Question about HP Hewlett Packard Compaq dx2400 Microtower - KR604UTABA PC Desktop
USB Network Interface is missing i don't know how to fixe it
I want to get the internet with usb device but it didn't work
  • Dan rogers
    Dan rogers May 11, 2010
    what usb device and what kind of os are you running?
    Scholar:
  • 164 Answers
What error are you getting?
Have you updated the USB Drivers?
Go to Microsoft and update them.
Go to your device manager and see if you are having any conflicts. resolve them.
Posted on Feb 23, 2009
Plug magicjack usb
If you have a magic jack + your best to connect via Ethernet , the reason for this is because you don`t have the delay a computer imposes. the reason your device dos not work on your routers usb port is the port dos not have the driver software or the operating program magic jack uses to interface with a computer and there is no way to to load it up on your router.
It will not work for you, the usb connection is for comunity access to a had drive on your network only ,,,as far as i know.
Oct 12, 2013 | TP-LINK Computers & Internet
Tip
How to fix ?USB device not recognized? error in windows
Are you getting a “USB device not recognized” error whenever you plug in a USB mouse, keyboard, or other USB device? I love USB and have 5 ports on my computer so that I can connect my mouse, keyboard, camera, phone, and printer to it all at once!
However, last weekend, my computer stopped recognizing my USB devices! The strange thing about it was that the USB ports were not bad because all of my devices were still getting power to them. I could still charge my cell phone without a problem!
So I started with the normal fixing methods, including uninstalling the drivers for my devices and reinstalling them. That didn’t work! Next I tried System Restore thinking that maybe I had installed something and it caused a conflict with the USB system drivers. That didn’t work!
I read online that in order to fix this problem I should go to Device Manager and uninstall all of the devices under USB Controllers. Restarted the computer, reinstalled the USB drivers, but the problem STILL did not go away!
You may also see in Device Manager that the device shows up as an “Unknown Device”. 42b721d.png
So how did I finally fix the problem? Well, apparently it’s a super simple solution! No need to edit the registry, uninstall drivers, or anything of that sort.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that’s it! Note that this does not mean just turning off your computer because modern computers don’t really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be “rebooted” also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this helps someone fix that pesky “USB device not recognized” Windows error!
on Jul 08, 2010 | Computers & Internet
I recently installed CAT6 cable to run between my computer and main stereo. The run is 50' so I also purchased a USB extender. My issue is that once I hook the network up to my computer, it can no...
Yes- don't use USB as an extender- Network spec for Cat 6 without a repeater ranges from about 165 feet to 75... You should be able to run the cable straight through.
Jun 15, 2011 | IOGear USB Booster Cable G2LUB16 USB...
Hej. Yesterday, suddenly my Macbook air´s keyboard and the touchpad started not to react. I didn´t do anything, just let my laptop on the tabel for 5 min. and when I came back, it wasn´t...
when your keyboard and touchpad are not working, try to connect an usb mouse and keyboard to the laptop, just to be sure the system is responding.
if the usb devices work, you can be pretty sure there is an hardware problem. if the usb devices don't work too, maybe the system got stuck, and the best thing to do is a system reset
How to Restore MacBook Air to Factory Settings
if the usb devices work, give a try to the apple hardware test to see if it detects anything.
Using Apple Hardware Test
i had a similar problem a few years ago.. if it's an hardware problem you will need to change all the top case
MacBook Air 13 Top Case eBay
Jul 30, 2017 | Apple MacBook Air
I've had a Netgear WG111 usb wireless adaptor since 2007. It has suddenly stopped working.My computer cannot connect to the internet/ modem - it says no adaptor detected. Help. Can the adaptor just die?
yes they can and do I personally have had 3 or more just die, especially anything USB, they are real bad for just stopping, It is usually the USB interface and not the actual device that fails. with USB, it is usually a power spike" that kills them.
Mar 24, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
APC ENS-USB laptop stand missing AC power adapter
please call APC Technical Support at (800) 890-4272 for a replacement.
If it is not a proprietary interface (I can't find any information on this), then you may be able to swap out with a cheap AC adapter from Radio Shack or something like that. From what I've read, however, it appears to be a proprietary interface and you'll have to purchase one from their office.
-Jon
Sep 29, 2009 | APC ENS-USB (ens-usb) Stand
USB wireless internet adapter disconnecting
Sounds like the usb ports are sharing an I/O channel. So when you unplug one usb device the CPU is being told that the USB port is not being used.....Maybe..... To test this, hardwire into a data cable and plug in different devices, next unplug a devise and see what happens. If you stay connected you may have found your answer. Unfortunately I don’t think a reimage or restore will fix the problem. If you get the same result try a reimage of your OS. Good luck.
Again sound like a mother board issue.
Questions to ask, When did I notice the problem (Maybe able to restore to the point the problem started.) and did I install new software or hardware when this happened?
Good Luck
Apr 05, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
CL51-15 USB Port Problem
I have the same problem with the USB's not working. Suppliers say Motherboard problem. solved it by purchasing a PCMCIA to USB port. at least i now have 2 USB ports. you could probably get one with 3 ports.
Kevin S.A.
Sep 26, 2008 | ASI CL51-15 Notebook
HP Hewlett Packard Compaq dx2400 Microtower - KR604UTABA  PC Desktop Logo
53 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
