Broken cord on head phones
The wire from the head phones is broken and worn. can I get another wire. I can't find any model numbers.
Bill Davis
  • 3 Answers
You don't need a model number to fix the wire. Any stereo headphone wire will work to replace the old one. Just be sure to check to see which wire is hooked where on your speaker. You need to put the ground wire in the same place the ground wire is on your speaker, the same applying to the hot wire. If you get the two wires backward you reverse the polarity going to the speaker and it will not sound right.
Posted on Feb 21, 2009
Pull cord engaging
recoil clutch fingers are broken or stuck. Take the recoil cover off and look at it while pulling the cord to see if the fingers arent coming out. If the fingers are still coming out then you have worn out grooves on starter cone where fingers engage to turn the motor. If the recoil is damaged a new one can be purchased as a unit from Troy Bilt online for a reasonable price.
Jan 25, 2013 | Troy Bilt 5.5hp Self Propelled Mower
My Vtech cs5121 cordless phone has no dial tone
Vtech phones are junk! I have had many trouble calls for no dial tone,only to find out the Vtech phone is the only one they have,and it is defective.(It really DOES pain me to bill someone 91 dollars to tell them their 21 dollar phone is broken-always try another(preferably hard-wired) phone before calling the phone company!
Dec 30, 2012 | Vtech 5.8GHz Cordless Phone with Digital...
How can i fix the main wire in my bose in ear head phones black and white wired kind
Do you have any idea how could I change the whole cord in fact the rubber black and white became sticky and it is broken :/ after 4 years of using. If you have any advice please let me know. Kbrudz@gmail.com
Oct 23, 2011 | Bose in-ear headphones - Black with...
One of my leg locks is broken off, can it be replaced? this is a davisi and sanford courier xxt
Yes, I believe so. This tripod is made by Tiffen.
Here is the product brochure
Here is a link to the Davis & Sanford Tripods forum. This is actually linking into a specific "Broken Tripod Leg" post where a rep of Tiffen posted theoa message
Here is Tiffen Parts & Repair
and... you could just try the Contact Us if all else fails.
Good luck with getting it repaired! Seems like something that appears to only be 5 years old should still be supported.
Mar 02, 2011 | Sanford Davis & Courier XTT 67 Heavy-duty...
Ryobi trimmer not spinning, the motor runs fine, I think the friction clutch is worn.
Either the cintrifugal clutch is not engaging(if that model has one). Or the drive cable is snaped, or the rotary head drive lug is stripped. Pull off the drive head(where the nylon cord goes) & behind it is a flexable cable that transmits drive from the motor to the drive head(bobbin).pull it out and see if its broken.Check The rotary drive head lug,its on the top of the drive head (bobbin) you removed.
hope this helps
Regards Andrew Porrelli
Dec 05, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My home/land line phone will not get a dial tone
The disconnected message is generated by the telephone company. They should be consulted about that.
The noise and not being able to dial out sounds like a broken wire. If you call the number and the line is broken it should keep on ringing until the telephone company times you out.
It sounds as if you have more than one problem.
After you try some of these things give me some feed back.
Jun 26, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
Power cord
You may have a broken solder connection - some sort of broken or intermittent connection. Common problems are broken solder connections at the power jack (inside the laptop). If this is the case, the laptop will need to be disassembled for repairs to be made. Note: There are online sites with DC power jacks available, crossed by Model number.
Wiring can also break (external to the laptop) especially if the wire/cord is flexed frequently (like when wrapped up to put into the laptop bag). Sometimes there is no external evidence of a break.
Also, if indeed your laptop has a pig-tale as you describe, the jack where you connect might be worn out- just not making contact with the plug.
Find someone with a little tech savvy, if necessary, and locate the exact nature of the bad connection, and make repairs from there.
Jul 03, 2008 | Computers & Internet
Bose in-ear headphone cord cut
most head phones there two wires. those are the two that you most likly put together. if there is any metel mesh covering the wires. that has to be connected also.
Jun 05, 2008 | Bose in-ear headphones - Black with...
Hoover Vacuum
Our Hoover upright vacuum cleaner makes a very loud noise when it is running. What causes this?
Jun 28, 2006 | Hoover S3614 Vacuum
1,745 people viewed this question
 Grubhead
Grubhead
