Question about Sony KDL-52XBR5 52 in. LCD HDTV
No sound on left side.
Have a sony kdl-52xbvr5. the left speaker has no audio but has a fluttering sound. Tried connecting the audio output to the audio in of an amplifier w/ the same sound,
sounds to me like an audio card?
  • 3 more comments
  • mjj4golf Feb 20, 2009
    more info:
    if we run the dvd player, the left speaker works fine.
    the speaker works fine w/ dvd player. unplugged for 20 min w/o fixing.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    So TV gives noisy sound in left channel only with cable.
    If you are using cable box, please recheck its settings.
    and if its direct cable, perform "fresh/ new" auto tuning or channel search in TV so it might fix L-Speaker sound issue.
    new update shows sound processor chip is fine.
    please unplug TV for 10-15 minutes and replug back and check sound.
    Yes, seems audio processing chip is defective.
    You should have related service manual to order correct part.
  • 335 Answers
RE-check the audio amp on its own see if this happens with any input device...
Re-check the connections, and be sure your cable wires are all in good condition....and that you have the proper input/output ports correct.
Posted on Feb 20, 2009
Kdl-32v4000 sound
Check the speaker first. Check if there is any sound output comes from the audio out terminals at the back of the TV, by connecting them to any external audio out devices; such as an amplifier or so. If there is audio output comes from the external source such connected, and no audio output from the TV; since the speakers are good, the fault is with the audio output section circuit inside the TV. If there is no audio output from the external sources too, the fault is with the audio processing section circuit at the main board. If this is the case, main board is faulty, and should be replaced.
Aug 07, 2012 | Sony Bravia KDL-32V4000 32 in. LCD TV
Sony BRAVIA KDL-40V2500 audio not working
I would Google the model number carefully for "problems" "no sound" and usually this set will display some kind of error code===it may even have a hard reset to try===service manuals are available on the net/web to allow you to see how the sound circuit is set up etc.
Mar 29, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I don't know which port in the back of the Pavilion to connect the black wire from the speakers (that connect to the right speaker with red and white ends). Any ideas? They are labeled as side, rear...
To get "surround" sound, when you face the computer, you will have:
* 2 front speakers, one immediately on each side of the computer
* 2 side speakers, one on each side of your head
* 2 rear speakers, one behind each side of your head
Thus, when the sound is of a jet-plane coming towards your face,
you'll first hear the sound in the front speakers,
then in the side speakers,
and finally in the rear speakers,
to produce a sound-effect of the jet passing over your head, and going "behind" you.
Usually, for "front" speakers, one speaker connects to the other speaker, and the second speaker connects to the "FRONT-audio-output" connector on your sound-card.
For side speakers, one speaker will connect to the LEFT-side-audio-output port,
and one speaker will connect to the RIGHT-side-audio-output port.
For rear speakers, one speaker will connect to the LEFT-rear-audio-output port,
and one speaker will connect to the RIGHT-rear-audio-output port.
Jun 01, 2011 | Audio Players & Recorders
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
Connecting speakers.
The speakers cannot be connected directly to the audio outputs. These outputs are for use with an external amplifier. Connecting speakers directly to these audio outputs can cause damage to the set. Thanks
Oct 24, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
The left side main output won't put out any sound on my Denon AVR-900.
connect your right speaker cable to the left output, if the sound comes out then the problem is on the left speaker ( the cable or the speaker itself ), but if still no sound, then the problem is on the power output of the unit, need to repair them
Oct 20, 2009 | Denon AVR-900 Receiver
Problem using headphones 3.5mm output with Sony Bravia tv
Just mute the TV and you will get sound out of your headphones. You may have to turn the TV sound up though.
Sep 09, 2009 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
Trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Aug 25, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
How do i hook external speakers to sony bravia television
The proper way to do this would be to use the audio output from the TV, either analogue left and right or the optical port, and send it into an dedicated amplifier or AV receiver. You can then use the amplifier or receiver to power the external speakers. If you are using a dedicated amplifier with no volume control you will want to change the audio output setting on the TV to "variable out" as oppose to its current "fixed out"settings. You can find this in the TV menu, usually under the audio settings. This will allow you to use the current TV remote to adjust the audio volume coming out of the external speakers.
Aug 21, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony KDL-52XBR5 52 in. LCD HDTV Logo
56 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
