Question about Nikon D80 Digital Camera with 18-135mm Lens
Nikon d80 won't expose sometimes on start up
When I turn on my D80 set in the Auto or P mode, I can't make the camera fire. When I first bought the camera, it would fire immediately on start up. Now, I seem to have to focus on a close object and make it fire once before I can proceed
I had the same problem, more often than not it wouldn't focus or shutter release, seemed to be lens to body contact problem so I sent the camera back to Nikon UK. They returned it "repaired" but the fault came back. Went back to retailer (Jessops) and they exchanged for new camera after nearly 12 months. So far so good!
Posted on Mar 02, 2009
    Problem Solver:
  • 5 Answers
It almost sounds like your lens is not solidly on the body. I remember having a similar problem with a lens. Try starting the camera on A or S priority mode and see it you still have the problem. And check the lens mount.
Posted on Feb 26, 2009
Nikon D80 won't allow use of auto ISO
Hi kathlag96, page 43 of the manual state that Auto ISO works in the Vari-Program modes. Page 88 item 7: explains Auto ISO does not work in the P, S, A, M modes
Jun 07, 2010 | Nikon D80 Digital Camera with 18-135mm...
Nikon d80 buttons malfunction
Is there any chance that the symptoms are different when you are in Auto, M, S, or P?
Jan 08, 2010 | Nikon D80 Digital Camera with 18-135mm...
My D80 nikon camera was not working specially on
Check the following:
- Make sure your lens is screwed on correctly. Try to remove it and put it on again.
- Make sure the dial is squarely pointed to Auto
- Make sure the Auto-Focus switch in front of the camera is turned to A (not to M)
Dec 29, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon d80 will not take a picture the letter r flashes
your subject maybe very near that's why the auto mode prevents you from closing the shutter. R just stands for remaining images in the buffer.
Dec 28, 2009 | Nikon D80 Digital Camera with 18-135mm...
My nikon D80 built-in flash not work in TTL mode
It may be sensing enough light at your location so the flash does not fire. If you want to force it to fire, make sure the flash icon is selected and also use Auto mode to test
Nov 27, 2009 | Nikon D80 Digital Camera with 18-135mm...
My D80 will not auto focus with any of my 3 Nikkor lenses. It will fire on auto focus when you manually focus while in that auto focus mode.
Press the AF button on the top of the camera (to the right of the window) to select an AF mode & make sure the M/A (Manual / Auto focus) switch on the lens set to "A"
More info below:
http://www.kenrockwell.com/nikon/d80/af-settings.htm
Oct 05, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 - Singe Focus Area
once you have your settings, is there an option in the menu to save your profile? ( I do not have a Nikon DSLR..) If you can, try saving your profile and then restart again.
"Auto" modes generally are designed to reset to the pre-defined automatic settings, so it may not be possible to keep your changes every time.
Also, you can update the firmware, however there is no mention of any changes which should affect this issue.
http://support.nikontech.com/app/answers/detail/a_id/16091
Aug 31, 2009 | Nikon D80 Digital Camera with 18-135mm...
Dark photos
  • Be sure camera is set to the Green auto, not the A (A= aperture priority)
  • Be sure your white balance is on auto.
  • Be sure your EV is set to 0
  • Be sure your lens is on M/A, not M
  • Check the internal meter. See if it is showing a middle of the graph reading when the camera is on auto. If it is and you still get dark pix, might be time for Nikon repair.
Mar 12, 2009 | Nikon D80 Digital Camera
Consistent under exposure
Under exposed should be minus not plus number.
Lucky you didn't buy Canon 5D or 1D- they have focus and exposure problems.
Hope you are not using the pop flash that is on the camera. If you are, then turn off the Red Eyes Modes.
Set camera to manual mode and lower the F number(open up to half or one stop).
What studio lights are you using? Increased the light output of studio by those number and shoot like you normally do.
atdlee@netzero.com
Dec 11, 2007 | Nikon 20MM F2.8 AF NIKKOR Lens
Nikon D80 Digital Camera with 18-135mm Lens Logo
95 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
