Question about Microsoft Windows XP Home Edition
When installing windows xp home edition, the drivers are loaded then when it gets to the 'windows is starting setup', it freezes. From what I know, it is due to a problem detecting hardware. I have therefore replaced the hard drive and the RAM. I am still getting the same problem. I also tried installing xp pro which does the same thing. Both install cds work on my pc. I have an acer aspire 5101 laptop. Any ideas why it is freezing on this screen and what I do to get to the bottom of why this is happening?
  • 2 more comments
  • al_will_robi Feb 22, 2009
    yes i did, i had the problem both before and after i replaced both the ram and the hard drive. I originally had xp on the laptop so it shouldnt have compatibility issues.
    I ran a memtest which flagged up errors with my old ram, so i replaced it. yes it is the correct ram. i replaced the hard drive also incase that was an issue. its a 2.5" ide so it shouldnt have the issues the later sata drives do.
    why is it freezing at this screen do you think?
  • al_will_robi Feb 23, 2009
    I did a bit of google searching and found the following thread...
    http://www.theeldergeek.com/clean_instal...
    Which has led me to believe that the support for ACPI is not being installed by setup.
    How do I rectify this?
  • al_will_robi Mar 06, 2009
    Thanks for your interest, I tried that but it didnt work.
    I think I am missing some drivers which I need to install....
  • bsevinc May 11, 2010
    Did you recently upgraded your RAM or any other hardware?
    Problem Solver:
  • 8 Answers
Disable ACPI during installation. When prompted to press F6 for SCSI press F7. This will force standard HAL on you pc.
Posted on Mar 05, 2009
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
Mar 09, 2014 | Computers & Internet
I want to change my windows xp to Home edition
You can also do a clean installation by following the procedure as listed below:To perform a clean installation of Windows XP, follow these steps:Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.At the Welcome to Setup screen, press ENTER to start Windows XP Setup.Read the Microsoft Software License Terms, and then press F8.Follow the instructions on the screen to select and format a partition where you want to install Windows XP.Follow the instructions on the screen to complete the Windows XP Setup.
Oct 27, 2010 | Microsoft Windows XP Professional
My Computer will turn on and go to the windows XP loading screen with the blue bars and will won't load up, it rarely does but when it gets to the log on user screen it freezes
Right after your POST screen goes off,before you get to Windows starting,try pushing the F8 key several times until you get the Windows boot options.Then try 'last known good configuration".
If that doesn't work,you can boot from the Windows installation disk and try to repair your Windows installation.Let me know what happens.
And good or bad, please rate my post?
Bob
Aug 11, 2010 | Dell Microsoft Windows XP Home Edition
I am trying to install windows xp home edition on my compaq presario 1260, and everything i have read states that this is possible. my issue is that when it gets to the "set-up is starting windows" it...
The following items can cause Setup to stop responding while the "Setup is starting Windows" message is displayed:
  • An incorrect mass-storage device (such as a SCSI or IDE controller) driver is being loaded, or the driver was not written for Windows and is not compatible. Contact the device's manufacturer or download the latest driver for the mass-storage device. For additional information, click the article number below to view the article in the Microsoft Knowledge Base: 216406 Specifying Third-Party Disk Controller Driver During Setup
  • There is a device connected to your mass-storage device that is preventing Windows from being installed. Remove any devices (such as scanners, tape drives, removable drives, and so on) from the mass-storage device controller. If the computer is IDE-based, verify that you have the master and slave designations set properly. If the mass-storage controller is SCSI-based, verify that the termination and bus speed is set properly.
  • The computer does not have the latest BIOS revision. Contact the computer's manufacturer or check the manufacturer's Web site. Many manufacturers have updated their BIOS revisions to properly support Advanced Configuration and Power Interface (ACPI).
  • An ACPI Hardware Abstraction Layer (HAL) is being used during Setup. Force the use of a non-ACPI HAL during Setup. For additional information about this procedure, click the article number below to view the article in the Microsoft Knowledge Base: 216251 How to Specify a Specific or Third-Party HAL During Setup
For additional information, click the article numbers below to view the articles in the Microsoft Knowledge Base: 224826 Troubleshooting Text-Mode Setup Problems on ACPI Computers 220845 Adding Third-Party or Updated Driver During Windows 2000 Setup
You may have to load you SATA drivers first? OR choose another HAL, press F6 during setup.Setup ACPI also.
Feb 08, 2010 | Compaq Presario 1260 Notebook
I have a benq joybook 5100 and xp home edition.I formatted my notebook.I want reinstall from Home edition CD.But windows 98 starting... " 98 start file comes and "quick restore" a window comes."english" to...
you can use either two system. just follow  the screen when installing it... put it on the other partition (drive)....
when starting you can select xp or 98.....
Jan 28, 2010 | BenQ Joybook 5100 Notebook
Video controller
your screenshoot shows that you are not installed VGA driver. put your motherboard CD. Run VGA/AGP Driver setup.
Mar 12, 2008 | Microsoft Windows XP Home Edition
Microsoft Windows XP Home Edition Logo
96 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
