Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
I have milky film on glasses and food particales on everything.
I have checked the filter below, and cleaned it, but problem still exists. Help!!
Learn how not to eat like a slob!
Posted on Feb 20, 2009
My new beco dishwasher is leaving a white film on everything. Glass is very cloudy. It has rinse aid and salt in it help.
Is the inside of the dishwasher clean? Have you emptied the filter and cleaned the jets in the spray arms?
Feb 12, 2015 | Dishwashers
We have had this dishwasher for approximately 2 years. Dishes do not clean well. For example, I put a mixing bowl in that I just mixed brownie in--and the bowl did not come clean (simply a thick...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Mar 01, 2011 | GE Profile PDW8480JSS Built-in Dishwasher
Dishes and glasses with a milky colored film
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes
Feb 10, 2011 | Bosch Dishwashers
This is a 3 yr old dishwasher with very gentle use. It now is not cleaning glasses....even when rinsed before hand the glasses are still stained and spotted. Also my silverware needs to be completely...
Hard water stains are easily taken care of with the help of vinegar. Add 1/4 vinegar to the cycle when you start it and it will help to remove spots and cloudiness.
As for food residue you might check your filters and water pressure.
Oct 30, 2010 | Kenmore 13863 Stainless Steel Dishwasher
My electrolux icon dishwasher leaves food residue in the interior of glassware and mugs. It has etched and left milky scratching permanent texture to all glassware. I have replaced glassware change...
heatman101
Mar 10, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Dishes are no longer cleaned properly. They have a white milky film BUT if hard water is the problem, why were they coming out perfect for the past 8 years?
If the film is only on glass. wash the glass with a citrus cleaner, if they get clean then your glass ware may have been etched by your had water and the detergent from your dishwasher is staying in the etched glass.
If this is not the case, then your dishwasher might not be getting the proper volume of water, witch will decrease the pressure of the wash arm or your spray arm might be dirty.
Jan 08, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Glasses have milky film after running the dishwasher.
This "milky-like" film is hard water build up in your dishwasher that is depositing it back onto your dishes. To solve this you can get the product called Lemi-Shine at any store or on line. The first time you need to put about 2 heaping table spoons into the dishwasher with no dishes in it and run a normal cycle. Then load and put 1 table spoon in it for about 4 times and you will see the "milky-like" film go away. After that you will need to do a Lemi-Shine cleaning 1 a week. The Lemi-Shine has the directions on the container. I know this cause I use to have the same problem at my house and this works. Good luck. And thank you for the question.
Aug 17, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Rinsing agent not dispensing
the problem is hard water. go to www.dishwasherfilter.com. they have a filter designed specifically for this problem. it filters the water going into your dishwasher leaving your dishes crystal clean with every load. it is very affordable and guaranteed to work.
Mar 18, 2009 | Dishwashers
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
115 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
