Question about Fuji FinePix S700 Digital Camera
Finepix s700 says memory full and wont take more pictures with sd
Card installed in camera....the sd card is empty...camera wont let me format the card...when I hit ok to format...the screen goes dark and seems locked up.....internal memory works fine...
  • 1 more comment
  • ginny_m Feb 20, 2009
    wow..I never knew about that switch on the side...but..I changed the position on the switch...and the camera said Protected card....so I switched it back and it still says memory full.....
    I have a slot on my computer....can I format it like that?
  • ginny_m Feb 21, 2009
    its not new. probably 2 yrs old.....its 2 gb...the computer says windows cannot format.....camera wont let me format it...I try and the screen goes dark....but the camera works in all other aspects....the switch doesnt seem to make any difference and I tried the tape so the switch didnt lock.....no difference.
    .I wonder if the card is bad,,do they go bad?
I know this is late, but my camera had the same problem.
1. If you go in the setup menu.
2. Push the right button once and scroll down to the menu that says format.
3. It will ask you if you want to erase all data.
4. Select No and everything should be fine.
Posted on Dec 22, 2009
finepix s700 says memory full and wont take more p - noavatar_s.gif skullz_007 i know this is late, but my camera had the same problem.
Addition:
5. Turn camera off and on again.
Yes this solution worked for me.
Every single memory card i used said it was full when obviously it wasnt. even formatting on pc and camera wouldnt work.
Thanks Skullz :D
Posted on Jul 21, 2010
    Sergeant:
  • 180 Answers
Have you made sure the memory card isnt locked? there is a little switch on the side of the card, try messing with that
Posted on Feb 20, 2009
  • 3 more comments
  • peeface
    peeface Feb 20, 2009
    do you have a memory card reader so you can take it out of the camera and try to format it on the computer?
  • peeface
    yes you can. try doing that and then put it back in the camera
  • peeface
    is this a new memory card? what size is it?
  • peeface
    you probably have to try and format it when its back in the camera
  • peeface
    peeface Feb 21, 2009
    it could have gone bad. i had a flash drive that wouldnt format on anything and i thought it was no good then i downloaded a hard disk low level format utility and it formatted it no problem and it worked fine after that. heres a link. its down the page a little.
    http://hddguru.com/content/en/software/2...
    just make sure if you try to do that you choose the memory card and not your computer hard drive. mine says memory card adapter and the size on the right is 2000mbytes. my hard drive says gbytes. yours will probably say close to the same thing.
    Novelist:
  • 109 Answers
There is a setting in one of the menus of the camera where you can change the place where pictures are stored. Make sure it is set to memory card and NOT internal memory.
Posted on Jul 10, 2009
Tip
How to Recover Pictures From Fujifilm FinePix S700 Storage Media
With 7 mega pixel camera, 10x optical zoom, 2.5 LCD, picture stabilization mode, and i-Flash intelligent Flash, the Fujifilm FinePix S700 fulfills all the requirements of any photographer. The storage media (SD and xD memory cards) used in this camera allows the photographer to save audios, videos, and photos of different sizes. Damage in storage media can occur any time, resulting in fatal consequences, like inaccessibility of data saved in the memory card. In most cases, the photographer encounters an error message stating that the card is corrupted. To overcome such corruption scenarios, the photographer needs to restore the data from an updated backup. But all photographers do not create a backup on regular basis. For them, a third-party Camera recovery software acts as a boon and helps them recover the data.
As a real-world instance, you encounter the below error message while trying to view the pictures saved in your SD card (inserted in Fujifilm FinePix S700):
"CARD ERROR"
After the above error message pops up, the data saved in the SD card becomes inaccessible.
Cause:
Few main causes for the above error message are:
1.Incorrect SD card format.
2.Incompatible SD card.
3.Memory card corruption due to unexpected camera shutdown, virus infection, and interrupted read or write operation.
Resolution:
To resolve the above error message and to access the data saved in SD card, you will need to:
1.Use a compatible SD card.
2.In case of memory card corruption, format the card in Fujifilm FinePix S700 camera. Though formatting brings the card in reusable state, all the audio, video, and picture files get deleted. To recover the deleted data, you will need to choose a powerful Camera recovery software.
Such recovery tools use effective scanning methods to ensure complete Camera data recovery. These tools can be downloaded from the Internet and used by anybody. Such applications are safe as they harm the original data saved in the memory card.
Digital camera recovery software is a world-renowned Photo Recovery utility used for recovering data from almost every type of memory card. This software ensures complete recovery of digital files, irrespective of their size or type. Compatible with Windows and Mac OS X, the read only software also recovers data from other storage media, like Zip drives, hard drives, etc.
on Jun 30, 2010 | Cameras
Why am I getting a "memory full" error when my memory card is not full?
Try formatting the card with the camera menu. This is always safer when you buy a new card. If that doesn't work take the card back
Sep 18, 2014 | Fuji FinePix S7000 Digital Camera
"memory full" but SD cards are empty
Not sure if it will be this, but has the SD card got locked by accident? There is a little sliding button on the side of the card, which can be locked to protect the content. My camera shows the card as full if I accidentally lock the card. You can just slide it back again to unlock it. I never noticed the button was there until I accidentally knocked it while loading the card in and out of my PC to transfer the photos.
Dec 04, 2012 | Fuji FinePix S1000FD Digital Camera
Fuji finepix s700 camera error message protected card. After making sure sd card in unlocked. I still get this message. I had trouble getting out a sd card,i feel a piece of the sd card broke in the...
Take a small flash light and see if there is a part of a memory card in there, if there is cleaning it out would solve the problem. Also make sure you're putting the memory card in the right way. I've you've done that and it's still giving you problems try going into the menu's and formatting the memory card in the camera.
May 10, 2011 | Fuji FinePix S700 Digital Camera
Will sdhc card work in my fuji s700 camera
The SDHC memory card is a newer version of the SD card and will fit in the memory card slot. However the maximum memory capacity your camera is capable of is 2gig, beyond this the card may not work. You may be able to extend this capacity with a firmware update from the Fuji site.
The SDHC memory card has a lock the same as your SD card here is a diagram to make sure the lock is in the correct position for use. Remember also to format the new card and format after each download of pictures to the computer.
Diagram
Jan 02, 2011 | Fuji FinePix S700 Digital Camera
Says memory card is full but it is empty. Internal memory is working fine.
Please try to format your memory using you camera. If problem is still there, then reformat your memory card at PC.
I hope either will work.
Regards,
Jeep Brainy
Aug 10, 2009 | Fuji FinePix S700 Digital Camera
My camera says memory full but doent show any
hi
an alternate solution to this is that try to read te card on uoy pc using a card reader and check to see that the card is empty infact and if it still is genuenly empty then try and format the card once and then try again
cheers
pls rate if this was any help
Jul 12, 2009 | Fuji FinePix S700 Digital Camera
My fujifilm finepix s700 is having problems reading the sd cards i put in none of them are new and have worked before but when i put them in and go to playback it says there is a read error and i cant...
I had the same problem, First, format the card with the camera, you can't drop the card into a computer, because after you format the card it will only work in the camera. If its formated with a computer, then the camera can't use it. You will have to connect the camera using the USB cable to transport your pictures to the computer, use 2GB class 6 cards, the high end 4GB XSD cards will not work at all.
Jun 09, 2009 | Fuji FinePix S700 Digital Camera
Memory Full Error
You need to format the SD memory card using the camera format function. The manual should tell you how to do this. If you don't have the manual, you can download it from the samsung website.
Jul 05, 2007 | Samsung Digimax S700 Digital Camera
Fuji FinePix S700 Digital Camera Logo
1,011 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
