Question about ASUS P4PE-X Motherboard
I installed 2GB ram pc doesnt start, i mean it starts but the screen stays black and the dvd station's light thing turns on and off
  • ilhan_unal Feb 20, 2009
    i dont know but i only could get it to 1.75 , at 2GB i dont think so but all the ram cars are checked and working
    President:
  • 2,976 Answers
Will it actually recognise 2GB of ram? That could be your problem. Mine will only recognise 1.5GB. If I put in 2GB, it causes problems. More isn't always better.
Posted on Feb 20, 2009
  • David Shaub Feb 20, 2009
    Put in what you know will work. Probably at most 1GB. If you can get up and running, go to belarc.com and run the program. It will tell you everything you need to know about your computer. It will also tll you how much RAM your system is able to use.
    If you are installing too much RAM, it won't work. The computer will try to use what it can't. It's like scooping a full cup of chocolate mix to make 1 glass of drink. You have to keep trying & trying a little bit at a time. That's what the computer is doing.
I have black screen in my computer, whats the problem?
There is a button in ur keyboard for projector / TV press the button and your screen will come.
You may have to press the function key and that button together. That button usually stay with the F keys
Oct 31, 2014 | eMachines E442 E442-v133 15.6" Notebook...
Acer am1100 won't start up
Discribe what happens when push the on/off button and you try to boot, fan spin? LED's blink? HDD/DVD light blink? Sound? Any thing on screen at boot? What blue light?
Feb 26, 2013 | Acer Aspire AM1100-B1410A Refurbished AMD...
Have this error Oxcooooe9 and have start up cd what key should I press to make system accept it to reformat hard drive?
this is a "STOP" error or Blue Screen Of Death (BSOD)
There IS no 'key' you can press to fix it, you can only shut-off the computer, and turn it back on again.
As to what is causing it, that Stop error means:
STOP Error 0x000000E9: ACTIVE_EX_WORKER_THREAD_TERMINATION
It is VERY unusual. I've never seen it doing repairs for 20+years.
My suggestions are to:
Make sure you have a clean CD/DVD for the Operating System you are installing.
If you are installing Vista or Win 7 with more than 2GB of RAM, do it below 2GB, if you have two 4GB RAM modules, then remove one of them and try it.
Aug 21, 2012 | Toshiba Satellite L305D-S5874 Laptop
My desktop has an orange light no beep sounds when starting it won't boot up the back where ethernet plug goes is orange too the fan makes a burning smell also
Orange light usually means the harddrive or computer is processing and loading, But it can also mean that there is a problem with the hard drive. Start your computer and wait. If you see orange light it means its working to boot up, it might take a while, you might see your screen black for a while but eventually will work.
To fix this problem you need to upgrade more hard drive space, RAM memory and processor speed
Nowadays a computer should have a minimum of 2GB of RAM memory, at least 120GB of Space, and about 2.0Ghz of processing speed.
You can also buy great refurbished computers which are cheaper. Most of them come with 4GB of RAM memory, 250GB HD Space and 2.5Ghz processing speed.
May 24, 2011 | Dell Computers & Internet
HP Pavillion dv6700 - black screen
Do the following without the battery inserted.
Let the computer sit with no battery for 24 hours. Do not put the battery in at all. Try using your original memory stick ONLY, with no hard drive and see if it will POST. If it does, insert the hard drive and try again. Could be the new memory...
Another thing you can try is reseating the processor. Turn the ZIF screw, take the processor out (WATCH THE PINS!!) and put back in GENTLY. Leave the memory in the computer, hard drive removed, try to power on.
These models have been known for bad motherboards. Contact HP and arrange to send it in. If you do enough digging on HPs website, you'll find the service advisory.
-Dell & HP Certified Technician
Oct 29, 2009 | HP Pavilion DV6700T Notebook PC
My toshiba A200 screen occasionally turns black and music also stops. When i try manually restarting my laptop, sometimes it works but most of the time it doesnt boot at all. Sometimes it doesnt even go...
This sounds like a hard drive is, or has failed. Either that or the RAM (memory has gone bad)
Did you let the laptop overheat? Was it left on for a long time? Or is this just an old machine ?
I would replace the hard drive, and reload the operating system, that is if you really want to keep the laptop. If that solves it great! Also, did you notice if there are any "beep" noises, or error messages when it acts up? Often times, you can go on the internet and find out what the messages mean.
Jun 17, 2009 | Toshiba Satellite A200-0ET00X Notebook
My asus eee 900 pc with 512mb of ram, i upgraded to 2gb of ram, and it restarted fine, now with either ram chip in it it will start to boot up, but the screen stays blank and it attempts to start up with a...
request you to check speed of 2 gb ram with old 512 gb, if u r using 2 strrips of 1-1 gb then first remove both and resinstall old 512 again, and checked, again install both 2 gb ram and check. if after installation of 2 gb ram laptop is not restarting the problem is only with speed of ram. u may need to install ram with proper matching speed
May 26, 2009 | ASUS Eee PC 900 PC Notebook
Ram issue
you may have to check the speeds of the memory as some boards only take a certain speed after 2GB of ram, forcinh you to use different speed sticks, or look for the cmos clear terminals and clear the cmos settings and restart
Nov 23, 2007 | ASUS P4V8X-X Motherboard
ASUS P4PE-X Motherboard Logo
203 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
