Question about Dell 924 All-in-One InkJet Printer
I replaced my black ink cartridge and ran a test page. it keeps telling me there is an alignment problem and to remove the tape from cartridge. I already did that but it keeps on telling me the same thing. Will not correctly print colors.
  • 1 more comment
  • g carus Feb 22, 2009
    I changed black and colour cartridges and my printer tells me it has not alligned and to remove tape from cartridge-have checked cartridge and there is no beepin tape!
  • downhill4me May 03, 2009
    I don t have the manual to the printer, and its saying the same things remove tape
  • marylouotto1 May 09, 2009
    I replaced a new ink cartridge and the printer tells me to remove the cartridge over again because of an alligment problem. I have done this several times and it keeps repeating, although I have done what it asked. Now what???
  • 514 Answers
Go to page 49 of the manual ("http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf" if you don't have it) good luck!
Posted on Feb 28, 2009
How to refill hp deskjet 1560 black cartidge
Hi
check here
Pls vote us to keep us alive
Nov 09, 2010 | Office Equipment & Supplies
I don't know how to install the cartridgre on my new printer J 3680 Could you please tell me how? Thanks,
Follow the instructions below to install the print cartridges for the first time. Installing print cartridges Step one: Install the print cartridges Follow these steps to install the cartridges.
  1. Open the cartridge door. The carriage moves to the far right side of the product. Figure 1: Open the cartridge doorc01133347.jpg
  2. Remove the new cartridge from its packaging and, being careful to touch onlythe black plastic, gently remove the plastic tape by using the pink pull tab. Figure 2: Remove tape from cartridgec01107115.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections.Do not remove the copper strips. They are required electrical contacts. Figure 3: Do not touch the ink nozzles or copper contacts.c01107116.jpg
  3. Slide each new cartridge forward into the empty slot. Then gently push theupper part of the cartridge forward until it clicks into place.
    • Insert the tri-color cartridge into the left slot.
    • Insert the black cartridge into the right slot.
    Figure 4: Insert the cartridgec01107117.jpg
  4. Close the cartridge door.
Step two: : Align the print cartridge The product prompts you to align cartridges every time you install a cartridge. You can also align the cartridges at any time from the control panel, or byusing the software you install with the product. Aligning the cartridgesensures high quality output.
  1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
  2. Press OK. The product prints an alignment page.
  3. Place the alignment page print-side down on the scanner glass.
  4. Press OK to scan the alignment page. When the scan finishes, the alignment is complete.
NOTE: If you have colored paper loaded in the input tray when you align the cartridges, the alignment will fail. Load unused plain white paper into the inputtray, and then try the alignment again.
Sep 13, 2010 | Office Equipment & Supplies
Dell V305w Printer Alignment problem. Remove tape from cartridges or check troubleshooting. Press > to continue. Ink cartridges reset, tape removed, trays aligned. HELP!
In my case this happened with black cartridge out of ink, colour cartridge low; replaced black: had permanent alignment problem, though test print looked OK; wouldn't print black. Replaced colour cartridge, then it all worked OK, straightaway!
Aug 24, 2010 | Office Equipment & Supplies
The black ink doesn't print. We have brother cartridges in our printer DCP 385C, and until recently it always told us when ink was running out. now it doesn't print the black ink at all and it doesn't tell...
Make sure the protective tape covering the new cartridge has been COMPLETELY removed then reinsert. Your printer should tell you that a new cartridge is inserted and ask to print a test page, align etc. Otherwise your cartridge may have a faulty chip which simply wont read.
In which case you need to return it and get a replacement.
Mar 07, 2010 | Brother DCP-385C Stylish Colour Inkjet...
Test page printing at the time of printer powered on
s.gif Solution minimtop.gif The product aligns the print cartridges every time that print cartridges are installed or replaced to ensure the highest-quality prints. The alignment page will continue to print every time that the product is turned on or off until the alignment process is completed. NOTE: If you remove and install the same print cartridge, the unit will NOT align the print cartridges. The unit remembers the alignment values for that print cartridge, so you do not need to realign the print cartridges. Follow the steps below, in the order presented, to correctly complete a print cartridge alignment. s.gif Step one: Remove the print cartridges minimtop.gif
  1. If the On/Resume button is not lit, press the On/Resume button to turn the product on. Figure 1: Press the On/Resume button to turn the product on c00316907.gif
  2. Make sure the paper tray is down and there is letter or A4 unused plain white paper loaded in the paper tray.
  3. Lower the access door until it stops. Figure 2: Lower the access door c00316908.gif Make sure the print carriage moves to the center. Figure 3: Print carriage in the center of the printer c00316909.gif
  4. Wait until the print carriage is idle and silent, and then, using your thumb, lightly press down on a print cartridge to release it. Figure 4: The print carriage c00316910.gif
    • If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If replacing the black print cartridge, remove the print cartridge from the slot on the right.
    Figure 5: The print cartridges in the proper position c00316912.gif 1 - Tri-color print cartridge 2 - Black print cartridge
  5. Pull the print cartridge toward you out of its slot.
s.gif Step two: Install the new print cartridge minimtop.gif
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 6: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
  2. Slide the new print cartridge forward at a slight upward angle into the empty slot. Using your index finger, push the print cartridge forward until it clicks into place. Figure 7: Insert the print cartridge c00316911.gif
  3. Close the access door.
s.gif Step three: Align the print cartridges minimtop.gif If you are installing a new print cartridge, the product begins to print a print cartridge alignment sheet. This may take a few minutes.
  1. Lift the lid of the product.
  2. Place the top of alignment page face down in the left front corner of the glass. Figure 8: Place the alignment page face down c00316913.gif
  3. Close the lid.
  4. Press the Scan button.
  5. The On/Resume light will blink during the alignment process.
  6. After the On/Resume light stops blinking, alignment is complete.
Feb 26, 2009 | HP PSC 1410 All-In-One InkJet Printer
Photo 924 keeps saying alignment problem. please remove tape from
""I have the same issue. I replaced both cartridges and ran the alignment test numerous times but kept getting this message. I then unplugged the printer and plugged it back in and it was fixed! You probably already tried this but if not, it worked for me. Good luck!""
try that for about 10 seconds per the manual at ("http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf" if you don't have it)
good luck!
Feb 14, 2009 | Dell 924 All-in-One InkJet Printer
Lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
Jan 01, 2009 | Lexmark All-in-One Printer with PictBridge
HP PSC 1300 All in one Printer
  1. Turn on the HP PSC and lower the print-carriage access door.
    The print carriage will move into the access area. Figure 1: Opening the print-carriage access door
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot.
      NOTE: The black cartridge is on the right side of the print carriage.
    Figure 2: Removing the print cartridge
      NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab.
      CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles.
    Figure 3: Removing the plastic tape
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place.
      CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
    Figure 4: Inserting the print cartridge
  5. Close the print-carriage access door.
Using a photo print cartridgegtabtop.gif To use the photo print cartridge, remove the black print cartridge and insert the photo print cartridge in its place.
The photo print cartridge can be purchased separately and will optimize the quality of printed photos.
With the tri-color print cartridge and photo print cartridge installed, you have a six-ink system, which provides enhanced quality photos. For printing regular text documents, use the black print cartridge.
Use a print cartridge protector to keep either print cartridge secure when it is not being used. Figure 5: Storing the print cartridge
c00034854.jpg 1 - Inserting the print cartridge
2 - Removing the print cartridge
Aligning the print cartridgesgtabtop.gif After installing or replacing a print cartridge, the HP PSC will automatically print a cartridge alignment page.
  1. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  2. Press Scan .
    The HP PSC will align the print cartridges. During the alignment the button LED will blink until the alignment is complete.
Aug 04, 2008 | HP PSC 1350 All-In-One Thermal Printer
How to change cartridgeon HP desktop D4160
from HP's web site: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00641960&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN Step one: Replace the old print cartridge
  1. Make sure the product is turned on.
  2. Open the print carriage access door.
  3. Wait until the print carriage moves to the right side of product and is idle and silent.
  4. Press down on the print cartridge to remove it from the slot, and then slide it out of the print carriage.
  5. Remove the new print cartridge from its packaging, and then carefully remove the plastic tape by using the pink pull tab. Figure 1: Remove the tape c00442146.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00442147.gif
  6. Slide the print cartridge at a slight upward angle into the print carriage until it snaps into place. Figure 2: Inserting the print cartridge c00642241.gif
  7. Close the print carriage access door. WARNING: Keep both new and used print cartridges out of the reach of children.
  8. Wait until the print carriage moves to the right side of the product and is idle and silent.
Step two: Align the new print cartridge
  1. Load Letter or A4 size, unused, plain, white paper in the input tray.
  2. Open the printer Toolbox . Follow these steps to open the printer Toolbox .
    1. From the File menu in the software program, click Print . The Print dialog box appears.
    2. Click the Properties button. The Print Properties dialog box appears.
    3. Click the Features tab.
    4. Click Printer services . The printer Toolbox appears.
  3. Click Align the Print Cartridges .
  4. Click Align , and then follow the on-screen instructions. The product prints a test page, aligns the print cartridges, and then calibrates the product. Recycle or discard the test page.
Dec 23, 2007 | HP 83 3-ink Black UV Cartridge Multipack...
Dell 924 All-in-One InkJet Printer Logo
206 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
