Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
Polaris rmk 500 backfires when it gets hot then won't start
Ok this sounds like a similar problem that I have had with a 500xc engine...This engine has been running fine for the last 5 yrs until a few weeks ago when it became a pig to start and when it did only run on one cylinder eventually running on both and when it gets to a certain temp would cut out and then not start again for 5mins, changed everything we could think of, checked compression, barrels fine, carbs clean new cdi, coil, plugs, leads, fuel pump and pipes, then someone came accross with checking the resistance on the temp sensor on the top of the head which were different values to the the book and on another identical engine, I borrowed a spare sensor and although still a pig to start it was an improvement when running, need to buy a new sensor to rule it out
, can anyone else shine some light on this?
Posted on Sep 04, 2009
    Problem Solver:
  • 12 Answers
Im guessing its a blow piston it could be an antifreeze issue check the thermostat it should be on the head of the engine just remember to tighten the new one to the correct torque specs the back firing sounds like a blown piston check your compresssion
Posted on Aug 14, 2009
I have a 1998 Polaris Sportsman 500 ATV that won,t idle and backfires. Chuggs when idiling, Starts hard, even with choke. Hitting the throttle makes it die out
Could be a vacuum leak in the intake tract. Try spraying carb cleaner with the straw that come with can around the intake and carb area. If there is a leak, engine speed well change.
I
Oct 28, 2017 | ATVs
Start up idle is slow below 1050 rpms and sounds like going to stall while idling. Runs fine otherwise.
How to adjust your Polaris Snowmobiles TPS. - YouTube
? 6:05
https://www.youtube.com/watch?v=aEPx7OsywNk
Dec 11, 2009 - Uploaded by PolarisRich
A quick video on how to adjust your Polaris Snowmobiles Throttle ... TPS cause this? it seems like it hits top rpm, it runs flawlessup to the ... Would this work on a 2011 Polaris pro rmk 800?? ... I have a 2006 Polaris Fusion 600 h.o. It seems to bog out when u first start ... Sounds like its a carb or clutch issue!
2011 Pro RMK 800 Top End Bogging [Archive] - SnoWest Snowmobile Forum
www.snowest.com/forum/archive/index.php/t-298871.html
Jan 30, 2012 - 52 posts - ‎33 authors
[Archive] 2011 Pro RMK 800 Top End Bogging Polaris: Pro-Ride. ... Sled is a 2011 ProRMK 800 155, 1700 kms, MBRP can. ... problems with bogging at every rpm and roughidle, I am running 91 from .... fuel filter yet?...almost sounds like your fuel pump can't keep up with ..... I am running a 2010 660 CFI-4. 2010 dragon 155 RMK electrical problems
Feb 3, 2013
Polaris update
100+ posts
Nov 15, 2009
~~The Official Phazer Thread~~
100+ posts
Sep 12, 2009
M1000 Hiccups on the Bottom
100+ posts
Jan 28, 2008
More results from www.snowest.com
Jan 12, 2016 | Polaris 2010 RMK 800 Dragon 163-Inch
Why would my Polaris snowmobile overheat?
My sled overheated - HCS Snowmobile Forums
www.hardcoresledder.com > ... > Rush/Switchback (Pro-Ride Chassis)
Jan 6, 2013 - 12 posts - ‎3 authors
Hey guys, I was out riding my sled yesterday, and out of no where, it threw a code, and it went into limp ... I would be worried about where did the coolant go? ... (Knowledge + results / corrected HP)Polaris + Als input = WGAF ... overheating
Feb 23, 2013
05 Polaris Switchback 800 overheated
Dec 23, 2010
Overheating...
Dec 23, 2008
2001 xc 600 overheating
Nov 29, 2006
More results from www.hardcoresledder.com
02 800 rmk overheating - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris-snowmobiles/67778-02-800-rmk-o...
Mar 4, 2012 - Does anyone know where I can get free service manuals for my sled so ... for a 05 polaris edge touring but i have used it to fix my 02 edge 600. Edge 600 overheating
Jan 2, 2013
Snowmobile Overheat Problem :( F8 LXR
Jan 16, 2012
2000 touring 600 overheating
Jan 13, 2011
need help with overheating issue
Nov 20, 2005
More results from www.snowmobileforum.com
800 Pro RMK, overheating, coolers... a
Jan 01, 2016 | Winter Sports
My 2013 pro rmk 800 is backfiring when I press on my gas ! Then works fine after that.
Check for a Blockage in your Air Intake System. Mice Love making new homes in Air Cleaners... You are NOT Burning the Fuel, so either you have un-burned fuel so maybe you need to back off the Needle JETS but check your Air System First
Jan 02, 2015 | Polaris 2013 PRO-RMK 800 155
Reverse on my 2007 rmk is going into reverse on its own and toggling back and forth from fwrd to rverse winthen seconds wat shuold i be checking ?
My 07 RMK 600 did the exact same thing after a VERY wet ride on the sled deck. after i let it dry out it, then next trip we made it seemed to run fine.
were you able to identify the problem on your 07 RMK?
Jan 31, 2011 | Polaris New Genuine Polaris Snowmobile...
Polaris rmk mtn bike or victory vegas low mtn bike. Which is a better buy found them both for around the same price
The Polaris RMK and Victory Vegas Low are the exact same bike with different colors and names.
They are made by Ming Cycle in Taiwan and are distributed by an American company-----Cycle Force Group.
The Polaris and Victory are Ming's top of the line dual suspension mountain bike, they have upgraded wheels, front disk brakes and 19" frame. If color doesn't matter to you, then the Victory Vegas Low is usually the better deal.-------Can be found on Amazon, Wall mart, Miejer.
The Polaris and Victory generally have the best reviews and ratings of any dual suspension mountain bikes priced below $250
May 13, 2010 | Victory VegasLow 26 Men's Dual-Suspension...
2005 polaris 500 stalling
Yes, yes, and yes. Begin by installng new spark plugs. Also, a new air filter, and finally put carbeurator cleaner into your fuel tank, usually one ounce per gallon. You can purchase these items at any auto parts store. Bring the old plugs and air filter in so u are sure to get the correct ones. Finally, charge up your battery.
Jul 04, 2009 | Polaris ATV
2000 rmk 600
You may have a sticky exhaust valve due to carbon build up on the stem.
Aug 26, 2017 | Polaris New Genuine Polaris Snowmobile...
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
516 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
Bill Boyd
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
