Question about 2wire Wireless-G 802.11g ADSL Gateway
2wire modem and a hd dvr.
I like to know if this is possible. I have a 2wire gateway and dvr next to each other. The gate way has a green RJ45 wire attached to it with CAT 6 wire coming from the dvr into one of the 4 empty ports. My question Is I like to leave the modem where it is right now but move the dvr and tv to another corner of my living room and have the dvr work without any wires is this possible?????? Thank you and kind regards
  • 538 Answers
Yes and no.
You can't make it completely wireless.
But, you don't have to drag cable from your router either. You'll need something like this:
http://www.iogear.com/product/GHPB32W4/
Posted on Mar 20, 2009
How to install to att 2wire 2701hgb modem router
Plug power cord into back of modem and then into an electrical outlet. At this point you should see the lights on the front of the modem beginning to come on.
Check the front of the modem for a solid green DSL light. If the light is still blinking, allow a few more moments before proceeding to step 5. A blinking DSL light indicates a break in the network and will require the help of your service provider if it does not turn solid green.
Open your internet browser and type the default gateway into address bar. The default gateway will be provided by your service provider. Newer model 2Wire modems automatically direct you to the installation instructions when the browser is opened.
Click on "Run System Setup Wizard" in the lower right-hand corner. It may require the system password. This password will be provided by your service provider.
Select your timezone and click 'Next.'
Enter your ISP provided login information and click 'Next'. This should authenticate your credentials on the network and complete the installation.
Jan 02, 2013 | NetGear RangeMax Dual Band Wireless-N...
I have moved to new home. I am using 2wire wifi
you can check if the ethercable is loose or if you have a spare ethernet cable (rj45) you can replace the one that youre using
Jul 14, 2010 | 2wire Wireless-G 802.11g ADSL Gateway
I have a 2Wire 2701HG-B Gateway. The power light stays red and the internet light is green. I have had no problems with this machine in the past and there was no warning for the problem. I have heard it...
1. your power adapter is possible faulty
and the port for the internet is still getting connection signal or the RJ45 is connected and this green light is saying it is connected.
check the AC plug to see of it is properly connected.
Apr 21, 2010 | 2wire (2701HG-B) Wireless Router
Dear all can I connect a hd dvr to my gate 2 wire wireless modem and get so access over the network to the hd dvr?
I connect my HDD to my computer then I allow other computers to authenticate with my computer in the network. So they can access the drive when they want to.
Apr 22, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
What is a 2 wire gate router
2 WIRE is a company that makes routers, Telus uses them to hook up television and internet.They don't appear to be any different unless you consider the fact that the ADSL modem and the router are combined into a single unit. All routers have a gateway IP, but its likely that a "gateway router" by definition may be just a router/modem combo, just a guess.
Jan 04, 2009 | 2wire (1000-400108-001) Router
I hv 2 wire modem bought from my friend, I don't know how to reset user ID and password in this modem
you can try resetting the modem by picking a small pin and pocking in behund the modem which states "reset"
Or if you can access the gateway you can reset it from there.
to access gateway in case type in your browser -- > http://gateway.2wire.net/mdc - <-- you will be prompted to enter password . The default password is 2wire . Once you entered in , scroll down to Troubleshooting which will be on your left
, search for resets <--- Click on it, it will direct you to a page where you can reboot system and stuffs.. Click on the button RESET beside factory defaults. Your modem will be reset to factory default, your power light will change orange and be normal back for about 10 secs ... When everything has come back to normal, you can then continue to enter your user id and password to log in internet.Or alternatively u can Go to http://gateway.2wire.net/setup <--- and configure your modem from there with a step by step guide :)
THANKS
Dec 02, 2008 | 2wire (1000-000057-000) Modem
Can I use a 2 wire router with dishnetwork dvr for upgrades
Hello smithonline,
You will not be able to use another vendor's modem with being on thier network.
- Vincent
Nov 21, 2008 | 2wire HomePortal 1100 Router...
Adding another computer to network
You can have 4 PCs connecting to your 2 wire 2701hgv or 2700hgv wired or wirelessly. Make sure the DSL light and the internet light is green and lighted up
For wired connection, just plug in the RJ45 cable to the ethernet 1,2,3, or 4 and the other end of the RJ45 cable on your laptop LAN card or network adaptor
For wireless connectivity, SSID is 2wire followed by the last 3 digits of the SN(or serial number) and the WEP key is located at the bottom of the 2wire modem in between 2 bar codes in square brackets. If the WEP key and the SSID was changed before in the modem page, go to the modem page and see what is the latest SSID and WEP key using RJ45 cable connected
From Andy Thoo Wai Kiat, Singtel
Jul 19, 2008 | 2wire (1000-000057-000) Modem
No connection
what you should have bought was a ADSL modem/router, but if you only have a router, try the following:- go to the TCP/IP properties of your network card and ensure that it is set as obtain ip address automatically, restart the pc. Connect modem to the router then connect your router via rj45 cable to your pc, then type 192.168.1.254(This should be the default gateway) into your internet browser to get to the router settings. Look for DHCP and enable it to give your pc an automatic ip address and save settings. You should now have a 100MBPS connection to the router, if you have got a modem router ensure that you have the correct Tiscali settings inputed.
Oct 09, 2007 | 2wire HomePortal 1800HG Router...
Open Questions:
See all 2wire Wireless-G 802.11g ADSL Gateway Questions
2wire Wireless-G 802.11g ADSL Gateway Logo
150 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
