Question about RCA DRC8030N
Can,t Record from VCR to DVD
Don,t know how to set up dvd recorder to record from VCR
  • 27 Answers
Make sure you have your VCR connected to the recorder by either the ANTENNA cable or 3 A/V cords. Make sure the recorder is on whatever output channel the VCR is set on (switch on the back of the VCR) for RF, or that the VCR is set for AV output and the recorder is set for Input 1 for the back of the recorder. You should be able to see a picture on the recorder of what's playing on the VCR. If you got that far, then you should be able to record the incoming program using the menu features of the RCA 8030. I hope this helps.
I need a manual for this machine if anyone has one.
Posted on Apr 12, 2009
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
Hi i got a vhs/ dvd recorder from a friend who upgraded,but dont have a manual,i have set it up to my portable tv upstairs,which has a set top box,but dont really know if i have the cables right. the...
Hello Audrey,
If you can watch the videos on the TV, your cables are correct, but you don't generally record a video to DVD using the record button. Most VCR/DVD combinations have a DUBBING button on the front of the player and/or the remote control for copying from one to the other.
Additionally, some players can only record from video to DVD, some can only record from DVD to video and others will do both. On players that can do both, you need to instruct the player whether you want to record from video to DVD or vice-versa.
If you can le me know the model number of the player, I can let you know which recording options are available on your player, how to record and (hopefully) supply a new manual which you can download and print. The model number may be on the front of the player, but usually these are found on a label on the back of the player.
Regards,
BElectric.
Apr 14, 2011 | Televison & Video
I need instructions to record from vhs video player to dvd recorder
Connect the vcr to the dvd recorder via scart. Set TV to your usual dvd channel and power on dvd. Power on vcr and scroll through input channels (AV etc) on dvd recorder until you find the signal from vcr. Prepare the recorder ready to record, then play the vcr and start the dvd to record.
Sep 20, 2010 | Televison & Video
Record from vcr to dvd
You need to get a set of RCA leads and connect ya Video to your DVD recorder, from VCR Video, Audio OUT to DVD Audio IN. Press play on VCR, and Record on DVD ya should be good to go.
Jan 26, 2010 | Philips Magnavox MDV530R DVD VCR
I am attempting to record from a VCR tape to
I have a Magnavox MWR20V6 and I am attempting to record a Tv show but when I play it back the recording is just black.
Jan 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Electronic ILLITERATE!!! - nothing recorded from cable tv channel
okay, if you have a cable box (cable out plug to dvd/vcr in), then from the dvd/vcr (cable out plug to tv/monitor). make sure tv/monitor and dvd/vcr are set to ch #3. you swith channels with the cable box ,you are not going to be able to record HBO on dvd (but you can with the vcr), any other cable ch(tnt, history, tbs,we, oxygen and more) is recordable w/ both dvd/vcr
no cable box. take cable wire plug to dvd/vcr in, than other wire is connected to tv/monitor
now go to dvd/vcr with remote, menu, set to catv, scan channels. now when you wish to look at tv the dvd/vcr must be on at all times. again you will not be able to record Premium ch like HBO
hope this help............pls feel free to rate
May 14, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Copy Audio Cd into DVD
Best guess...put audio cd into DVD side, Video tape into VHS side. Set the VHS to record in SP, Then record the cd to vhs. then when you are done recording on the vhs, put a blank DVD in the recorder side, and press dubb to DVD to get it to record from vhs to Dvd.
Jun 24, 2008 | Funai FDRV90E DVD Recorder/VCR
Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
Apr 16, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Unable to record vcr while dvd playing
are you trying to record the dvd or tv or cable channels let me know then i can help
Jan 08, 2008 | Televison & Video
RCA DRC8030N Logo
172 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
