Question about Toshiba Satellite M45-S331 Notebook
Problem with Toshiba wireless conection
Hi!I have a wireless network at my house.I have Laptop and Desktop all using this wireless connection.The desktop use the wireless network fine, no disconnects and get a good signal.The Laptop seems to disconnect every 15 mins or so and won't pick the network up again. I have to restart my laptop if I want to connect againCan anyone suggest what may be happening for mine laptop to just Forget about the network?
  • vannanbg Feb 20, 2009
    I have already tried that, but the problem is still here. Tnx anyway.
  • 35 Answers
If you have your router set-up with security enabled, you should try to re-set the router and then go back onto the routers "control panel" and re-setup the security. You can find out the correct way to reset the router and the correct address to enter into the browser to access the routers control panel by going to the router makers website and checking under Support
Posted on Feb 20, 2009
Connect toshiba 4025cdt to wifi
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 25, 2012 | Toshiba Computers & Internet
I don't know how to use wifi on my Toshiba A45 S120
Open the Network Settings program. Click on the Control Panel in your "Programs" bar and select "Network Settings." This will give you options for modifying how you connect to the Internet. Select "Connect to a Network" or "Show Network Status and Tasks." Both selections will show you whether you are disconnected from the wireless network. Select "Manage Network Connections." This selection is located on the left side of the window; clicking on it will show you whether you are connected to a local area connection or wireless network connection. Engage the wireless connection. Turn your wireless switch to "On," then right-click on the wireless network connection. Select "Connect/Disconnect." Wait for the IP address acquisition. It may take a few minutes for your Toshiba Satellite to pick up the signal and transmit your IP address. When this is complete, you will see the word "Connected" next to the name of your wireless connection, and a series of bars that indicate signal strength. Launch your favorite browser to access the Internet using the wireless connection.
Feb 11, 2010 | Toshiba Satellite A45-S120 Notebook
Hi. I am using a wireless adapter with a desktop computer. This computer connects to a wireless router but the internet acces is through a laptop in this network that uses a mobile internet solution and...
It appears the wireless adapter is not working properly or is not configured with the wireless router's settings Ie. the SSID, and encryption etc.
First install the latest wireless adapter driver.
Next configure the wireless adapter with the wireless router's settings.
It needs to be the same as the wireless settings in the laptops.
If you need further help, please contact me.
Dec 21, 2009 | Gateway Computers & Internet
Compaq Presario 2232US. The printer on the Desk Top works. From the Desktop, I have 'shared' the printer. From the Laptop, (Compaq)under Control Panel, Printers, the printer Icon is there, however, I...
hi im josh, friend you need to set up network connection for printer config.becoz it is different connection from your internet.try to do so.good luck.
Feb 16, 2009 | Computers & Internet
Lan internet
the easiest way to setup internet on the laptop, is to go to control panel, and launch the network setup wizard. this will enable you to setup a new network, and scan for a local area network connection. this will also give you access to the troubleshooter. to solve any connection problems or issues, should there be any. If your using a wireless method. Your PC must also be able to transmit/receive wireless Signals. If hardwired you,ll have to use the network setup wizard, as this will auto determine I.P And any other DNS settings et,c.
Hope this Helps Mike @ compurepair.
Jan 14, 2009 | Toshiba Satellite Pro L300 Notebook
Trying to set up wireless from desktop (Main ethernet computer) to Laptop @ home. Have cable modem (comcast) connected to desktop (main ethernet plugged computer)Belkin Wireless Router G ethernet is hooked...
Check that the wireless drivers are installed properly on both your laptop and desktop. THe certificate error is because your laptop does not "trust" your computer. Under network conections click add a connection ec, and when you try to conect, microsoft should ask you weva to trust the connections from computer to computer that should do it :D
Sep 07, 2008 | Belkin Computers & Internet
Wireless adapter not showing up in network conections,icon
This happened to me when I had to install a wireless router in my house using my laptop to initialize the network for the first time.
The start up software messed with my settings for wireless detection on my laptop. It turned off the automatic detect for wireless networks in the
"Wireless Zero Configuration"
(This has the settings for the 802.11 wireless adapters
i.e. the one that comes with the R4000 presario)
to get to this hit start>run...
and type in this:
%SystemRoot%\system32\services.msc /s
go to "Wireless Zero Configuration" and enable automatic startup
, if the service is stopped, start it.
hit the apply button to save your settings.
May 01, 2008 | HP Compaq Presario R4000 Notebook
My Toshiba SP6000 cannot enable the wireless network connection when the wireless pc-card is inserted. I intend to network my laptop to my computer for broaband purposes. Please help
Hi Alirahmani26,
From what I've gathered here, you're trying to use a wireless card on your laptop to connect to the Internet through your desktop computer. Are you using a wireless router somewhere in there? Or are you wanting to connect to the Internet FROM your laptop THROUGH your desktop computer? If the latter, are you planning to connect the laptop with a Cat-5 cable or with the wireless connection?
Ben
Mar 21, 2008 | Computers & Internet
Toshiba laptop wont find router
Right click on the network icon in your task bar or in network connections in control panel and click view wireless networks, then when all the networks show, delete them all and close the window, next, a pop up will say found wireless connections click the pop up icon again and look for your connection in the list and click connect and enter the pass phrase Iif you have security enabled.
Nov 06, 2007 | Toshiba Satellite A105 Notebook
Can't detect network
Hi, Some models of Toshiba Laptops have a slide switch either on the side or front to physically activate the built-in Wifi. Some models also will not work with some models of Access Points if using the built-in Windows Wireless Configuration Utility. A workaround is to install the Wireless Configuration Utility of the WiFi manufacturer. If your Toshiba is using the Atheros WiFi chipset, you may need to install the Atheros 802.11a/b/g Wifi Client utility to use rather than than that pf Windows. The file name is atheros_wpa_client.exe and you can just Google it. Hope this be of some help. Post back how things stand or should you need additional information. Good luck and kind regards.
Oct 03, 2007 | Efficient Networks SpeedStream 3510...
Toshiba Satellite M45-S331 Notebook Logo
148 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
