Question about Technics Audio Players & Recorders
Head alignment on technics rs b 605? the screws just dont do anything!  and now through my fiddling the mechanism has jammed..........
3 Suggested Answers
SOURCE: Technics RS-TR272 dual cassette deck
My RS-TR272 tape deck plays the cassette but no sound. I have not even used it much, may be 3-4 times in last five years. I tried demagnetizing it but still no effect. It is brand new unit, only thing I did last time was that plugged in the RCA cables in opposite ways one time (Output in In and In into output one). I am not sure if that had any bad effect on it. Can someone please help on this as unit shows cassette playing. There is no volume switch on the unit itself as someone else recommended in the previous answer.
Posted on Nov 25, 2007
Grubhead
  • 5259 Answers
SOURCE: Technics RS-TR373 is chewing tapes
A lot of tape chewing problems are caused by the capstan roller being worn. Check for wear or oxide on that first.
Posted on Jan 21, 2009
My ink cartridges say full but wont print. how can i rehydrate them
->Make sure the printer is connected to your computer.
->Run a print head alignment and cleaning. Misaligned or dirty print heads affect printing quality. Click on the Start menu icon in the computer task bar. Select Control Panel, then click Printers and Faxes. Click on your printer icon and then select "Printer," "Preferences" and "Maintenance." Select "Run print head alignment" and execute the alignment. Select "Clean print heads" to perform this operation.
->Open the access panel door and look at the roller devices to see if a page has been jammed in between them. If so, pull on one end of the page to remove the jam. Try to print your page.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
Nov 19, 2012 | Lexmark X1150 All-In-One InkJet Printer
I have a rs-tr 180 that's pulling the tape out of the housing is there a solution?
The tape player recorder that pull the tape out could have the following faults: 1) It has a separate belt from the motor/capstan to the take=up turntable. 2) Capstan roller skew the gap when you bring the mechanism in can be checked and it must be PARALLEL with the surface of each other.3) Faulty cassettes they are binding in their housing due to heat or bad manufacture! Try to rewind and wind your cassette end to end both directions. 4) head alignment not set correctly 5) clutch of take up reel worn or has a bad tension spring. depending how it was made.
Mar 28, 2012 | Technics RS-TR272 Single Cassette Deck
RS-X501 DOUBLE CASSETTE DECK PROBLEM WITH TAPE DRIVE ON BOTH DECKS
Usually the fault is the failure of the BELT on the mechanism. You will need to remove the covers to have a look on the motor drive behind the mechanism of the tape drive. Thebelt can be changed if you are technically capable to remove and reset the mechanism.
May 06, 2011 | Technics RS-TR272 Single Cassette Deck
Hi receiving error code 6a00 for canon ip6700d
6A00 is a mechanism jam code.
Regarding Error code 6A00. I have a Canon Pixma iP5000. I got that code. No easy answers on the net so I took it apart myself. The covers are all snap locked on. It was a bit painful but I got the side and top covers off to reveal the print head. There is a device that slides back n forth and acts like a window cleaners squeegie on the printhead. This mechanism seemed to be stuck at its full extention rather than being back at home base. Every time I turned it on and off I could see it tried to move but seemed to be stuck. I gave it a little assistance and that released it. I think it had become glugged up with drying ink and that had acted like a glue holding it out at full extension. The mechanism that drives the sliding squeegie relies on a spring
for it to return. The spring wasn't strong enough to over come the gluey ink and so the whole thing jammed up which is probably what the code means - jammed mechanism. If you are going to try it. Do not force any part of the covers. There are little arrows in the plastic indicating where the snap locks are, stick a flat head screw driver in to release. Trial and error will release the right ones first. You'll release one part only to find it hooked up at the next snap lock. Some are hidden under or on opening covers so keep looking. The base seems to be securly attached to the workings so dont try and get it off. Just top and sides. Ink is water based so a damp rag is all you need to clean. If youre not technically minded dont bother.
Jan 06, 2011 | Office Equipment & Supplies
ERROR 6A00 HELP HELP HELP Ayuda porfavor
NOT MY ANSWER- IS A CUT AND PASTE FROM SOMEPLACE DIFFERENT
You may or may not find this usefull.
I thnk the 6A00 is a mechanism jam code.
Dave
HOPE THIS HELPS
May 31, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Aprilia rs 125 wont idle and sputters and sperts when riding in all gears
ok buddy on carb will be a screw try fiddling with this screw till it runs ok also try changing the spark plug underneith the tank you can access this screw from the right side just on carb next to the idle screw black big one with a long flat head screw driver get back to me if no difference
Oct 21, 2009 | 2003 Aprilia RS 125
Jan 18, 2009 | Technics RS-TR373 Single Cassette Deck
No sound from double deck
Look around for micro switches. They might have broke or jammed or something.
Dec 17, 2008 | Technics RS-TR373 Single Cassette Deck
RS-dc10 DCC replacement head
You should contact Panasonic, or Matsuchita. They can most likely give you their authorised parts dealer. You may find the head to be a little expensive.
You will have to have an experienced tech install the head for you. He will have to do a tape path alignment with the frequency response calibration.
Jerry G.
Oct 02, 2008 | Technics RS-TR373 Single Cassette Deck
Technics RS-TR272-no sound during play
CHECK CONNECTIONS AT THE BASE OF THE READ HEADS AS THEY HAVE A TENDENCY TO CRACK OVER A PERIOD OF USE. CAREFULLY STRIP BACK AND RESOLDER, REMEMBER TO LEAVE SOME SLACK AS THE HEADS REVOLVE ON TAPE REVERSAL.
Jun 09, 2007 | Technics RS-TR272 Single Cassette Deck
142 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
