Question about Samsung Digimax S800 Digital Camera
"Card Locked"! appears when trying to take a picture.
I pressed power to turn on Digimax S800 in Auto mode and it won't record image on memory card with a message "Card Locked!"  How do I unlock?
    Sergeant:
  • 180 Answers
A little switch on the side of the memory card
Posted on Feb 20, 2009
I can't install my card in samsung digimax S800
What type and size memory card? The S800 uses MMC and SD cards. It will not work with SDHC cards even though they'll fit into the slot.
Dec 22, 2012 | Samsung Digimax S800 Digital Camera
S800 digital cmaera unable to delete photo's memory full but when I go to to delete using the ok button nothing happens
Is the memory card inserted??if yes try to check the memory card on the pc. Maybe the card was wasted or corrupt.So you can see the previous pictures before the mmc corrupted, And it cant be deleted.
If No. try to reformat the unit by pressing menu and settings. After formatting,,click reset for defaulting settings..
Dec 31, 2010 | Samsung Digimax S800 Digital Camera
I am unable to take photos with my samsung digimax s800 camera as the message 'CARD LOCKED' keeps coming up on screen. I have deleted loads of photos so the memory card is definitely not full. Any ideas?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 17, 2010 | Samsung Digimax S800 Digital Camera
I have lost my disc for the computer so i can download my pictures from my samsung digimax S800 camera
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Aug 06, 2010 | Samsung Digimax S800 Digital Camera
Is San Disk memory card compatible with Digimax 401 ? I inserted one and got the message card errior.
SD Memory Card is compatible with your Digimax 401 camera. You just need to format the card.
Formatting a memory card
** This is used for formatting the memory card. If you run [FORMAT] on the memory card, all
images, including the protected images, will be deleted. Be sure to download important
images to your PC before formatting the memory card.
** If the memory card is not inserted, the internal memory will be formatted.
** Be sure to format the memory card if you are using a newly purchased or non-initialized
memory card, if it contains data that the camera cannot recognize, or if it contains images
captured with a different camera.
Formatting a Memory Card
1. In any mode other than Voice Recording mode, press the MENU button.
2. Press the LEFT/ RIGHT button and select the [SETUP] menu tab.
3. Select the [FORMAT] menu by pressing the UP/ DOWN button and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN button and press the OK button.
- If [No] is selected : The memory card will not be formatted.
- If [Yes] is selected : A [PLEASE WAIT!] message appears and the memory card will be formatted. If you ran FORMAT in Play mode, a [NO IMAGE!] message will appear.
Apr 12, 2010 | Samsung Digimax 401 Digital Camera
Transfer pictures to computer
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Apr 10, 2008 | Samsung Digimax S800 Digital Camera
Memory card is locked
There is a small tab (like a very small hole with a sliding piece of plastic) on the corner of the memory card. Slide it to unlock it :)
Dec 17, 2007 | Samsung Digimax S800 Digital Camera
Memory problem?
If Its in warrentty period don try anything yourself just go to customer support. Sangita
Dec 26, 2006 | Samsung Digimax S800 Digital Camera
How do I use the memory stick?
Recording Still images To The Memory Stick M.REC mode (Memory RECORD mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to CAMERA. 3. Press the PHOTO button. The still image is recorded to the Memory Card. To View photos on the Memory Card M.PLAY mode (Memory PLAYBACK mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. The last recorded image appears. If there are no recorded images on the Memory Card, NO STORED PHOTO! or NO STORED MPEG4! will display on the screen. 3. Using the (FWD) and (REV) buttons, search for the desired still image. * To view the next image : press the (FWD) button. * To view the previous image : press the (REV) button. * Pressing (FWD) when you are on the last image will take you to the first image and pressing (REV) when you are on the first image will take you to the last image. * Keep pressing (FWD) or (REV) to search for an image quickly.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
How Do I Make An MPEG Recording?
You can record video with audio onto the Memory Card. Follow the instructions below. Recording moving pictures onto a MEMORY CARD 1. Insert a Memory Card into the slot on the camcorder. 2. Set the mode switch to MEMORY CARD position. 3. Set the power switch to CAMERA mode. 4. Press the START/STOP button, the images are recorded on the MEMORY CARD in MPEG4. * You can record 10 ~ 20 seconds continuously. * You can record a still image on the Memory Card by pressing the Photo button instead of the START/STOP button. 5. Press the START/STOP button to stop the recording. Notes: * Moving images that you recorded are saved in *.asf file format on the Memory Card. * The moving picture images on a Memory Card are smaller size and lower definition than those on a Tape. * The sound is recorded in mono. * The following functions cannot be operated in M.REC Mode. - DIS (Digital Image Stabilizer), Digital Zoom, Fade, Program AE, Digital Special Effect, Slow Shutter. * Don't insert or eject a tape during Memory card recording as it may record noise. * Don't eject the Memory Card during recording as it may break the data on the Memory Card or the Memory Card itself.
Samsung Digimax S800 Digital Camera Logo
98 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
