Question about Acer Aspire 5100 Notebook
Hi Viriiguy,when i plug an external monitor on my laptop i still dont get a picture.Even after pressing Fn+F5.When i shine a torch on the monitor(laptop)there is no ghosting in the background.How much is a new motherboard??This seem to be a common fault on the acer aspire 5100.I did find the cooling fan very clogged up,could the overheating have something to do with it Thanks Adriaan
  • 77 Answers
A new motherboard will run you about 99 bucks. The Acer laptops are cheap and fail often. But they are cheap and cheap to repair compared to other brands that don't fail as much and cost more/
Posted on Feb 20, 2009
  • Randy
    Randy Feb 20, 2009
    And why such a low rating on my last help to you?
  • Randy
    Randy Feb 20, 2009
    Overheating MAY have contributed to it, but they eat motherboards on a regular basis.
How do i fix a split screen of my Toshiba c600d-t36b laptop
The quickest way to change the display output settings is to use the
display hot key (Fn + F5):
1 Press Fn and F5 simultaneously.
2 While holding down Fn, press F5 repeatedly until the setting
you want takes effect. Briefly pause each time you press the F5
key to allow time for the display to change.
This hot key cycles through the settings in the following order
(the last two options are available if an external monitor is
connected):
? Built-in display only
? Built-in display and external monitor (simultaneously)
? External monitor only
? Built-in display and TV (or other external video device)
? TV (or other external video device)
? External monitor and TV
? Built-in display and external monitor (extended mode)
? Built-in display and TV (extended mode)
? External monitor and TV (extended mode)
? Swap-Switch primary display between internal display
and external monitor when using extended desktop
Feb 12, 2015 | Toshiba Computers & Internet
Still am not helped pliz, once i connect the projector i dont see the information on the laptop sreen help me pliz, thanx
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 ASUS and Dell = Fn + F8
Mar 21, 2013 | Computers & Internet
Not able to connect to projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Jan 30, 2013 | Acer Aspire Computers & Internet
My samsung r20 backlight keeps going off, if i press the Fn and F5 button it comes on for a second and then back off
If you can see the images on the screen very faintly when you shine a flashlight on the screen, then your problem more than likely is the LCD Inverter. The LCD Inverter costs less than $10, but you will have to disassemble the lcd screen to get to it.
I'm sure you know that you can attach an external monitor to your laptop and hit the FN key and hold it while you hit the correct F1 thru F8 key that will display the image on the external monitor? This could be a solution until you get the inverter fixed.
Now a dishonest repairman will take advantage of you if you take that laptop to them talking about the backlight is going bad. He'll simply bill you $300 and tell you he had to replace the LCD Screen which houses the back light an most times it's easier to replace the screen then fool with the backlight. And in your case all he would do is replace the lcd inverter that sits under the lcd screen and is covered by the strip at the bottom that goes around the lcd screen.
Mar 20, 2012 | Computers & Internet
I have got acer aspire net book size is 8.9 inch. Ca i connect it to external monitor
Hi.
Sure you can with a standard VGA video cable.
Maybe you will have to change your screen resolution to get the best display layout.
Hope it helps!
Feb 10, 2011 | Acer Aspire One AOA150-1784 Netbook
I buy vga to rca and s video cable to conect toshiba laptop to tv and dont show grafic options how ican make work
There is a button to switch from laptop monitor to external monitor or can view on both monitors. There is a button with a drawing of two monitors, usually the F5 button. Press FN and F5 simultaneously to switch from laptop monitor to external monitor. Press them again to view both on laptop and external monitor. Press them again the third time to view only on your laptop monitor.
Sep 07, 2010 | Computers & Internet
I am using an acer aspire one netbook on xp. i can not make the external monitor that i attach to the serial port to work. is just shows, "no signal" When i press fn f5, it still won't work. please help.
Hi, Could you please post the Model Number of the computer.Are you trying to connect using a VGA cable or a HDMI ?Fn+F5 key combinations are used to toggle the display between the laptop and the External Monitor.Try these steps
1.Remove all cables,Turn OFF computer and Monitor
2.Start the computer and wait till it boots to windows nrmally.
3.Start the Monitor,then plug the cables between laptop and Monitor.
4.Check with Fn+F5 to toggle display
Jun 30, 2010 | Acer Aspire One Netbook 8.9" Notebook
ACER cracked screen..external monitor???
Hi there.
The keyboard toggle you are using is the correct one.
Sometimes you have to hit Fn + F5 a couple of times to stay on there is no real set time. Make sure Fn + F6 is on so the laptop screen stays on.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | Acer Aspire 5500 5570-2609 Laptop
Laptop LCD won't display
Bad Video.... It is replaceable if you have dedicated Video,
Need to replace the motherboard if you have onboard (integrated)video..
Jun 07, 2008 | Toshiba Satellite M105-S3004 Notebook
Acer Aspire 5100 Notebook Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
