Question about Asrock P4i65G Motherboard
New P4i65G motherboard, no display and no keyboard, no beeps
Installed new motherboard in Emachines 2230. there is no display and no keyboard. Tried a graphics card still the same. Connected internal speaker and no beeps. Disc starts but nothing else happens.
I assume I must have done something to it on install but cant think what as this is the 4th one I have done and had no problems this far.
  • Anonymous Mar 21, 2009
    same problem with my vstanf70 Asrock motherboard wont show up
Deriver ASUSTeK Inc. P4B 845 mainboard audio ou grafiq mercu
Posted on Feb 20, 2009
No video on asrock p4i45G motherboards
Hello the homepage is here:
http://www.asrock.com/mb/Intel/P4i65G/?cat=Manual
3 short beeps: base 64 k ram failure.
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Read more here:
http://www.computerhope.com/issues/ch000996.htm
Beep codes:
http://www.computerhope.com/beep.htm
The fault could also be: power supply, or bad capacitors on the mainboard.
Good luck
Nov 26, 2012 | Asrock P4i65G Motherboard
PC Freezes During Boot and at the BIOS Screen, EVGA P55 Classified 200
Beep Code Descriptions
1 short beep Normal POST - system is ok
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps 3270 keyboard card
Aug 30, 2012 | Evga P55 Classified 200 (160LFE659KR)...
6 BEEPS ON DELL MOTHERBOARD REV A00
6 beeps on POST indicates a keyboard error. As virtually all BIOS require the keyboard, it is one error that cannot be bypassed in most BIOS. Is your keyboard connected properly?
Jan 18, 2012 | Computers & Internet
P5GD2 one post beep
Check the processor's heat sink fan. Make sure it's spinning. Blow out any dust or vacuum (w/ no power to the tower.) Reseat the memory. Try with one memory stick if you have two, resassuring to put in slot 1. Sometimes two different types of memory act weird together. Make sure memory is compatible. (ex. PC2100...)
Jan 01, 2012 | ASUS P5GD2 Premium (P5GD2PREMIUMWLOM)...
Asrock motherboard
can u play like that? if u can u can do it or if u can;t just try your best
Nov 15, 2009 | Asrock P4i65G Motherboard
I replaced installed additional RAM in my eMachine T4510 but it wouldn't complete POST. Removed the new RAM and re-installed the factory-original RAM and it still wouldn't complete POST. Removed all RAM...
In your motherboard there will be a CMOS battery remove that battery and put it again you will get the display in your monitor, the battery will be in coin size the battery is CR2032.
Oct 18, 2009 | E-Machines eMachines Refurbished EMA...
My motherboard fail to display and there wasnt any beep sound after i on the pc
Can you give me the make and model of the computer please. Chris the computer doctor http://www.motherboardsrus.net
Jun 07, 2009 | Asrock P4i65G Motherboard
My ECS 915 G-A elite group motherboard doesnot display anymore on the monitor..
have you tried to isolate what the cause of the problem? first check the video card if is properly inserted into the slot, and check the memory, and cable from CPU to monitor if it is connected properly. then boot your system. And try to observe this beep error code this might help you locate where the problem is.
short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 3 short beeps Display adapter problem (EGA)
thnk you.
Nov 29, 2008 | Computers & Internet
If the CPU is dead the problems can be
  1. no power
  2. no fans etc or
  3. power, no beeps (errors)
If the Ram is not compatible it would be constant beeping.
With the board in, and power supply 20pin + 4pin Pent 4 power attached,(#2 and #7 of motherboard layout) remove power cord from power supply.
CLRCMOS0 allows you to clear the data in CMOS. The data in CMOS includes
system setup information such as system password, date, time, and system
setup parameters. To clear and reset the system parameters to default setup,
please turn off the computer and unplug the power cord from the power
supply. After waiting for 15 seconds, use a jumper cap to short 2 pins on
CLRCMOS0 for 5 seconds. Remove the jumper. Remove heatsink and fan from CPU. disconnect cpu and reseat it. Re-install heatsink and fan. Plug in the power cord. Try to boot up. If it still does not boot and (no power, no fans etc.) problem would then be cpu is fried.
Jun 02, 2008 | Computers & Internet
Asrock p4i65g motherboard
Your current motherboard is an mATX form factor. I recommend staying with that form factor for your new motherboard if staying with your current case. When upgrading to the new board you choose don't forget that you may need to upgrade the power supply unit also. You should upgrade to either a socket AM2+ board with dual core amd cpu or socket 775 board with Intel Duo Core2 cpu.
May 02, 2008 | Intel Motherboard
Asrock P4i65G Motherboard Logo
545 people viewed this question
Top Asrock Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Matthew Spark
Matthew Spark
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
