MDG Laptop will not power up
MDG VisionBook 3590DL will not power up. The blue power light comes on for a second or two and then goes out. With the unit plugged in and with the battery in, it looks like it is trying to charge, according to the lights on front of the unit, but no attempt to post. With the battery out, the unit lights up for a second and then all lights go out. It is not posting, no fans noise, nothing.
  • 3 Answers
It sounds like you are using an inadequet power supply. Check it for low voltage and/or amps.
Posted on Feb 21, 2009
I have a acer aspire 5920 the amber light comes on but when I try to turn the computer in the blue light lights up then goes off and will not turn on! Pls how can I fix this??
One suggestion I could offer is to unplug the laptop and remove the battery, then proceed to hold the power button for 20 seconds and then attempt to boot the laptop again.
Sep 17, 2013 | Computers & Internet
Hi! Having some trouble with a friends laptop here. I have it on AC power and the battery is now charged (middle light has changed from amber to blue). So when I push the power button, the top light...
Hi.
Try unplugging AC power lead and then take out the laptops battery, plug the AC power lead back in and try turning it on, see what happens. If the laptop turns on then there is a problem with the battery.
Good luck and let me know how you get on.
Regards.
Jan 29, 2013 | Computers & Internet
Primary hard disk failure press f1
Replace the hdd and reinstall windows.
May 22, 2017 | Computers & Internet
My Compaq Presario F756nr will not turn on. The blue light to the power cord is on and blue light on front of laptop is orange but when you press the power on button it comes on then goes right off.
Hold the Power button and at the same time attempt to continually press the button for the CD/DVD drive. Continue until the status lights for power, hard drive and power button stay on for 3 seconds or longer. When status lights remain on, remove your finger from power button and allow the machine to boot as usual. Enjoy.
Feb 19, 2011 | HP Compaq Presario F756NR Notebook
My HP 6720 won't switch on. When connected to the power source, a steady blue light comes on (normal) then goes to a light blue then goes blank. If I press the 'on' button, a flashing orange light appears...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced.
Sep 19, 2010 | HP Computers & Internet
Power light comes on and then goes off.
power light comes on and then goes off
Dec 08, 2009 | Acer Aspire 3680 Laptop
Hp dv6700 laptop wont turn on power light comes on for 2 seconds
No its not a virus, your power led on *********** board is not receiving power, go and see a technician close to you
Sep 09, 2009 | Computers & Internet
Delll Inspiron 2200 Laptop does not power on
You have all the simpthoms of an overheating laptop.
For starters, get a vacuum and **** all the dirt from the fan or fans on the back/ bottom of your laptop.
Then turn on your laptop. It should stay longer than 5 seconds.
If this solves your problem, then you are lucky.
If not, you'll need to have your laptop serviced, and clean the heat sink, and have reapplied the heat transfer compund on the processor.
Not a big deal, and not that expensive either.
If this answer helps, please don't forget to rate.
Jun 22, 2009 | Dell Inspiron 2200 Notebook
Toshiba Satellite M65-S821 WONT BOOT UP
probably shorted out motherboard. same happened to mine. motherboard alone is over $300 plus
labor.
Nov 07, 2008 | Toshiba A205-S4577 Notebook
Toshiba laptop wont power up. Blue lights are on for mains cord and battery but if you press the power button the blue power light comes on for about 5 seconds then goes out without any stirring from the...
only suggestion i have is to remove, then replace the memory in the back of the laptop,as it may not be making good contact, if you have two sticks swap them around to see if one is bad.
good luck
Terry
Mar 25, 2008 | Computers & Internet
Computers & Internet Logo
264 people viewed this question
David Payne
David Payne
