Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
110,000 btu all-pro heater 2years old ,runs 2 mins and cut off ,cleaned filter,didnt help
  • 193 Answers
Take off rear plastic filter end cover. check very close for hair line cracks and make sure that plastic rib that seats around cork portion of gasket is not warped
Posted on Sep 25, 2009
It starts up good then stops and a big cloud of smoke comes out. Got a new ignighter (50$) but still doing the same. can you help me? You could have an air problem. Take the cover off the heater and see if it runs ok, if it does then you have an air problem, check for bad lines or cracked housings
Oct 16, 2014 | All-Pro Kerosene Garage Shop Heaters - All...
Reddy Heater kerosene 110,000 btu . plup it in, fan runs, blows smoke out the front, leaks kerosene also from front, i have cleaned photo cell, replaced plug, cleaned filter and checked lines for cracks,...
Just because there is fuel & spark does not necessarily mean there will be combustion. The fuel must be delivered at the correct pressure, the correct volume, and must be delivered as a fog- not a mist.
My suggestions:
  1. set the pump pressure
  2. be sure the fuel filter is clean
  3. be sure no air leaks or vacuum leaks
  4. Desa recommended annual replacement of the nozzle. They wear out. When was the last time yours was changed?
More troubleshooting tips
Oct 20, 2011 | Reddy Heater-30-55,000 BTU Variable
Fan starts no ignition then cuts off
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
Jun 08, 2010 | Reddy Heater-75-125,000 BTU Variable
Motor went bad in a reddy heater pro 110 110,000 btu
The manufacturer is online at . If you go to that website you can find part distributors. I hope this helps you!
Feb 01, 2010 | Reddy Heater-30-55,000 BTU Variable
I have a Dayton 110,000 BTU need back plate
Look up Grainger or WW Grainger on the web they should be able to help you find the part.
Jan 06, 2010 | Dayton Gas Furnace Heater
An All Pro 60000 btu kerosene heater.
The fuel filter is clogged you need to clean it. Mine was doing same thing, easy fix.
Jan 05, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Ready hater 110,000 btu
replace the nozzle and check the fuel filter - if this is a kerosene heater. under the access plate is a round filter - remove it completely or change it.
Dec 18, 2007 | Reddy Heater-30-55,000 BTU Variable
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
481 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
