No picture when I plug in mt TV a green LED shows then is replaced by a RED led that flashes 7 times & repeats the flashing
  • 530 Answers
Hi im josh in cebu phils. may i suggest. friend i encountare the same problem of yours before. the problem is the power supply that supports the main board and the pic tube. change the power supply.cause the current that flows is insuffecient to make your tv work. good luck
Posted on Feb 21, 2009
  • 537 Answers
What is the manufacturer/model number of the TV? This would be helpful in troubleshooting your issue.
    Sergeant:
    Champion:
  • 239 Answers
Try to work with the control remote
  • 217 Answers
7 blinking code Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
  • Saroj Sharma
    Saroj Sharma Feb 21, 2009
    It would be much helpful if you specify the TV brand and model.
  • 547 Answers
What type of tv?
  • 2 more comments
  • albert getty
    albert getty Feb 21, 2009
    have you pulled it apart ?
  • albert getty
    if its under warrenty take it in best bet thank you for useing fixya if you need manuel go here http://www.repairgroup.com/PlasmaRepair/...
  • albert getty
  • albert getty
    Purchased the above new Freesat TV (which is visually great by the way) and had barely used it for a week when it decided to give up the ghost!!
    This is what happened :
    I powered the TV off using the remote, remebered i needed to change something on Sky+, and so powered it back on again (once again with the remote) about 5 seconds later. All i got was 7 red blinks from the power LED on the front, a short pause, then the 7 blinks again....etc. This just continued in a cycle.
    I then unplugged it from the mains, waited over night, powered it on from the front using the power button. The power LED then flashed green rapidly (for about 2 secs), made a clicking noise and then went back to the 7 red flashes, pause, 7 red flashes.............etc on a loop.
    I have since googled this and it looks like its a power board/circuit problem that will need a qualified technician call-out to resolve!!
    Not happy after spending over £1250 on a product that i thought would be reliable.
    Purchased it from John Lewis, so will take it up with them and keep you posted.
    Had to post this thread to make people aware of a potential issue here, which hopefully only affects a small batch of these TVs'.
  • 13,433 Answers
The problem / symptom you are facing is a protection mechanism when a fault is detected the tv goes into protection mode and displays a error message in this case 7 blinks.
First I would suggest to check your warranty
2nd, you will need a service manual which includes the list of codes and explanations of them.
I have to warn you, its not recommended attempting to fix a tv at home. Do you have previous experience?
what is the brand and model of your television and I'll see if you a service manual is available.
NO PICTURE OR SOUND ,GREEN LED STAYS ON FOR 10 SECONDS THEN A RED FLASH . PROCESS REPEATS ITSELF
Hi
You have to check how may time that led flashes. check the link for more details about led blinking in sony bravia tv.
www.electro-medical.blogspot.com
Mar 18, 2015 | Sony KDL-40XBR4 40 in. LCD HDTV
PT54DL50
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
TV does not turn on/red led flashes 7 times in front
this is common issue with this model and through your troubleshooting is tied to y main board. blinking led on logic main in normal operation. when replacing y main always good idea to replace y upper and lowe buffer boards as they complete a circuit and sometimes replacing one without other could cause additional failure on remaining boards
Aug 10, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
