Question about Canon Rebel XT / EOS 350D Digital Camera
My timer wont turn on
I keep trying to set the timer and it just wont set... is there something in the minue that may have changed on me some how?
  • marysyd02 Feb 20, 2009
    well.. its worked for years and i looked in the settings and I cant seem to find the place that enables it.., i may to take it in i think
    President:
  • 2,976 Answers
Make sure you have it enabled in the camers setup menu.
Posted on Feb 20, 2009
Why can I not get past the "set time" on Gardena water timer?
Check if you get water from the tap without water timer.
Look for obstruction in filter washer (rubber washer with screen mesh to keep debris out of timer)
Battery operated water timers are made to last few years, and cannot be exposed to freezing temperatures or hot sunlight
http://waterheatertimer.org/Gardena-timers-and-manuals.html
Gene
h
Jul 29, 2014 | GARDENA Water Timer
How do you set a pool chlorinator timer - pump wont go on automatically and I dont have a user manula for my clearwater LM2 24TS
If the timer does not keep the time of day then it is faulty and needs to be replaced.
Timers have adjustable tabs to turn the timer on and off at a set times of day.
Dec 02, 2012 | Pool & Spa
Tv turns on and immediately off again
Check if the timer is on or if it is set, please change the setting and turn off timer, if not applicable, try to observe other issues on your TV like if it produces unusual noise, etc. if its new and still under warranty, bring to nearest service center it might be factory defect or something
May 09, 2011 | Televison & Video
Replaced bulb last nite, green light blinks for a min. then it worked! watched a few min.turned on this morning blinking.... wont stop green blink. last nite when i changed bulb tv said change bulb reset...
Many projectors use a lamp hour timer for predicting bulb life so they can give you fair warning of impending failure. Since a bulb may be removed and reinstalled because it is still working or another used lamp installed, the timer is not automatically reset to zero when the lamp is replaced. I surmise your set is complaining because the timer was not reset or the time verified when you changed the bulb.
To fix the problem, buy or borrow a remote control; a universal remote control with a menu button may work. (If you borrow a universal remote from a friend, be sure to record the code for your friend's TV first so you can set it back before returning it.)
You could probably get back into the timer reset menu by removing the new lamp and reinstalling it. Caution: follow the directions on page 68 of the user's manual or the sheet that came with the bulb - let the set cool for an hour first, unplug, and wear gloves when handling the bulb since skin oil can cause discoloration and possibly an explosion when the bulb gets hot. You can download the user's manual from Panasonic's support page for this set.
If you can edit the timer hours instead of just resetting, you may want to set it for the number of hours the new bulb has been used.
It is likely that you can get into the lamp timer menu if the set is in service mode, but the user's manual doesn't tell how to get there (I don't have that info either - it's in the service manual, which may be available online from a third party for a price). Usually it is something like holding a volume or channel button on the front of the TV while turning it on with the remote control. After that you need the code to switch to the timer menu. If you have problems getting into the timer menu, ask your dealer's service department or try calling the Panasonic help line listed on the bottom of page 68: 1-888-VIEW PTV(843-9788).
Oct 16, 2010 | Panasonic PT-40LC12 40" Rear Projection...
Freezer not defrosting
You got the right idea. your fridge have a deforst problem, and it can be cause by a number of items. 1. the timer, 2 the defrost temperature control. 3 the defrost element itself.
Before you use the hair dryer when there is ice forming in the back panel, try to turn the timer and see wheather you can set it to defrost cycle manually if you can then the timer need to be change. the 2 and 3 item is a bit more work for normal people to deal with, you better call in a serviceman and watch him how he handle it so you can try it yourself next time. God Bless
Jul 14, 2009 | Freezers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Keeps filling up even when full for over 4 hours (never changed cycles)
The timer sends a signal to the water level control valve. This valve serves two primary purposes. 1. Activate the water valve to fill the machine. 2. Shut the water flow down and allow the machine to operate. Try running the machine again. If the water continues to enter the machine after it begins aggitating then shut the water off at the spigot. Now watch and see if the timer moves or not.
If the timer does not move at all then I would replace the timer. If it DOES move then another problem exists and will need to be addressed.
Jan 13, 2008 | Maytag Performa PAV2200
Timer
After you set the time ,do you push the Clock button to lock your time??If you set the clock time and walk away its not holding the time ,because its waiting for you to confirm time selected.So after you set the time press the clock key pad 1 more time .Remember this, just because you bought a new clock doesnt mean its a good part.Bad parts get the best of us ,so dont think your new part is ok yet.It probably is not.
Aug 16, 2007 | Rangemaster Proffessional 110 Gas Kitchen...
Canon Rebel XT / EOS 350D Digital Camera Logo
42 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
