Question about 2wire 1800HG Router (RG1800HG00)
Dont know how to reinstall all the wires
I had change my cable but decided to go back to my old cable and now i dont know how to reconnect my phone, cable, and internet wires back correctly.
  • 136 Answers
You will have one RJ11 slot on the router with a Phone symbol
Connect your phone line to it
You will have a RJ45 slot ( a bigger phone cable slot) named ethernet
Connect your internet wires to it
You will have a Round slot to connect the Cable to it
Connect your cable to it
Posted on Jan 26, 2010
95 buick regal custom speedo issues
There is a gear that drives the sensor gear much like the old speedo cable gear.
If you connected the sensor and the check engine light went off, chances are the sensor is working.
Jul 04, 2013 | Cars & Trucks
I cant hear from the earpiece, but im able to hear on the speaker. i think its a wiring problem, can i open and fix it myself? dont want to send it for repairs, have had bad experiences with phone repairs...
Plug it in and move the cable starting from the plug, making sure that you only move part of the wire. if it's a break, you might find the break and get the sound back while holding the wire in a certain way, which means that you'll have found where the break is. Depending on the location of the break in the wire, you may open the actual headphone and use a clip to hold the wire and resolder the wires (usually touch the end of the wire to the soldering gun and melt the shield coating away, dip in to flux and then to the mini board.)
If in the wire, carefully slice (lengthwise) into the wire (use any extra wire you might have to reconnect the old) then split electrical wire to seal the old wire. The Use the extra to secure the hold.
Thanks and have a nice day.
Jul 01, 2011 | Sony Ericsson W910i Cellular Phone
How do I remove the valve cover in order to service lifters?
This si the solution for a gasket replacement, and you will need it when you remove the old ones.
  • Right Side
    • 1
      Disconnect the negative battery cable. Remove the accessory drive belt. Using a 9/16mm wrench, loosen the power steering pump bolts, then slide the pump forward. Do not remove the power steering pump. Remove the power steering pump braces.
    • 2
      Disconnect the spark plug wires. Using a 9/16 mm wrench, remove the valve cover bolts. Lift the valve cover to remove it. Using a flathead screwdriver, gently nudge and remove the old valve cover gasket.
    • 3
      Clean the gasket seating area using automotive engine cleaner and a clean cloth rag. Make sure that all debris is removed. Place the new gasket into place. Apply gasket sealant and place the valve cover back into place.
    • 4
      Tighten the bolts securing the cover into place using a torque wrench. Reconnect the spark plug wires. Reinstall the power steering pump braces. Place the power steering pump back into position. Using a 9/16 mm wrench tighten the bolts that secured it into place. Reinstall the accessory drive belt.
    Left Side
    • 1
      Ensure that the negative battery cable is disconnected. Locate and remove the accessory drive belt. Using a 9/16 mm wrench, disconnect the bolt attaching the alternator to the brace.
    • 2
      Remove the brace to gain access to the additional parts that will be removed. Disconnect and remove the spark plug wire harness. Using a 9/16 mm wrench, remove the bolts securing the valve cover. Lift up and remove the valve cover.
    • 3
      Use a flathead screwdriver to gently nudge the old valve cover gasket to remove it. Do not scratch the gasket seating area when removing the valve cover gasket. Make sure that all debris and particles are removed from the gasket seating area.
    • 4
      Place the new gasket in the gasket seating area. Using a torque wrench tighten the valve cover gasket bolts. Reinstall the spark plug wire harness. Put the alternator brace back into position and tighten the bolt that secures it into place.
    • 5
      Reinstall the accessory drive belt. Reconnect the negative battery cable. Add oil to the car and start the engine. Allow the engine to run idle for 10 to 15 minutes. Drive the car a short distance to check for leaks.
  • Mar 16, 2011 | 1999 Oldsmobile Silhouette
    I've had this HP printer for years with no problem using it most days. just plug it in when i want to print. but for some reason it has just decided that windows does not recognise this USB device. i have...
    Disconnect the power cord from back of printer
    Disconnect the USB cable from PC
    Turn off your PC
    Disconnect the power cord from wall outlet
    wait for 10 minutes
    Reconnect the PC Power cables
    Power on the PC
    When you see the PC desktop
    Re-connect the Power cable to printer
    Re-connect the USB cable of Printer to PC
    This should resolve your issue
    Sep 25, 2010 | Office Equipment & Supplies
    I have the solenoid switch but i dont know how to change it. to a ford expidition 2000 5.4l
    it will be located near the battery, follow the positive battery cable to the solenoid, disconnect the negative(black) battery cable first. remove the wires from the old solenoid, remove the bolts the hold the solenoid to the firewall or fender wall, install new solenoid into place then reconnect the wires. last reconnect negative battery cable & test repairs. make diagrams & mark wires as needed to avoid other problems
    Oct 11, 2009 | 1999 Ford Expedition
    The hood release is broken on my 95 buick century and i ant open the hood any more even using plyers to pull the wires im sure i need to replace it or somthing but dont even know how to go about that if...
    I think you should be able to get your hood open if you can get your hand up to it, I think that you can actually trigger the latch at the actual cable connection lever to get it open. Replacing the cable is a piece of cake. Remove the old on inside and remove your latch and disconnect the cable from it just goes in a groove, pull your old on out but attach a long piece of soft wire pull the cable out from inside the car. You may have to help to get it through the fire wall. after you remove it, attach the wire that you pulled through and tie it securely to the new cable, have some one help you and slowly work the cable back through and route it back the same way the old one was, reconnect to our latch and install latch exactly in the same place it was when you removed it, you should be able to tell by where the old bolts had been . Hope this helps you! God Bless, and Merry Christmas!
    Dec 10, 2008 | 1995 Buick Century
    Telephone wall jack
    Did the old wall jack work before you removed it?
    Are the wires still connected or do you remember where the wires used to go.
    If so, then what I would do, is with a phone connected, start disconnecting 1 wire at a time. When the line goes dead, then you know that is one of the wires that you need to use. Reconnect that wire, and mark it, and Keep doing this until you find the other wire that makes the line go dead.
    Then you will know which 2 wires you will need to get the jack working.
    Usually, the standard color wires that you need for the new jack is Red and Green for a single line phone jack.
    Hope this helps.
    Good luck.
    Mac
    Feb 21, 2008 | Lands Phones
    Confused about Connections
    Bob, you can do this, grab 3 rca cables, 1 yellow 1 red 1 white.
    the holes on the back of the dvd are colored coded, you guessed it yellow ,red, white, plug the cables into the matching colored holes, your done with the dvd player, now take the other end of these 3 cables and guess what the plugs on the back of the tv are the same color code as well, take a flashlight and find the 3 colored holes marked " input 1" stick the yelloe cable in the yellow hole , red in red hole, white in white hole, turn on dvd player & tv, grab your remote for the tv and find the input button and push it until the screen show "vid1" or "video 1", input 1 what ever yours says and you`ll be watching your dvds. Good Luck & Happy Holidays, BMW Rider
    Dec 01, 2007 | Hitachi 57F500 57" Rear Projection...
    Inside phone wiring
    Red and green (2-wires) are all that is typically needed. This does depend on if the other end of the wire is properly hooked up!
    Sep 11, 2007 | Lands Phones
    Changing monitors
    If the video cable will come out of the monitor the connector will look like the one that is connected to the back of your pc on the other end with 2 long screws. If its simply a wire straight in you cant remove it. If you mean the power cable, you will need the same 3 pin connector as a kettle has, or it will have a special connector which normally has a voltage regulator built in the plug
    Oct 25, 2006 | Samtron 76df 17" CRT Monitor
    2wire 1800HG Router (RG1800HG00) Logo
    198 people viewed this question
    Top 2wire Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
