse Feb 20, 2009
    Hi again,
    I see you have rejected to join the session.
    To solve this issue with text only.
    First start off unpluging the printer from the computer usb port. Open up printers and faxes. Start -> printers and faxes, on some computer start -> control panel -> printers and faxes.
    Right click on your printer and select uninstall.
    now with the printer removed. turn off the computer and plug in the printer and turn the computer on. ones windows is started it will ask to install the printer again, drivers should still be installed on the computer so just click next next next and it should install automatically.
    now if the printer has installed, try printing a test page.
    Open up printers and faxes again. Right click on your printer and select properties ones there click on print test page.
    Does the test page come out?
    Remote support is still open if you wish my assistance.
    Thanks,
    Ekse
Message says printer is offline
Sounds like your usb connector or cord. When you change the printer to a different usb outlet you may have to go to control panel and select the printer as the default printer. Always use the same plug if it works good.
Nov 24, 2013 | HP LaserJet Pro P1102W Printer
Everytime i go to print something it says "printer not responding" the status shows online, and turned on. I put the disc in again to try to install it and it dont even pop up on the computer?
If your printer fails to respond to a job, check that all printer cables are connected properly and be sure that the printer is turned on. If everything is connected properly and powered up, go to the computer's "control panel" from the "start" menu. Choose "printers" and be sure that your printer is selected as the default. If everything checks out in the control panel, right click on your printer icon and select "properties." Click on the "details" or "port" tab and make sure that the correct port is checked off. Next, double click on the printer icon, which will bring up a list of current jobs in the print queue. Cancel all documents and try printing again. If your printer is attached by USB port, you may try connecting to other USB ports.
Good luck, KoBaC
May 22, 2011 | Computers & Internet
Printer says offline how do i get it back online
Assuming that you have windows Operating system
1. Click on start go to control panel and under that Printer and other hardware >> you will see an icon of your printer ..right click on it and then click - use printer online
This will help you.
If it does not then check whether the USB cable is properly connected or not, unplug it from the USB port in computer and plug it back in a different one.
If this also does not help you
Then try some other USB cable
Apr 23, 2011 | HP J3680 Officejet All In One Printer
I bought an HP Deskjet F4400 printer for college and it keeps saying the printer is offline. I have a Macbook Pro, so there's no "Control Panel." I looked under "system preferences" but was unable to right...
its likely the printer port that the printer is assiged to. I assume its plugged in via usb. power on the printer, then connect the usb cable. go into the printer properties, look for printer port. do not use LPT1 LPT2 or Com anything. make sure printer port is set to the USB port. Its a mac so it may be tricky to find. Quite often these printers set to LPT1 by default which is incorrect on a USB printer. good luck.
Aug 25, 2010 | Office Equipment & Supplies
Printer's "offline"
go to your printer folder, mine was here " Control Panel\All Control Panel Items\Devices and Printers "
Right click on your printer and click on use printer online.
Also make sure that your printers usb cable is plugged in properly
Jul 13, 2010 | Computers & Internet
Windows doesnt idemtify it
Try this.
Go to your control panel and then to Printers
Right click on your printer and select Put Online. See if that works. If not do let me know so that we can research further.
May 14, 2009 | Canon MX300 Office All-In-One Printer
Printer message says it is offline
Hi
Kindly check the usb cable if its fine then try going into control panel open printer and faxes option & set your printer as default .
Thanks
Jan 03, 2009 | Brother HL 2140 Laser Printer
Printer stopped printing and says its off line!
HI,
Im Rizwan from India, i would to tell u to check few things that will resolve this problem
SOLUTION:
NO 1: Check the Connection and power
1.Check the USB cable and the power line to the printer.
2.unplug and replug the cables at the PC an printer end.
NO 2:Check the printer status in control panel.
1.Click start - >Run.
2.In the run window type "control" (without quotes).control panel will open.
3.In the control panel, look for printers and fax and check the printer icon.
4.If printer icon says Offline, Right click on printer icon and select "use printer online"
5.Try printing, if it didnt print follow step NO 3.
NO 3:Restart the USB Composite Device.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:WE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP DESKJET 720C
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Try printing Now, if it didnt work please response.
Thank you
Rizwan
rizwan84tx@gmail.com
Dec 06, 2008 | HP DeskJet 722c InkJet Printer
Printer is online and says ready but won't even attempt to print
Click on Start,
Go to Control Panel,
open Printer and Faxes
look for the Printer which is HP C5280 or any icon related to same,
Right click
Choose set as default
Close Everything
Shutdown your computer and Printer
Check and make sure that the USB cable is connected propely
Restart the Printer first and then the computer,try Printing some thing.
if this doesnt resolve you issue then i would suggest you to uninstall the printer software and reinstall and update it from HP.com.
Please let me know about the resolution
Oct 25, 2008 | HP Photosmart C5180 All-In-One InkJet...
Lexmark Printer Install - No Communication Error
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Jul 19, 2008 | Lexmark X1150 All-In-One InkJet Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
15 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
