Question about Radio Communications
Uniden UH-013 squelch
I have a Uniden UH-013
My complaint is the squelsh chatter on weaker signals.
Is it possable to modify the decay time without altering the atack time of the squelsh.
I haven't been able to find any mods for this radio. I would like to download a Service manual and schematic if available.
Had an issue with this unit since new. Squelch adjusted too high. Not hearing some signals showing on meter. Solution - find a trim pot labelled "Meter" on the PC board and adjust it like a knobby squelch control. Made a big difference to the number of received stations. Down side is I need to use SQT tight squelch sometimes.
Posted on Nov 25, 2012
GALAXY DX 88 NO OPEN SQUELSH
if you have been this far into the radio you may want to see the alignment diagram. It shows the squelch adjuster and the procedure tells you what to do.
Oct 29, 2016 | Galaxy Radio Communications
Have interference after incoming transmission which remains til mic is keyed stays clear til after next incoming.
perhaps the squelch is set too "open". Try to program a tone code into the radios. Many times the manufacturer expects you to use a tone and they set the squelch too high, or open. This causes the squelch sound because the radio is trying to pull in weaker signals. If you are using a tone code, the model of the radio is needed to tell you if the squelch can be adjusted.
Nov 02, 2015 | Uniden Lot Of 3 Gmrs 10-mile Range Uhf...
Scanner not scanning, says delay
you need to turn up the squelch
delay is displayed when the squelch gets broken
so turn it up and scan or it will start to auto scan if you set it too auto
when a signal breaks then it stops .. and listens
you can set it to manual so when a signal is detected it will stop and listen too that frequency
if it says delay all the time then there is a problem
prob with the squelch cicruit or the control perhaps has had a knock
Dec 13, 2014 | Uniden BC340CRS 100-Channel Clock Radio...
Squelch is open all the time on uniden bc350a scanner
Have you turned the squelch knob all the way in both directions, to see if that helps?
If so, then you have to replace that squelch knob unit, with a newbie.
I hope this helps.
Cheers,
Peter
Nov 02, 2012 | Uniden Bc350a Nascar Police Scanner No...
How do i adjust the squelch?
Turn the squelch control clockwise just enough to cut the background noise, this should work well for local communication.
Jul 23, 2012 | Uniden Gmr2638-2ck 26 Mile 2way Radio With...
Squelch jammed open on uh 047sx
You shouldn't use jam on your radio, ha! Ha!
To help you find a solution, we need more info.
The MAKE/MODEL of your radio and as much info as you can give in regard to the problem, the more info, the easier for us to find a solution.
Cheers,
Peter
Sep 08, 2011 | Uniden Radio Communications
I have a uniden bearcat scanner 30 channel i would like to know if it is possable to add any software or chip to make it able to pick up aircraft frequencies ? ...
Sorry, but it's been a long time since scanners could be modified to extend or change their frequency coverage. The AIR band in your BC350C allows you to monitor commercial, private, and some military aircraft. If you want full military air coverage though, I suggest that you look at the reasonably-priced BC370CRS.
Bill B.
Listening in since the 60's
Jan 29, 2011 | Uniden BC350C Base Scanner
I have alot of squelch on my cb until i connect ground then nothing.
this is not common it only means you have a good ariel and ground.the preset for the squelsh inside the rig needs turning up if you really need to turn the squelsh off.
Jan 18, 2011 | Midland 1001Z 40-Channels Base CB Radio
CB stays on RX - never goes off. Squelch is set at mid-point. Can you explain why please?
The AGC ( auto gain circuit is possibly cranked uo too much and perhaps the squelch circuit needs adjusting also. If allelse fails trun up the sq. conrol. the local ( louder ) sIgnals will trigger those signals....The weaker (DX ) signals will be more difficult to hear unless the sq. is right off .
Sep 20, 2010 | Radio Communications
Won't pick anything up (uniden BC72XLT)
Not sure this would be a solution but...
Make sure you don't have the Ch. Locked out so it just skips them..
You may also try and let the scanner sit on one frequency that you know has chatter and see if you receive.
This unit also picks up local weather try that feature and you can tell if you reception is working or not.
Jun 23, 2009 | Uniden BC72XLT Handheld Scanner
Radio Communications Logo
380 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
