I have a Verbatim 160 Gig USB 160 portable hard drive that I downloadd my computer on to about 6 months ago. I went to retrieve the data on another computer and the drive is not even recognized, the blue light just blinks. I have a lot of important data on that drive. How can I retrieve it? Michael in Flemington NJ
  • mfbregen Feb 20, 2009
    I have tried to connect to 3 other computers with the same result. No recognition, blinking blue light. Is there any other solution besides the shipping out to a data recovery house?
  • mfbregen Feb 21, 2009
    Apparently there is no fixya fix for this problem. I know that I could always send the unit to a data recovery house, as Verbatim recmmends, but that costs $1500 or more and is not a fix....but rather a major thing, for a unit taht costed $75. I do not need it that bad.
    With so many other people reporting the same problem with the Verbatim USB160 one would have thought that someone would have come up with a fix.
  • 564 Answers
You can recover this data as long as the file recorded is still recognized by data recovery software. You might want to try PhotoRec (cgsecurity) a freeware to recover files with option to choose file extension you need to recover.
General information of how-to diagnbose and recover hard drives: http://www.pcstats.com/articleview.cfm?articleID=1139 http://www.data-recovery-info.com/ http://www.hard-driverecovery.com/ http://www.get-data-back.com/data-recovery-how-to.html wizard to help you decide how bad the problem is Does disk management recognize the FORMAT of the partition, not just the existance of the hard drive? If not, then possibly the partition table is corrupt. There are some programs that can fix this, if you are sure that is the problem. For examle: http://www.ptdd.com/index.htm Do a Google search on "partition recover" to see more possibilitiies. Can you run CHKDSK on the hard drive, when it is in the external case? If yes, does that help? If no, then this disk is probably not accessible by ordinary XP programs. So, try lower level programs, such as the disk testing tools available free form most hard drive makers (e.g., SeaTools for Seagate drives). Avoid "low level format", as that will erase everything. Most such tools are available as bootable CD images, although some are also available as installable software. Try file recovery software, some of which can find files without a valid partition table. This is more likely to work if the hard drive was not fragmented, or only slightly fragmented. See the following link and try a few of the free programs, or read about the capabilities of the not-free ones and maybe try one of those. Some programs offer a free find-files version, but you have to pay for the version that can recover the files. http://www.majorgeeks.com/downloads38.html However, if the disk is physically damaged, it is unlikely that software tools will fix it or recover most files. If you come to that comclusion the only hope might be a professional recovery service, which can mount the disk platters in a new hard drive, then recover (some) data. Such services are not cheap, but most offer a free/cheap diagnostic, and only change big bucks if they can recover a lot of files. A list of possible services is at: http://www.get-data-back.com/data-recovery-services.html http://www.data-recovery-directory.com/usa-canada.htm While roaming the web in search of a solution to your current problem, also check into backup and recovery software. You should never (again) let yourself get into a situation where you have important data without a backup. At the very least consider performing backups to an external USB disk via windows explorer or better via XCOPY.
Hope this Helps, Please Rate My Response! Thanks!
PREM
Posted on Feb 21, 2009
  • 58 Answers
Go to control panel and look up the drive you install in you computer and see if u could bing it up that way because what some times happens the cunputer gets stuck on some thing ors its leday by any reson is going to let u kow its not rec so try to pull it up that way on ur control panel and click on ur software and rigt click on the mouse and click instal and make shure it complets correctly hope this helps
  • 744 Answers
Hi...try getting an external power supply from Verbatum. The drive might not be getting sufficient power from the USB port....
thank u
  • Prakash Ram
    Prakash Ram Feb 21, 2009
    I had a similar problrm with a smartdisk 250 gig drive. Initially when
    it was drawing power from the USB port, it did nor show up as an
    installed drive. When I added an external power supply made by
    Smartdisk it worked fine. Perhaps you need an external power supply.. that will solve ur problem surely....
    thank u...
    Scholar:
  • 64 Answers
From Verbatim web site:
If you need the data off your drive, we suggest a few things.
  • The hard drive mechanism inside of your Verbatim product may not be the part that failed. If the mechanism inside the unit is still working, a local computer repair shop should be able to transfer your data through adapters or another enclosure and transfer it to another hard drive, CD or other storage media. This is relatively simple and inexpensive.
  • Once you get your data recovered by a repair shop, you will have to obtain a letter or receipt on company letterhead stating that they are the data recovery company that performed the data recovery on your drive. We require this because opening up the drive in any way will void the warranty. If you have a letter or receipt for the service, your warranty will still be honored.
Posted on Feb 20, 2009
  • 19,396 Answers
If the disk is not being recognised that can be because the caddy enclosure with the disk inside is faulty.
The hardrive must be removed from the defective enclosure and installed into a computer , or into a USB enclosure that is working.
If you want to do it yourself, buy a different caddy, remove the disk and mount the disk inside the new enclosure.
An alternative solution is having the backup done at a local repair shop, that will be safer for your data.
If you want to do it yorself you can buy the enclosure here.
Here is an example of the enclosure you need to do the job:
SAT3510U2 3.5'' SATA Hard Drive Enclosure ...
    President:
  • 2,653 Answers
Michael,
The easiest thing to do is to use Knoppix.
What operating system is the computer you originally used to store the files on?
What about the new one?
Have you ever burned an "iso" file before?
There are LOTS of ways to fix this problem so I wouldn't worry too much at this point. I can definately get you thru this.
  • 13,433 Answers
Hi
I suggest you take the hard drive out from it case, and plug it directly to the computer to see if the adapter is fauly.
If you have warranty I would use the warranty instead of taking it apart but warranty service can't guarantee the safety of your files unless so stated by the service provider.
I' woul personally take it out from the case, and plug it directly to my computer. If you don't have the required connectors on your computer, tell us what kind of connectors the end of the drive has and I will locate you a new adapter to test it with.
    Master:
  • 413 Answers
How does the drive connect to the computer? USB, Firewire?
Are you getting power to the drive?
  • 77 Answers
Try the drive on yet another computer to be sure. But if nothing, then you will likely have to ship the drive to a data recovery house.  I use http://www.ontrackdatarecovery.com/ when I need this done. They are very good, but be warned.. It will not be cheap.
  • Randy
    Randy Feb 20, 2009
    Basically it goes like this. You can take the drive out of the enclosure and try it inside your PC. See if your BIOS reads it. If not, then one of a few things have happened.
    The controller card is dead. This is usually the case when a drive is not recognized, makes no spin up sounds and no clunking sounds. Then IF you can find an identical drive, with the exact same revision controller card on it. That is the circuit board on the back of the drive, you can swap those. IF it is the controller card, swapping them will fix it.
    Otherwise it is either a head or motor problem and there is nothing you can do besides ship it off for data recovery. If you open the drive and expose the heads, dust will instantly be attracted to them and will wreck the platters.
    Vey few options for data recovery when it is resulted from failed hardware.
    Sorry,
    Randy
How can I retrieve my information from my verbatim hard drive 320gb? It isn't opening.
Take the drive out the caddy and plug it into a computer using a SATA to USB cable. If the drive doesn't spin up then it's a dead drive and you'll need to use a data recovery company
Jul 17, 2016 | Verbatim InSight 320GB USB 2.0 2.5...
My verbatim external hard drive has stopped working. I plugged it in to a computer at work which cam up with "power surge" the light no longer comes on and it is not being recognised in my system device...
Disassemble the external drive and install the hard drive in a pc or place in a generic external drive you can purchase without a drive inside, then you can get access to those files again. The External drive interface has failed not the drive itself.
Oct 06, 2013 | Verbatim SmartDisk Firelite Portable USB...
Verbatim store n go usb flash drive 8 gb device not recognized
My Verbatim Sto N Go 8GB USB Flash Drive does not work in any port, in any computer. When I plug it in, the "Device is not recognized" error comes up. When I click on it, and the Unknown Device Properties comes up, the device status reads: "Currently, this hardware device is not connected to the computer. (Code 45)
To fix this problem, reconnect this hardware device to the computer."
The driver details read:
Provider: Advanced Micro Devices
File Version: 1.0.11.82 built by: WinDDK
Digital Signer: Microsoft Windows Hardware Compatibility
This is the 2nd drive of this same brand that quit working within 6 months. I have MONTHS of work on files in this drive, and would hate to have to redo all that work! I was real careful after the first one went bad to use the eject button when removing it from my computer. But I am thinking the last time I clicked the eject button, it froze, so I just pulled it out without the message coming up. Hopefully there is someway to get the computer to recognize this drive again???
Sep 26, 2012 | Verbatim ® Store `n` Go USB Flash Drive,...
Hello, i have a VERBATIM hard drive USB 2.0 it cost me a lot of money :-( i've hardly used it! it has been handled in cotton wool tonight, when transferring data to it from my computer it has...
1. First power down the computer and the external hard drive.
2. Disconnect the drive.
3. Wait a minute.
4. Start your computer.
5. Connect the Verbatim drive again.
6. Wait a minute. (While waiting, check the screen for popup messages telling you the harddrive is ready and received a drive letter.)
7. Check "My Computer" for the harddrive.
8a. If you see it there, click it and make a copy of the data you have stored on the drive immediately!
8b. If the drive does not show up, you probably have a problem that will take deeper looking-into.
A clicking sound from a harddrive is never a good sign. While it does not mean immanent ***** of the drive, getting the data from it is now a matter of luck. In any case you should not trust the drive and should replace it as soon as possible.
Jul 01, 2017 | Verbatim SmartDisk Firelite Portable USB...
My Verbatim suddenly stopped working on my Mac OS
It sounds like your hard drive is damaged. Hard drives are very, very dilicate pieces of machinary. The disk is paper thin and any sudden jarring, especially dropping it creates a warp in the drive. It could also be just a mechanical failure. Unplug it to prevent further damage. Don't worry in many cases you can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Jul 13, 2009 | Verbatim VER95327 USB Hard Drive
External hard drive does not display icon in My Computer
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program to recover your files.
http://www.asoftech.com/adr/
Mar 03, 2009 | Verbatim 160GB USB FireLite: The "drive...
Verbatim usb 160 external hard drive.
That model doesn't have an external power supply port.
May 26, 2008 | Verbatim 160GB USB FireLite: The "drive...
Open Questions:
We provide best team support to all Toshiba users active for 24*7 hrs. Call us +1888784-9316 With 24x7 major subsidiaries and affiliates worldwide, Toshiba Corporation is known as a world class innovator and global high technology product leader worldwide. Toshibha launched laptop computers from its kitty way back in 1985 and by Financial Year 2010 they have managed cumulative shipment of more than 100 million Laptops. Toshiba has been known to set benchmarks when it comes to quality and features that results in exceptionally high performance. In spite of the exceptional features you may experience issues related to data recovery, backup and security and may be deprived of any support by the Toshiba Support. In the event of an OS Crash there is always a chance that you may Toshiba Support your critical data. Virus attack or accidental data deletion are also some of the other reasons that could cause mess. An updated backup will warrant that you do not lose your critical data forever. DataAlign comes to you rescue in these situations. DataAlign offers comprehensive technical assistance for your computer's data backup, recovery and security. DataAlign lets you schedule backups to execute daily, weekly or monthly. Our award winning cloud backup Toshiba Customer Service lets you schedule your backups continuously throughout the day. Data Align gives you affordable services that saves you both time and money and that lets you take control of other important things in life like growing your business or spending time with near ones. TOSHIBA is known for its diversified product range and services worldwide. Still, there are several issues that a TOSHIBA user can face on the TOSHIBA computer. Problems faced by TOSHIBA customers BIOS update Toshiba Backup Slow Performance Windows 10 upgrade Data Backup and Transfer Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Computer Tune-up Issues Virus Removal Issues Our highly talented and expert IT Team can help you fix most of the issues that you face with Toshiba Virus . And the best thing is that we can help you get your data backed up on our secure cloud storage. Why Our Toshiba Help Desk Number Technical Support Team Are Best? With several years of experience in our kitty working with a wide variety of customer group, we have gained an edge when it comes to providing technical support for TOSHIBA Computers. To add to it, our expert technicians trained specifically on TOSHIBA computers are always ready to help you best possible solution for any issue that you may face with your TOSHIBA product. 24X7 availability and assistance for your TOSHIBA computer. We have a dedicated & experienced support team to handle issues for your TOSHIBA computer We ensure little to no downtime with maximum uptime and highest productivity for your TOSHIBA Computer. We ensure Data backup and retrieval assistance We ensure end to end ownership & solution for issues you face with your TOSHIBA computer. Quick and efficient support over the remote. You can sit back & relax while one of our techs fix the issue for you. All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact +1 888 784-9316.
Apr 27, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
David Payne
David Payne
