Question about Denon Audio Players & Recorders
Lost my sound in my surround speakers
Just have been running it on wide screen for the tv but I must have pushed a button this morning and how my surround speakers are not working
    Scholar:
  • 93 Answers
Check your speaker setup onscreen ( monitor) viewed configuration, be sure you are enabling SURROUND SPEAKERS, or REAR SURROUND if you are running 7.1, then check the AUTO input to be sure you are receiving a MULTI-CHANNEL SIGNAL within the DIGITAL/ANALOG source. Cycle through the DSP Analog modes ie. Pro-Logic, Rock Concert etc. and check your DIGITAL signal indicator for a 5.1 DD or DTS input, if you hit a unitentional button then you will just need to reset it back to prior operation before loseing the surround speakers.
Posted on Feb 21, 2009
The Sound has gone out on the TV.
HERE'S THE ANSWER TO YOUR PROBLEM:
There are times that TV sound problems does not require you to call for a technician. Some TV sound problems are just easy to repair, and you can just do it yourself. Try to do this one:
1. Press the "Mute" button on the remote control or press the "Volume Up" button. The most common cause of no sound is accidental use of the television's "Mute" function.
2. Make sure the speaker source switch on the back of the television is switched to "Int" if you are using the television's speakers and "Ext" if using surround sound. If not set properly, you will not hear the television sound.
3. Access the television's equalizer by pressing the "Menu" button, selecting "Sound" and then "Equalizer." A list of sound options will appear on the screen. Use the up and down arrow buttons to select the option you want to adjust, and the right and left arrow buttons to make adjustments to the option. You should use this method of adjusting the sound settings if the audio output is in some way unusual.
4. Check the surround sound speaker wires and make sure they are secured to the audio jacks on the back of the television. In addition, ensure that the surround sound speakers are powered on.
If it does not work still. Contact your service provider. Thanks...
Jul 04, 2011 | Protron PLTV-32 Television
Sanyo lcd-32k40 features
  • Model: Sanyo 32K40 Multi System LCD TV
  • World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!!
  • World-Wide NTSC M, PAL BG, PAL I, Secam BG, DK/ PAL DK TV tuners
  • 32 inch LCD TV with 3 HDMI inputs and PC input
  • USB input for direct media playback
  • 45,000:1 Dynamic Contrast: While viewing either very bright or very dark scenes, it can be difficult to distinguish main images which blend into the background.
  • Dynamic Contrast dramatically mitigates this problem by adjusting the backlight intensity, providing up to a 4X improvement in contrast.
  • 6.5ms Response Time
  • Widescreen 16 X 9 Format
  • World-wide Dual Voltage 110-240 volts 50-60 hertz
  • HDTV monitor (HDTV tuner required for HD reception)
  • This is a multisystem TV. All Multi System TVs in the market do not have a digital TV tuner: What does this mean?
  • To watch digital channels (ATSC Broadcasting in US and DVBT broadcasting overseas) you need a digital source/tuner like a cable box, digital tuner, satellite service, etc.
  • To get the best quality video on this TV you need a source that has a digital connection like HDMI or component.
  • Wide Screen Mode allows you to watch conventional 4:3 aspect ratio broadcasts in wide screen (16:9) mode.
  • Steady Sound® equalizes volume levels so there is consistent output between programs and commercials.
  • Built-in hidden speakers includes 2 (5W x 2) speakers to deliver dynamic sound.
  • Component Video Input offers the best video quality for DVD (480p and 480i), and digital set-top box (1080p, 1080i, 720p, 480p and 480i) connections.
  • PC Input allows you to connect your PC and display the PC screen on your TV.
  • Surround Sound Audio Effect
Mar 04, 2011 | Sanyo 42 in. LCD TV
How do I connect to an external speaker, for better output from my LG LCD 42 inch?
It sounds like you are wanting better sound on your home theater.
If this is the case, you can invest in a surround sound receiver and run audio from your sources to the receiver (rather than to the tv).
Basically you would hook your cable/satellite, dvd/bluray, and other items into the surround sound receiver using HDMI, Optical, or RCA-style Stereo wiring.
Once this is done, you can run a single HDMI from your surround sound to your television for the crisp awesome video that your LCD will produce!
If you are looking to run an external speaker directly from your television, it has to be powered on its own, as the television's output audio isnt that strong.
In essence what you would be purchasing is a very wide bar (that is a speaker) that is powered, and has an audio processor built right in!
These are the solutions that I would recommend. If you appreciate them, please vote!
Feb 23, 2011 | Televison & Video
I have an older model Yamaha HTR 5830 receiver and I want to set it up for surround sound (5.1). When I test the receiver all five speakers give back a signal, but nothing ever comes out of the center or...
The broadcaster of the TV station has to tell you they are transmitting surround sound - sometimes they are just transmitting stereo. Also, the media as in CD's and DVD movies must have surround sound embedded or recorded on it to allow surround sound.
Jan 02, 2011 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Can't run ps3 1080p to tv, but can to surround sound
dude im sure its ur TV cant be bith 1080i and 1080p not sure that works like that, sorry just stick to what the TV is
Oct 28, 2009 | Sony Playstation 3 (PS3) Console
I can't get sound from my speakers on my Sanyo HT32744 tv but I can get sound from surround sound speakers through surround amplifier.
Most tv's have a way to turn off the speakers. Either a button on the remote, or in the menu. Go into the menu, sound options. See if it says speakers on/off.
Oct 27, 2009 | Sanyo HT32744 32" TV
Surround sound not working with PS3..
hook your front speaker wires up to the A side and on the front of it make sure only the A speakers are playing but leave the rear speakers plugged into the B side then hit the listen mode button and you should be rocking
Apr 24, 2009 | Kenwood VR-407 Receiver
Surround sound problems
you need an optical cable which it's sort of mentioned in the manual, but because of the multitude of possible ways to connect the TV to the sound surround, I did not figure out either.
I got my optical cable at BestBuy for about $45.00
Jan 27, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Durabrand ht 400
i got everything hook -up stereo works but my tv surround does't i push test button it works but no surround from tv
Jul 18, 2008 | Audio Players & Recorders
297 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
